#26 | |
![]() Join Date: May 2012
Re: Factory A/C, what to do
White K20 |
#27 |
Moderator
![]() Join Date: May 2007
![]() My pet peeve is non functioning or poor cooling AC. I run hot all the time and use it every time I drive a vehicle. It's one of the first things I learned to do myself because the first classic truck I owned I took to a shop and was charged $800 and got a converted 134 system that blew "lukewarm" air and a failed compressor within 2 months.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#28 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Can you run R134 in an A-10.. I bought my truck with functioning A/C and discovered it has a rebuilt A-6 compressr and has been converted to 134...
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#29 |
FWIW
The vacuum pump and gauges can be had off Amazon for less than 100 bucks shipped. Take your truck once to a shop for anything and you'll have spent more than that LOL! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#30 |
![]() Join Date: May 2017
Subscribed. Will be doing this in a few weeks if I can get my dash wiring harness sorted out.
#31 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#32 |
Moderator
I bought my recent a-10 at autozone, they had a special going on a complete ac kit. Included compressor, a quart bottle of mineral oil (used with r-12), drier/receiver, and expansion valve. Was $325, $50 rebate/gift card made it $275.
A-10 will work with r-134, just need to use the compatible oil. Mine came with 3 ozs of oil already in it, and I think it was pag oil as it had a different appearance than the mineral oil. Just to be sure I drained it and filled it with mineral oil, spun it around a few times and drained it again. I did this a few times to be sure I had compatible oil for the r-12. A quart is waaayyy beyond enough oil to do this procedure.
#33 | |
#34 |
![]() Join Date: Apr 2016
So please tell me how do you go about getting one of those from a place such as Autozone? I just now called Autozone and they have no way of selling me an A10 because when they look up what compressor goes on a 1969 C10 it shows them A6 compressor. They don't know what A10 means. It seems to me (and them) they must have an application, specific year/vehicle/engine size in order to sell something that was not intended for the truck as manufactured. Are we talking about using the same brackets, or are you guys who use an A10 fabricating something? Are the fittings exactly the same as on an A6?
#35 |
Moderator
Go down to autozone and tell them you want an ac compressor for a 69 truck...then look at all the options that come up. It will be obvious from the pic which one it is. The people there have no clue unless you lead them by the hand. Here is a pic of the kit with a part number.
#36 |
Moderator
The a10 bolts right up to the factory brackets and hoses or I wouldn't use it, lol. This is all the stuff that comes in the kit, with part numbers.
#37 |
Moderator
I took those pics at the beginning of May when I first bought the kit for reference in the future. I'll try and get a pic of everything installed when I get home from work late tonight or tomorrow.
#38 |
That would be great!
I just confirmed in person at AutoZone that it is not possible to get an A10 compressor by walking into AutoZone and asking for one. Applications for a 1969 pickup are for A6 compressor only, and there are no kits or individual compressors that is referred to as an A10. With the picture of the box with part number B0743, that was the only way to find information about it. The detailed information he was able to find out about it included some technical information, but no information about the application, brackets to fit, fittings, etc. Nowhere in the documentation they have is it referred to as A10. The guy was knowledgeable but did not have memorized anything about compressor upgrades for an old pickup like mine. This is kind of the same story of how there is no way to walk into an AutoZone and just get a 12SI alternator. You must know the part number or application. |
#39 |
Also, looking on the AutoZone web page it shows this kit B0743 with part number 58098 is an A6 compressor. http://www.autozone.com/cooling-heat...3_246189_34477
#40 |
Quick Google Serach this morning found this. Not plugging just sharing info.
http://www.brotherstrucks.com/64-74-...tinfo/ACC472A/
#41 | |
Moderator
#42 | |
Moderator
#43 |
This thread is very interesting. Thanks for sharing that info. I think there are a lot of things about these trucks that you just flat out can't find out without help from friends.
#44 |
Moderator
Here are some pics. The front hub is slightly different than the ones I've had in the past, and the ones pictured for sale linked above, maybe they upgraded or something? I also painted mine black so it appears more "factory" as opposed to raw aluminum. You can see the factory brackets and hoses connect right up.
#45 |
Moderator
Another
#46 |
Moderator
More from top
#47 |
Moderator
New hard lines and hoses from classic industries (made by old air products). They all are factory duplicates. Drier/receiver was identical and hard lines needed very minimal tweaking to line up. You can also see a new aluminum champion radiator peeking in the back...very happy with that as well
#48 |
Moderator
iPhone pics suck...here's one that's finally oriented properly so you can see how it looks overall. Only thing left is to splice in a heater shutoff valve...but the ac works so well I just haven't found the time to do it yet. I replaced all the vacuum lines and ducts in the dash as well.
#49 |
That's a beautiful and clean engine compartment you have there. Thanks for sharing info about the A/C and your setup and pictures. I have a quite different bracket for the compressor. I don't think I've seen any others with brackets like mine. It is huge and in the way and complicated.
#50 | |
Moderator
Tags |
air conditioner, pressurized, r-12 |
