Old 09-18-2017, 11:18 PM   #26
b-mac
b-mac's Avatar
Re: Beulah - '49 3100LS10
Cleaned up the front lower A-arms and installed new, Pro-Thane bushings. They were a ***** to get out. Had to use a friend's press.
b-mac is offline   Reply With Quote
Old 09-18-2017, 11:24 PM   #27
b-mac
b-mac's Avatar
More floor repair, and my dumb solution to my transmission hump issue.
Old 09-19-2017, 02:36 AM   #28
Nut Case
Nut Case's Avatar
MAC
I respectfully disagree, go to the other end of the spectrum, brilliant.
Just my .02 ...
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-19-2017, 08:02 AM   #29
LCA1971
LCA1971's Avatar
That's a great job, and you said you weren't a fab guys!!!! Looks great.
LCA1971 is offline   Reply With Quote
Old 09-19-2017, 02:38 PM   #30
8man
What he said! Fab work looks pretty good to me.
8man is offline   Reply With Quote
Old 09-19-2017, 09:14 PM   #31
iowaboynca
iowaboynca's Avatar
Now if your "dumb solution" is 1/2 a piece of cardboard taped to a hoop with what looks like a moving tarp as a cover...I may have to agree with you...
If it is the template work to what will turn out to be some nice looking metal work, I will have to agree with the previous 3 posts.
Nice job!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 09-20-2017, 08:54 AM   #32
b-mac
b-mac's Avatar
That's actually a fiberglass welding blanket covering the transmission.
-1 Dumb Point
Old 05-01-2019, 09:05 AM   #33
Matt_50
b-mac, I think we need some updates, maybe a few pictures.
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-01-2019, 10:18 AM   #34
b-mac
b-mac's Avatar
Alright, alright...
No, you're totally correct Matt.
Here we go:
I just showed these off in another thread, but this is the late 90's Camaro brake swap.
I gave the link to the parts to someone else. I can find it again if anyone needs them.
Oh, tall ball joint upgrade first. Supposed to help with geometry when lowered? IDK.
Old 05-01-2019, 10:24 AM   #35
b-mac
b-mac's Avatar
setting the front bumper height
Old 05-01-2019, 10:30 AM   #36
b-mac
b-mac's Avatar
So I was (am) dumb enough to think I wanted a patina outside, and clean and nicely painted inside.
Can't get to these rust spots...too much of a tight-a to take it to the media blaster...live in an HOA so I can't blast outside...
Solution: Let me introduce you to the plastic blasting tent of death!
But look how pretty that clean metal is!
Old 05-01-2019, 10:40 AM   #37
8man
The big brake upgrade is interesting. Please post the link to the parts or PM me with that info. As I recall, the big brakes need at least a 16" wheel, is that right?
I'll bet being inside that plastic tent when blasting was a real pain! Are you still finding sand in unmentionable places?
Looks good though!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
Old 05-01-2019, 10:50 AM   #38
b-mac
b-mac's Avatar
Here's a link to that LS1 brake thread. Last post has the link to V8 s10, where I bought the bracket and hubs.
Hubs are essentially a turned down s10 rotor. If you had a lathe, you could do it yourself.
And yeah, I figure I'll be finding coal slag in crevasses for the next few years.
Old 05-01-2019, 10:52 AM   #39
Matt_50
Shiny! I wish i had invested in a media blaster. I used a lot of wire wheels.
1950 Build
Old 05-01-2019, 10:54 AM   #40
8man
I think I missed the links.
8man-aka Robert
Old 05-01-2019, 12:02 PM   #41
b-mac
b-mac's Avatar
Time to clean up the rear end:
IT ALL FITS! GOOD GAPS!
OFF YOU GO
8.8
GOOD STANCE
Old 05-01-2019, 12:03 PM   #42
b-mac
b-mac's Avatar
my bad
http://67-72chevytrucks.com/vboard/s...55&postcount=9
Old 05-02-2019, 12:29 AM   #43
joedoh
joedoh's Avatar
looks real real good man!
what conversion u joint are you using for the flange rear? my ext cab rear axle is a flange type and I was just going to replace the rear to get a standard yoke on the pinion.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-02-2019, 01:09 AM   #44
mongocanfly
Post Whore
mongocanfly's Avatar
(Tent of death)....I bet that was fun!...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-02-2019, 02:40 PM   #45
b-mac
b-mac's Avatar
Cool. Thanks for saying so.
As far as the drive shaft and joints, I really hadn't gotten that far yet. I was smart enough to get the drive shaft out of the Explorer, so I have the stock "flang to u-joint" conversion...whatever that's called.
I assume there is a conversion joint available to whatever shaft. I remember from my auto parts slinging days that they make just about any combination you can imagine.
I don't really know what to do about a driveshaft either. Haven't done much research, but having one made seems reasonably priced.
Old 05-02-2019, 05:41 PM   #46
joedoh
joedoh's Avatar
well as I normally do, I dived into it yesterday.
napa makes a conversion joint for 8.8 flange to gm, UJ355, 30 bucks.
I ALSO found out the bolt circle on the for flange is the same as my ext rear, 4.25". so woot to you for making me look.
if your driveshaft needs to be 52-53" long, you can use the 2wd 2004 trailblazer (4" aluminum, 52" long) or the stock s10 ( steel, 53" long) and then the UJ355 will set you up.
Old 05-03-2019, 08:55 AM   #47
b-mac
b-mac's Avatar
QA1s and 72 Mustang Tank
Old 05-03-2019, 08:59 AM   #48
b-mac
b-mac's Avatar
Blasting revealed that the Windshield Header was rotten
Old 05-03-2019, 09:06 AM   #49
b-mac
b-mac's Avatar
Since I learned a lot from the builds, I thought I should share this:
My running boards were/are junk.
The pic doesn't do the amount of work justice. I straighten most of the mounting "u-channels" Also, you can see I cut out the long factory u-channel, and replaced it with 1"x1/2" square tubing.
I also eventually welded my studs (1/4" carriage bolts) into place and slotted the mounting points on the truck. Most of my "pressure tabs" that held the bolts in place were junk or missing.
Old 05-03-2019, 09:18 AM   #50
Matt_50
What kind of saw horses are you using? I think i need some like those.
1950 Build
