Old 09-13-2017, 09:49 AM   #26
Robert Haas
Re: Two is easier then one 1965 GMC S/W/BB build
Originally Posted by Captainfab View Post
The dustless sandblasting just uses water along with the blast media. What I have seen done, leaves quite a bit of caked on blast media in the corners and crevasses that is a bit of a pain to take care of. I assume that you are aware that not all blasters know what they are doing on sheetmetal and not all do a thorough job? Also I would not allow anyone to use silica sand as an abrasive. Reason being that not all primers, particularly epoxy, is compatible with a surface that has silica imbeded into the metal. Yes the silica does get into the base metal.
Mobile Soda blasting is what I was considering, however these dry ice blasters seem like the best of both worlds.
Robert Haas is offline   Reply With Quote
Old 09-13-2017, 05:11 PM   #27
scoot_mcgrute
What frame and suspension will be going under the race truck?
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 09-13-2017, 08:48 PM   #28
Robert Haas
We will be building a mostly one off program. Rob @ No Limit Engineering has been fantastic in terms of technical knowledge and I bought the Fat Bar 4 Bar kit from him as a starting point out back. Moser Supplied a narrowed 9" and Rob's people welded on the tabs.
Truck will be on coil overs on all four corners. Penski will be helping us with some 4 way adjustable's too.
Up front The wide ride from No Limit with a splined sway bar as well as Wilwood on all 4 corners.
Old 09-14-2017, 12:26 AM   #29
Captainfab
60-66 Nut
I don't know anything about dry ice blasting. Soda does not remove rust very well and I would not use it for that and other reasons.
Old 09-19-2017, 08:38 PM   #30
Robert Haas
Greg and I decided that we would invest in building an actual frame jig. Something that will become a fixture that we can not only build a truck on it, but use it as a measurable apparatus to lay out and build our frames, suspension and exhaust systems on it.
I chose to use H-Beam with a 6" web over traditional I-beam as the flange is more suited to clamping being parallel with the top face. In this shot you can see one of the 6 legs. The Legs are 6" x 2" 1/4" wall mild steel tube.
1 of the center legs with the adjustable pads I sourced from McMaster Carr
The end legs will have offset pads to clear the lowering caster (you will see more of that later)
The other end.
Standing on its feet for the first time
At 17 feet long and 4 feet wide it is a beast. It will consume some shop space for sure
Old 09-19-2017, 08:54 PM   #31
Robert Haas
Here it is sitting in it's home.
Old 09-19-2017, 09:00 PM   #32
Robert Haas
Details of the caster plates. Using an 8 ton hydraulic jack I can lock the casters in the down position, lifting the pads 2" off the ground. The casters are rated to 3,000 Lbs. each so this rig will roll rather easily even with a full size truck sitting on top of it.
Old 09-20-2017, 12:43 AM   #33
rvrfoot
I hope them trucks turn out as nice as that shop.
rvrfoot is offline   Reply With Quote
Old 09-20-2017, 07:42 AM   #34
timmytimm3
Awesome frame jig. Great idea using the jacks to raise it up like that
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 09-20-2017, 09:41 AM   #35
Robert Haas
After all the work we put into building the shop, the truck builds are easy
Old 09-20-2017, 09:42 AM   #36
Robert Haas
Thank you, simple ideas from a simple builder.
Old 09-20-2017, 12:43 PM   #37
rvrfoot
Very nice shop.
Old 09-22-2017, 10:25 AM   #38
Robert Haas
Took delivery of the rotisserie yesterday. This is going to really help get things cleaned up. Being able to roll the cab and chassis to have access to the bottom sure does appeal to my old crippled self.
Old 09-22-2017, 11:02 AM   #39
rvrfoot
Lets get some chicken on that rotisserie and start cooooooooking.
Old 09-24-2017, 04:20 PM   #40
Robert Haas
No Chicken, but how about some 1965 Sheet metal?
Greg sure looks happy.
Old 09-24-2017, 06:19 PM   #41
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
That is a really nice shop! Very impressive!
What kind of car-covers are those in the background? Do tell please!!
Modges'66 is offline   Reply With Quote
Old 09-24-2017, 09:34 PM   #42
Greg B
Talking Re: Two is easier then one 1965 GMC S/W/BB build
Attachment 1693109
Attachment 1693110
Attachment 1693111
Attachment 1693112
Attachment 1693113
I couldn't be happier!
Greg B is offline   Reply With Quote
Old 09-25-2017, 09:25 AM   #43
Robert Haas
Had those built by California Car Covers.
They are their California Customweave
Old 09-25-2017, 07:00 PM   #44
Robert Haas
I built this Aluminum trailer to tow behind my Goldwing, turns out it is the perfect size to haul the cab over to the sandblaster.
Old 09-28-2017, 08:23 PM   #45
Robert Haas
Loaded up Gregs Frame on to the fixture table.
This was a huge day for us.
Old 10-02-2017, 10:45 AM   #46
Robert Haas
So we stripped the frame down, pulled off all the suspension and misc hardware, (Fuel Lines, brake lines, exhaust hangers, wire loom holders etc)
Now we need to precisely align and square the frame to the rack so we can construct the fixtures.
Old 10-02-2017, 03:33 PM   #47
Robert Haas
Details on the fixtures.
Old 10-03-2017, 09:56 AM   #48
GAc10boy
GAc10boy's Avatar
I'm all in for this one. Love the shop and all the cool jigs, haulers, etc. Thanks for providing dimensions and showing details for all of it. Cool trucks too!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 10-03-2017, 10:14 AM   #49
Robert Haas
Thank You Robbie
The new Wide Ride front clip ships to us tomorrow from No Limit over in Tennessee. That is very exciting.
Old 10-04-2017, 03:36 PM   #50
Robert Haas
So today is the day I cut the frame in half
The No Limit kit uses a raised rail rear frame. So I mocked it up and clamped it next to the original frame for reference and to pull some dimensions to transfer over to the frame fixture.
With everything figured out and chalked out, There was no excuses left so out comes the plasma cutter and I cut the back of the frame off.
