Old 09-16-2017, 10:38 PM   #26
sprint_9
sprint_9's Avatar
Re: Anyone using Speed Engineering Headers???
Originally Posted by coreyjhen View Post
Whose motor mounts are you using?
73-87 c20 with SBC to LS adapter plates
Originally Posted by Steve Cole View Post
Hey Sprint, couple of questions: 1. Can you post a "side view" version of the first couple of pics you posted? And 2. Do you see any clearance issues with the column shift linkage or spark plug wires?
Thanks!
Same question for Racecougar! (If you didn't re-locate your coils)
Havent gotten far enough into my build to know anything on the shifter, but it looks like that has been answered already. I did a little on plug wire mock up and they will be tight but manageable. I am relocating my coils so I have MSD wires, the wires I got have either a 90 or multiangle, up to 45 degree straight boot. Id like to use the 90's and run down behind the headers for that clean look, I just dont think there is going to be room between the bell housing and the header to make that happen.
That plug wire clearance brings up another point that was already mentioned, and that is header to block clearance. They are fairly tight, Im going to run a wrap around blanket in hopes of avoiding any starter issues. I also had to cut a small amount out of the block on the drivers side. There is a square boss toward the rear of the block that doesnt do anything, I cut about a half inch off of that to get 1/4 inch of clearance, so it is basically flush now. No one else has mentioned this block interference so maybe that is my gen 4 block, I am not sure.
Now while I may seem to say the SE headers are tight and in general talk down on them a little above, I did also try a set of Doug Thorley long tubes. And to be fair the SE headers were alot better in my opinion. With the DT headers you didnt gain that much block clearance, and plug wire routing looked nearly impossible. My SE headers came with straight exhaust flanges while the DT's were warped. Overall some of the key things that DT had going for them was the warrenty, ceramic coating, and thicker tubing (flanges are the same), although that thicker tubing was steel vs. stainless. DT didnt hang as low either, but I like the look of the header peaking down and through the wheel well
sprint_9 is offline   Reply With Quote
Old 09-17-2017, 08:46 AM   #27
Steve Cole
Wow! A lot of great info here, thanks for taking the time to post this Sprint_9!
At this point, I am leaning more towards the mid-length headers but the clearance issues on the passenger side have me concerned. I may just give up and rum Camaro manifolds and be done with it.
Steve Cole is offline   Reply With Quote
Old 09-17-2017, 09:15 PM   #28
sprint_9
sprint_9's Avatar
Took some pictures of the long tube to bell housing clearance today.
On the drivers side you can kind of see the square block that was cut at an angle to give me clearance. On the passenger just kind of showing an overall view, pretty close to the transmission bell housing starter kickout. Also it looks a little deceiving on the frame side as my shock bracket isnt bolted down on the passenger side picture.
Old 09-18-2017, 01:31 PM   #29
Steve Cole
Hey Sprint,
Do you see there being any issues with the starter so close to the pipes?
Thanks,
Old 09-18-2017, 01:33 PM   #30
racecougar
racecougar's Avatar
Hey Sprint,
Thanks,
I've had zero issues. No discernible difference in starting whether the engine is hot or cold.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 09-18-2017, 02:55 PM   #31
sprint_9
sprint_9's Avatar
Hey Sprint,
Thanks,
No, Im going to run a blanket so that should cure any heat build up beyond what would be normal.
Old 09-30-2017, 01:09 AM   #32
rctrooper1
Good headers. No issues!
rctrooper1 is offline   Reply With Quote
Old 10-25-2017, 09:13 PM   #33
ivorton74
ivorton74's Avatar
In particular, these:
Attachment 1689266
Part number 25-1021
I am looking for feedback on how well they fit, how well they are made, etc. Also info on the long tube versions.
Thanks!
Im interested in these as well for my 83. Anyone have these in a 73-87 truck?
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 10-26-2017, 10:48 AM   #34
Steve Cole
I ordered a set of these yesterday (p/n 25-1021). I know some people have said that they are very close to the starter and bellhousing area and I was concerned about that but I talked to someone at their shop and he told me these were recently redesigned to allow more clearance in this area AND they now come with V-band connections! This is a bonus to me. Plus, the price was reduced slightly so they are cheaper than before!
Old 10-26-2017, 11:33 AM   #35
ABQ-C10
ABQ-C10's Avatar
I have them on mine as well, but not running yet. Passenger side is tight, but doable. Had to grind down a few minor spots on block for some clearance, but they do state that in the directions. Will keep you posted as I get further along.....
1967 C-10 Stepside - The "Patina Machina" build here! *SOLD*
1984 Chevy C30 crew cab dually - 454/4L80E, Airbags, 4-link/Watts link, 22" Alcoa wheels
Patina Customs
ABQ-C10 is offline   Reply With Quote
Old 10-26-2017, 02:47 PM   #36
Steve Cole
Do yours have the V-bands or the old style 3 bolt connections?
Old 10-26-2017, 04:32 PM   #37
ivorton74
ivorton74's Avatar
Any pics?
Old 10-26-2017, 05:01 PM   #38
'68 C10
I'm running the Speed Eng mids you posted in the initial post. Mine are in a '72 with '01 5.3. Clearances are plentiful on both sides. These are with CPP perches and sliders.
'68 C10 is offline   Reply With Quote
Old 10-26-2017, 05:11 PM   #39
ivorton74
ivorton74's Avatar
Those look awesome. Hopefully they work with the mounts I got. Here’s my engine bay. Running f body manifolds right now.
Old 10-26-2017, 08:03 PM   #40
racecougar
racecougar's Avatar
Glad to hear they took our suggestions to heart. Had to weld our own V-bands on earlier this year.
Old 10-26-2017, 08:35 PM   #41
sprint_9
sprint_9's Avatar
Post some pics when you get them.
Old 10-26-2017, 11:01 PM   #42
Steve Cole
Will do! So far, they have been great to work with.
Old 10-27-2017, 05:43 PM   #43
Sik66
Got a email or link to guy who you got yours ordered that that from?....shot them a Q about getting it ordered like that through their egay shop,but must be trying to flick old stock still....
Sik66 is offline   Reply With Quote
Old 10-27-2017, 07:21 PM   #44
Steve Cole
I can give you their direct phone number but it will be Monday before I can get it. I left it at work.
Old 10-27-2017, 11:10 PM   #45
Steve Cole
What plug wires are you using?
Old 10-28-2017, 01:31 PM   #46
'68 C10
The wires will be MSD. They have yet to be thrown on yet, though.
Old 10-29-2017, 05:56 PM   #47
racecougar
racecougar's Avatar
MSD multi-angle boots work well with these headers.
Old 10-30-2017, 09:48 AM   #48
Steve Cole
For those needing a contact phone number for Speed Engineering, here it is: If you have any other questions our shop line is 559 348 0200.
Thanks.
Old 10-30-2017, 10:15 AM   #49
ABQ-C10
ABQ-C10's Avatar
Steve, mine have the 3-bolt exhaust flange. Here is the best pic I have before I put the cab back on. Just got the LS running and so far so good with the headers. Also, I used the Taylor brand wires for clearance. They are a tad longer, but give them a little twist and they all line up and look kinda cool.
Patina Customs
Old 10-30-2017, 01:19 PM   #50
Steve Cole
Wow, great pic ABQ, thanks!
BTW... what is that bracket on top of your tranny? Is that part of your shift linkage?
