09-20-2017, 12:11 AM | #26 | |
Re: Hide tank filler
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-20-2017, 12:47 AM | #27 |
I'm no fan of the filler behind the license plate as I had a couple of cars with those back when and every time you fill the tank and park on a bit of an uphill angle gas runs out if you have a vented cap and those tanks all used vented caps.
I buy a lot of stainless pieces from this outfit for my sailboat because they have good prices and the parts are pretty nice. If you scroll down the page to the fuel fillers they have flush mount stainless deck fill gas fillers for a reasonable price . Be careful because some read Petrol/gas some read diesel, some read water and some read waste. The hot rod shops that sell the want twice as much for the same thing. http://www.marinepartdepot.com/new316ststcl2.html That outfit also has some nice stainless cabinet hardware if anyone is thinking about building a wood "tool box" to go at the front of the bed and needs hardware.
09-20-2017, 12:55 AM | #28 |
Not bad on prices for those flush mounts. I've never relocated a tank before so I'm still wondering what's my best bet. I see a lot of mustang and camaro tanks for these. Mustang search pulls up issues for the sender and gauges.
If I buy a camaro tank.. My engine is carburetor, mechanical pump, v8 350 stock. I would need to make straps and move or add crossmembers.. What kind of tank? I'm seeing there are different kinds, edu or not I'm guessing. What sender and neck are needed for flush kit? Are there any good guides on installing one? |
09-20-2017, 07:53 AM | #29 |
I used a 01 camaro tank and pump. I ran the filler up to the top of the rear fender. No reason you couldn't weld a fuel filler pocket from something in the fender...
09-20-2017, 07:55 AM | #30 |
I know for sure that you can use your mechanical fuel pump with a rear tank as that's what I have now. I know of another TF with the same setup and no problems. I never liked the idea of the flush mounted filler in the bed as it seems like it would be almost impossible to never spill some gas in the bed
09-20-2017, 08:39 AM | #31 |
I think I could maybe live with the bed fill... not sure I want to add a door in a fender or bedside.
09-20-2017, 10:46 AM | #32 |
Hagan makes lots of gas tank doors with different curves in the outside metal/door. Not too tough to install and they are small. Come with a cap that seals but doesn't have to be removed to fill. here are shots of mine before it was complete and a couple showing the plumbing for ideas even though it's a TF. I used a Tanks unit but don't see why some factory tank wouldn't work, especially if it's not EFI. Tanks just makes it simple.
09-20-2017, 11:52 AM | #33 |
Hollister Road Co.
If you use a mustang tank you do want the Tanks Inc EFI tank not the original type.
EFI tank has the top side sender and a choice of sender ohms, pump or pickup install and a fuel tray to prevent starvation on acceleration and no openings on the bottom. Original tank has the bottom front opening where the pickup and sender go in and you must use a ford unit and your stuck with a 5/16 gas line outlet and then convert the gages to 73-10 ohm and none of the EFI tank benefits. if you're using aftermarket gages its not a big deal. if your using stock 30 ohm gages its a hassle. Many have used the original style tank with success but its more work that its worth in my opinion. |
09-20-2017, 12:05 PM | #34 |
I'm really surprised with the lack of people why say a cab tank is ok. I had thought to clean my tank and see, worst case spend money on a new and i might as well get a rear one.
I'm not using factory gauges. Took mine apart and used the faces on different ones. I could probably do that to a Ford gauge...but what about the wiring. Isn't Ford different? |
09-20-2017, 12:42 PM | #35 |
"I'm really surprised with the lack of people why say a cab tank is ok."
I'm way old and have owned at least 2 trucks that had cab tanks. You never REALLY get rid of the gas smell, let alone the safety idea. You can make the upper mounts out of 1/2" pipe and lots of people sell the universal straps. With the bed off, which most of us end up doing anyway, it's easy to fab up. To borrow the sports phrase,...."just do it!" |
09-20-2017, 12:45 PM | #36 |
Yea my bed is off right not due to swapping the axle and leafspring bushings. Now would be a perfect time.
09-20-2017, 12:50 PM | #37 |
Maybe this weekend I'll have the tank cleaned up. Use it or sell it. If I sell I can't make up my mind for a mustang or camaro tank.
Side note. I'll probably start another thread. I need to figure out what wiring harness to use. My donor truck is gonna be hauled off soon after i yank the engine and ive decided im not sure i wabt to try and use the wiring harness from it. It is from 84 and its got so many extra wires. |
09-20-2017, 06:16 PM | #38 |
I have a Tanks-Inc aluminum tank with a 0-90 ohm sending unit and a Classic Instruments "Fuel-Link" to match it to my original gauge. So far it seems to be accurate but I have only put gas in the tank once. Will take some time and more driving to get a feeling for how accurate it is. My son asked me where I wanted the fuel door and I told him to put it where it was the easiest on him, so he put it on the side. You push it and it pops open, and it's not necessary to take the cap off. I like it.
09-20-2017, 10:24 PM | #39 |
Mine is a fleetside 59 but I made something a little different. imagination can go a long way.
09-21-2017, 08:58 AM | #40 |
Pretty slick!!
09-21-2017, 10:32 AM | #41 |
Matt, I used a 66 chevelle tank on my 54 with stock straps that worked out ok, on my 52 here I used a 69 camaro tank, a little smaller, but had a lot more differential clearance. Stock straps bolted to existing crossmember, and I added 1" sq. tubing for crossmember at the back. I lost install pictures, sorry. I use the standard non vented cap with no issues just open slow like in the old days. There should be a couple of pics.
09-21-2017, 11:55 AM | #42 |
09-21-2017, 10:55 PM | #43 |
Kind of heading off subject but related when considering some of these prepackaged ideas (I like pop open door and modern push through seal door). Link on gas tank safety I found worth reading:
http://www.autosafetyexpert.com/defect_fueltank.php Tanks inside frame and in front of rear axle with filler tube that stays with tank/pulls away, has valve that stays with tube, inertia switch on fuel line...keeping that high octane 100% gas in its place... I'll try to make it happen on this truck I'm building for my son. |
09-22-2017, 11:49 AM | #44 |
09-23-2017, 12:09 AM | #45 | |
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
09-23-2017, 10:53 AM | #46 | |
09-23-2017, 11:19 AM | #47 |
Along with this subject comes the question of how to control venting and gas smell. Mine has no vent but cap and has always stunk a bit and interested to hear how others have vented rear mounted tanks with fillers thru fenders or rear.
09-23-2017, 11:27 AM | #48 |
I did the speedbumpauto one but didn't like it once I got it installed so I removed it and did this one, just don't have it on the truck yet. It was donated by a 89 Ford Windstar van which has the same reverse radius that portion of the fender and was within 1/8" top and bottom on the fit.
09-23-2017, 10:59 PM | #49 |
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-23-2017, 11:21 PM | #50 |
I should have painted it when I had the chance !
