11-02-2020, 02:12 PM | #26 | |
Re: HEI Distributor Wiring
11-03-2020, 10:45 AM | #27 |
The wiring on mine was pretty hacked...I got a new engine harness from AAW that was already set up for HEI
Plug and play
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-05-2020, 02:58 PM | #28 |
Basically, you want to mimic GM 1975 and later wiring. It is 12 AWG, Pink, Cross-Linked Thermoplastic wire (GXL). You only need four feet or so. You will also need an Aptiv (used to be Packard 56) female terminal at the HEI and a male terminal at the firewall junction block.
This is the only 100% proper way to do this (just like GM did it). The old stainless steel resistance wire should be completely removed from the harness, including the old yellow bypass wire from the starter to the coil. The harness should be re-wrapped in 1.25" wide, non-adhesive, vinyl black tape. I've done a bunch of 'em. And, as A1971Blazer says, American Auto Wire is your best source for a replacement engine harness. And it is no problem for them to make it with HEI connectors and wire type. AAW is the best and just an engine harness will not break the bank.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
