Old 06-06-2018, 10:22 PM   #26
J3rm0ff
Re: 72 Swb starting from the bottom
Not much to update. I got the bedsides shaved and in epoxy primer. Got the firewAll pretty much done besides the wire channel. Still need to get material cut for that. Also started collecting more stuff. I got a tial 44mm wastegate, Holley hi ram and btr stage 2 turbo cam on the way. I also talked with the machine shop and my engine is about ready for assembly.
J3rm0ff is offline   Reply With Quote
Old 06-09-2018, 09:17 AM   #27
ilikethewoods
ilikethewoods's Avatar
Originally Posted by J3rm0ff View Post
I got the tanks inc universal 16 gallon tank mounted up and the panhard bar mount bolted up.
Great build! Thanks for the tank heads up! I'm adding this one to my build!
ilikethewoods is offline   Reply With Quote
Old 06-09-2018, 09:24 AM   #28
ilikethewoods
Decided to go a different way with the turbo setup just to simplify things and keep as much of the exhaust out of the engine bay as possible. I ordered a turbo manifold from kb racing and got a hooker manifold with a vband flange already on it. Made the crossover this weekend.
I also picked up a 68 front clip from a forum member. Happy to have found what seems to be very solid panels.
This is a great idea running the exhaust piping through the rear of the engine!
Old 06-09-2018, 10:18 AM   #29
J3rm0ff
The gas tank fits very good with minimal trimming. And I found this exhaust idea from popular turbo kits used on silverados. After I started working on the exhaust facing forward I started getting worried about space and under the hood heat. This way simplified everything a lot for me.
Old 06-09-2018, 10:21 AM   #30
J3rm0ff
Got the intercooler mounts finished and grill support trimmed this morning.
Old 06-10-2018, 10:34 PM   #31
J3rm0ff
Got my champion radiator in this weekend. I had them weld on new inlets and outlets to work with the ls sizes. I needed the inlet on the driver side because of the position of the turbo.
Also finally brought my by bed up from my dads. Was excited to get this thing set on. Can’t decide if I want to use my steel floor or go with a wood floor.
Old 06-21-2018, 10:09 PM   #32
J3rm0ff
after Getting the radiator in I quickly realized he position and size of the turbo inlet was going to be an issue. I found a 5” to 4” elbow on frozen boost.com that looks like it will work perfect.
Also started working on the firewall again. Trying to finish up the day of the metal work so I can sandblast it again and get it epoxy primed next week. The last piece was capping off the wire channel.
Old 06-21-2018, 10:17 PM   #33
Jason7121
Jason7121's Avatar
Nice work so far I'm watching this one
Jason7121 is offline   Reply With Quote
Old 06-22-2018, 04:16 PM   #34
mdelosrey
Good work!
Did you brace the door jambs to replace the rockers or did you go deeper into the floor pan? Down the line I need to replace rockers and kick panel area as well.
mdelosrey is offline   Reply With Quote
Old 06-23-2018, 03:51 PM   #35
J3rm0ff
Originally Posted by mdelosrey View Post
Good work!
I only had to replace the rockers and inner rockers. I don’t think it was completely necessary to brace but always better to be safe than sorry.
Old 06-24-2018, 05:05 PM   #36
72 tigger
72 tigger's Avatar
Really nice build! You're doing it right
72 tigger is offline   Reply With Quote
Old 06-28-2018, 11:20 AM   #37
J3rm0ff
Finally finishing up the wire wall. I got the wire channel all welded up. All I have is a tig welder so it seemed like it took forever. Should save on the grinding tho.
Old 07-02-2018, 04:45 PM   #38
J3rm0ff
Got the cab put back on and some of the cold side piping done. Also had my dad make up a press fit sleeve to make the throttle body fit a 4” coupler snug. I didn’t realize the truck throttle body was like an 1/8” smaller than 4” so the elbow I bought was way too loose. Fits perfect now.
Old 07-02-2018, 10:13 PM   #39
J3rm0ff
Started working on the downpipe. Going with 4” until right after the trans crossmember then I think I will split it into dual 2.5” or dual 3”. It is about an inch from the firewall so I think I am going to have to do some clearancing. Added a picture without the fender and inner fender to get an idea of how the exhaust manifold, wastegate and downpipe are sitting. I had a lot of trouble finding any pictures when I started. I think photobucket had a lot to do with that.
Old 07-10-2018, 08:46 PM   #40
J3rm0ff
I’ve been talking with the machine shop and think I’m going with forged pistons and upgraded rods for the peace of mind. I see the snowball effect starting.
I got the the downpipe tacked together and looks like it will be close but work. Also got a mishimoto radiator fan shroud with dual 14” fans. Not sure how I feel about it yet. The fans don’t seem very beefy.
Old 07-19-2018, 10:23 PM   #41
J3rm0ff
I’ve shifted focus a little bit as I wait for more parts to come in. Started working on fitting the impala dash. For now I am going widen it with the intentions of using a factory style radio. I’d like to fit a double din somehow but that would come later. Really just need to get the dash fitted so I can sandblast the cab and get it in epoxy primer.
Old 07-26-2018, 10:55 PM   #42
J3rm0ff
Got the dash widened. Need to finish welding but it is finally starting to look like something.
Old 07-27-2018, 08:40 AM   #43
Stickman
Stickman's Avatar
Pretty Damn cool.
Stickman is offline   Reply With Quote
Old 07-27-2018, 12:31 PM   #44
TexasLS1
TexasLS1's Avatar
WOW that’s really cool! Also like the Vette observing quietly from her own room lol
TexasLS1 is offline   Reply With Quote
Old 07-27-2018, 05:50 PM   #45
J3rm0ff
Thanks. Definitely looking forward to seeing that dash fit into place for good. And yea I love the vette. Drive it nearly everyday.
Old 07-31-2018, 09:46 PM   #46
J3rm0ff
I returned the mishimoto fan shroud and fans. I’m pretty sure the fans they included were the same fans you can get on eBay for 30 bucks. I bought some aluminum, a harbor freight sheet metal brake and spal high performance fans. I’m about finished with the shroud just need to figure out how to neatly cut out the holes for the fans.
Old 08-05-2018, 02:32 PM   #47
J3rm0ff
Pretty much Finished up the fan shroud today. Just need to figure out how I want to attach it to the radiator on top. Picked up some silicone 90s from summit that will work good for the radiator hose too.
Old 08-09-2018, 10:11 PM   #48
J3rm0ff
Got the intake side of the intercooler piping tacked up. Think I may need to do a little more work to get it a little lower. It has about an inch clearence between the top and the bottom of the hood.
On a side note I think I’m going to get ridetech strong arms. The front just isn’t sitting low enough. About 2” higher than the rear.
Old 08-21-2018, 09:03 PM   #49
J3rm0ff
The impala dash is pretty much where it’s goig to sit. After 100 test fits I’m going to start welding it up. Going to wait on finishing the ends until I order the weather stripping and decide on the door panels.
Old 08-24-2018, 09:51 PM   #50
J3rm0ff
Did a test fit of my dads wheels today just to see how it’d sit. They are 20x12 with a 315/35 tire. Definitely helps envision how it will look.
