02-04-2018, 09:22 PM | #26 |
Post Whore
Re: 72 c30 dump with tool boxes
There was one very similar to yours for sale up here in the northwest a month or so ago.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-05-2018, 08:57 AM | #27 |
thanks
02-05-2018, 09:19 AM | #28 |
Judging by your pics I'd say it a 67-72 frame none of the brackets are bolted on still has original rivets on cab mounts and there is no step up in the frame under the cab like the later square bodies had
02-05-2018, 09:32 AM | #29 | |
Do you know much about these front rotors(pic related) best I can tell they didn't start until 74-75. Also Brakes shoes in rear are narrow(2.5inches) and self adjusting. Seems like they would have been the bigger ones unless like lok Doc said the cross member up front has been replaced? Last edited by daveinluray; 02-05-2018 at 09:33 AM. Reason: calrify |
02-05-2018, 09:42 AM | #30 |
How are the front brake pads fastened on do they have 2 pins that screw into the bracket or a Allen head bolt at the lower part of caliper with a slide key ?
02-05-2018, 09:46 AM | #31 |
Post a pic of the rear axle center cover this will help identify the rear but looking at the pic you posted it looks like a HO72 buy the shock mounts and has the original cast u bolt plates
02-05-2018, 09:47 AM | #32 |
thanks for the offer. Never had splits before so dont know much yet about the pros and cons of them. For now Ill just see what our local tire guy says about the rims when he sees them.
02-05-2018, 09:48 AM | #33 |
02-05-2018, 09:51 AM | #34 |
Also check the size of the rear wheel studs if they are 9/16" thread then it's
71-72 or newer rear the 70 and back rears had 1/2" wheel studs |
02-05-2018, 09:53 AM | #35 |
02-05-2018, 09:55 AM | #36 |
thanks
02-05-2018, 10:01 AM | #37 |
I know around here no one will change split wheel if that ring doesn't seat when you are airing the tire up it can fly off and cause serious injuries or death
02-05-2018, 10:10 AM | #38 | |
found a bit of info on H-072. looks like there were two different ratios with 4.57:1 being common? found some info here http://6066gmcguy.com/H-072.html So looking like rear is original and front is newer? plan to do control arms and tie rod order today. Parts guy was baffled yesterday but thankfully I can give better info today! |
02-05-2018, 10:23 AM | #39 |
02-05-2018, 10:28 AM | #40 |
They could have just did a ball joint and spindle swap I'd try getting tie rod ends for a 79 C/30
02-05-2018, 10:29 AM | #41 |
tire guy here will change splits.
02-05-2018, 10:31 AM | #42 |
02-05-2018, 10:34 AM | #43 | |
very likely given: all the pads and shoes are new but look to have sat for some years. Master is sealed and pristine and power booster disconnected. Only thing they left was running new brake line. Unfortunately though the front calipers are seized, and Im hoping the same wont be true for the wheel cylinders. |
02-05-2018, 10:39 AM | #44 |
The last reman calipers I bought were not priced to bad I think around $35-40 a side at Napa
02-05-2018, 10:46 AM | #45 | |
I can get new for 110 a piece. thinking about going new on the duallys since what I have is pretty beat up. not sure of sizing though to price online, and can only find 8 bolt listed for newer ford and dodge. Again learning as i go and will do some thread searching. |
02-05-2018, 08:52 PM | #46 |
Dave from Loo-ray, how ya doin'? That truck was given a second go round on life is what it looks like. I think it's a '72 with a '67 front clip and maybe some newer parts were used to service the front end. Are those rear wheel studs 1/2"? If so, maybe it is earlier or just the rear is. The dump body and crossover box were probably done in the '80s or newer since that type of tool box wasn't around when these trucks were new.
02-05-2018, 10:02 PM | #47 |
Damn that's a nice truck though! There's going to be some hodge podge with these trucks as just about anything will fit them, they're quite versatile, especially since it's a work truck. I've had my '72 C25 for 21 years and I run it about 20,000 miles a year doing a myriad of things from dump runs to pulling 12,000 pound trailers across the country. Needless to say, even my engine is a hodge podge. The only major component I had original was the transmission and I have to change out the shifter forks. I love my truck but good god, going to the parts store is a life altering event!
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
02-05-2018, 11:20 PM | #48 | |
turns out with a VIN search the truck was cab and chassis only. 9/16 front and rear i believe on the studs. |
02-05-2018, 11:27 PM | #49 | |
02-06-2018, 08:48 AM | #50 |
I spend a good bit f time in that area, visiting my sister who lives in Rileyville. My truck is a hodge podege in ways and it is to make it better. I have an HEI ignition for one thing. It's a 4wd with 4" lift and rather than buy fancy expensive off road company longer brake hose I ask for 1986 C20 hoses because they are the right length. I run headers with the plug wires out the top. I ask for '75 Vette pug wires because they fit. And my starter I ask for a '96 Vette LT4, which is a small bodied starter. I can't think of anything else right now, but I have to keep track of what I change and find it is easier to let the parts person believe I have whatever the parts are from rather than confuse their mind set on make model year for fitment
All the 157" WB C/30s were cab & chassis and the only bed from factory would be the stake body. Must be a true '72 then, with 9/16" studs on rear, too. That's good news since everything is compatible with what came in years since. The '70-earlier trucks used the small studs and the 16" wheels were all split rim, and no newer than '70, so not just laying around everywhere. Using later wheels is no problem for your truck
