Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-14-2018, 03:50 PM   #26
Bomp
Bomp's Avatar
Re: Door Skin Feedback
Yup, after market parts usually need some persuasion to fit correctly.
Original needs a good kick sometimes too.
Bomp is offline   Reply With Quote
Old 03-02-2018, 05:20 PM   #27
dracko
dracko's Avatar
Figured I’d follow up on this if anybody is searching for a good door skin. As expected, the TriPlus skin was equally bad as the Counterpart. The body lines were off by about 3/8” and I’m not even sure how folks use the complete skin successfully. I ended up doing the PS same as the DS, cutting between the body lines and basically tossing the top bit in the bin. Not exactly ideal when you’re paying $200CDN for a chunk of sheet metal.
Here’s a couple pics of how it turned out. Will still need some work, one side and the bottom need to be welded for gaps still.
I tacked a piece of angle iron to it before cutting to minimize panel distortion, it seemed to work pretty good.
dracko is offline   Reply With Quote
Old 03-02-2018, 07:52 PM   #28
MARTINSR
MARTINSR's Avatar
That's when we would refer to aftermarket parts at the shop as "similar."
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-02-2018, 09:09 PM   #29
dracko
dracko's Avatar
Brian
Haha that’s a good way to put it
Old 03-03-2018, 03:24 PM   #30
Bomp
Bomp's Avatar
Glad you stuck with it. You made it line up straight.
