03-15-2018, 01:55 PM | #26 |
Re: Lower Radiator Hose doesn't have a coil spring
get a piece of welding rod and make your own spring
Fuzzy |
03-15-2018, 02:18 PM | #27 |
03-20-2018, 10:42 PM | #28 | |
Even if the water pump pumped 50 GPM (which would be pushing it for even a high volume pump) and the bottom radiator hose was 1 1/2" diameter, it would take a .55 psi pressure differential to flow the 50 GPM through the system. In other words, as long as our radiator cap holds .55 psi, no collapsing will happen. If you have a cap that holds no pressure (bad rubber on the cap), and a clogged radiator, then yes, your bottom radiator hose can collapse. But, I digress - you can believe what you want, and I will believe the facts and physics. Good day. |
03-21-2018, 12:32 AM | #29 |
Who Changed This?
I will say that in general, a collapsing lower hose means a clogged radiator. Does any newer vehicle have a spring? I know that my 2000 Astrovan didn't. But the hoses looked to be made a bit better.
03-21-2018, 04:41 PM | #30 |
It took me a few visits to Advance Auto to get hoses that worked for me....what their computer said would fit did not! Just keep after it, save your receipts, and you'll get there.
I have a bit of a leak though, one hose isn't quite the right fit bit it works well enough. It's on the heater core off the engine though, the big radiator hoses do fit well. I saved their parts number for "next time." |
03-21-2018, 07:25 PM | #31 | |
The upper hose on my 468 BBC will suck the upper radiator completely flat at high RPM. How do I know? When test driving the 468 right after the install I left my hood off. The hose would collapse flat as a pancake. My fix (don't know if it's correct) was to replace the hose with a flexible stainless steel hose. No more collapsing.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
03-21-2018, 08:56 PM | #32 | |
Maybe you've got enough pressure when hot to prevent collapse... should I infer from that you think it's OK to collapse when cold?
03-21-2018, 09:59 PM | #33 |
its best not to think about it too much. I put one in to prevent the lower hose from collapsing. no clogged radiator or hi volume pump. Mine does not collapse and does not restrict flow. problem solved... nuff said.
03-22-2018, 07:50 PM | #34 |
One of the First
NAPA # 7463-Lower Rad/SBC hose and buy a coil off eBay.
03-23-2018, 09:32 PM | #35 | |
When the thermostat is closed (engine cold), there is negligible flow through the radiator - if there is no flow through the radiator, how can the water pump collapse the bottom radiator hose? |
03-23-2018, 09:34 PM | #36 | |
Here's one for all of you - when the hose collapses, it displaces fluid, correct? If the system is full of liquid (which is non compressible for the pressure we are talking about) with a tight cap, where does the displaced fluid go? Magically disappear at high RPM and then reappear when you take your foot out of it?? |
