Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-19-2019, 02:30 PM   #26
MONTE
MONTE's Avatar
Re: C20/cummins 12 valve
I’m looking for a suburban for it. Cummins engine was going into the C20 but a few members recommended that I keep it all stock, plus the 20 is running. Good suburbans are hard to find. So many scams.
I removed the injectors today and gave them a good cleaning. Hopefully this will fix my leaks.
MONTE is offline   Reply With Quote
Old 01-19-2019, 04:17 PM   #27
MONTE
MONTE's Avatar
Looks like it worked!!! No more fuel leaks.
Old 01-20-2019, 03:51 PM   #28
MONTE
MONTE's Avatar
Worked on the engine today but found another issue.
Looks like oil in my exhaust and all my injectors starting leaking again.
This engine was sitting for 10-15 years. Any suggestions where to start?
Old 01-21-2019, 03:46 PM   #29
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You just need to get your injectors rebuilt with new nozzles. The are you cleaned is not where the diesel leak is coming from. On the turbo, the turbine shaft seals are more than likely stuck and allowing oil to go past and into the exhaust. That turbo is not that great so if I were you I would just get a new or rebuilt HX35w. It really depends how much you want to spend.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-21-2019, 06:13 PM   #30
MONTE
MONTE's Avatar
I just ordered a new set of injectors from THD.
Will the HX35w be a bolt on or will I need to change some things?
Old 01-21-2019, 11:38 PM   #31
Dieselwrencher
The HX35 bolts right on. But, you won't be able to reuse your stock intake cross over without an adapter boot. IMO I'd just put an intercooler on and put a different intake horn on and be done with it.
Ryan
Old 01-26-2019, 06:17 PM   #32
MONTE
MONTE's Avatar
Did a little shopping this morning.
Old 01-26-2019, 07:59 PM   #33
MONTE
MONTE's Avatar
Almost got all the parts.Name:  9AC2AE05-CC94-4B48-B831-777B237D9AB3.jpg
Old 01-27-2019, 05:50 PM   #34
MONTE
MONTE's Avatar
I think I got everything I will need.
Old 01-27-2019, 10:25 PM   #35
MONTE
MONTE's Avatar
How can I make this work?
Do I need to change this wastegate?
Is this the correct way to have it setup?
Old 01-28-2019, 07:51 PM   #36
Dieselwrencher
Monte, you have a 2nd gen upper there not a 1st gen style. I have a chrome one I'd sell reasonably. You won't be able to use that 1st gen upper with a 2nd gen intercooler tube so either way you will have to modify something. Either you modify the throttle bracket or you modify/build the intercooler tube. Here's a pic of what a 1st gen intercooled upper intake looks like.
Ryan
Old 02-05-2019, 03:28 AM   #37
Madkidd007
Madkidd007's Avatar
Just keep in mind there is really no correct way on what you’re doing, after all a cummins in a c series truck will never be “correct.” Now on that note you can go wrong on things, but as long as you don’t bottle neck the charge coming from the turbo to the intake you’re fine. My setup is an he351 and comes out 2.75” to a 3” pipe, 3” in and out duramax intercooler and then a modified P-pump intake horn. Silicone couplers/boots are available in many different sizes and step ups. I found the p-pump horn with a 24v plenum plate was the easiest way to clear the brake master cylinder.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 02-15-2019, 03:49 PM   #38
MONTE
MONTE's Avatar
Thanks for the input guys.
I did a little shopping today San Diego and found Getrag speedometer adaptor.
Sucker was hard to find.
Attachment 1875795
Old 03-03-2019, 02:48 PM   #39
MONTE
MONTE's Avatar
Then I found this beast!
Old 03-03-2019, 11:12 PM   #40
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Nice find! Looks like a fun road trip as well.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-04-2019, 12:38 AM   #41
MONTE
MONTE's Avatar
Yup. 1700 miles down. 300 to go.
Old 03-04-2019, 12:55 AM   #42
Madkidd007
Madkidd007's Avatar
Wow that’s a haul with all that weight behind you. Is it a 20 or 1/2 ton?
Old 03-04-2019, 10:28 AM   #43
MONTE
MONTE's Avatar
It’s only a 1/2 but the price was hard to pass up.
Just got home today 0730. Time for some sleep. Drove up Saturday morning.
Old 03-04-2019, 03:07 PM   #44
Madkidd007
Madkidd007's Avatar
A good deal is a good deal. But it may work to your advantage anyways. You can always get an entire front end from a square body 3/4 ton, same as a 1/2 ton front swap. Then when you do that get the engine frame stands as they are the same angle as the 1st gen dodges and you can get away with stock mounts with very little modification. If you want I’ll post a picture of mine and a thought I had on how to redo them a little cleaner
Old 03-05-2019, 12:25 AM   #45
MONTE
MONTE's Avatar
Madkid- yes please, Anything helps.
Old 03-05-2019, 04:09 AM   #46
Madkidd007
Madkidd007's Avatar
Well just a quick snap of my mounts. The frame stands were off a square body, as well as the entire crossmember and suspension. I sliced the original 1st gen mounts and slid the engine down/rubber mount side up. Then just simply welded it up. One of these days I’m going to redo them. The plan is to take square steel and cut it diagonally at the same angle of the current mount and then drill holes to mount it to the block and rubber pads. It’ll be the same thing I have now just not welded together
Side note that notch was to clear my power steering lines, that is till I realized I notched the wrong side. That’s what I get for doing both at the same time.
Old 05-07-2019, 04:20 PM   #47
MONTE
MONTE's Avatar
Little progress on the burb. Motor is in. Just need to figure out the wiring for it.
Had to Flip the intercooler upside down to clear the hood latch. Name:  E836817A-0CD5-45EF-BF5E-445C2553C5B8.jpg
Old 05-07-2019, 08:56 PM   #48
Madkidd007
Madkidd007's Avatar
Had to Flip the intercooler upside down to clear the hood latch. Attachment 1901688
Wiring is gravy, all you need to do is take your original ignition wire and put it to the fuel shut off solenoid, same thing with the starter wire, and that’s it aside from the battery cables Ofcourse. Is that a duramax intercooler? Looks similar to my flipped express can intercooler.
Old 05-07-2019, 09:14 PM   #49
MONTE
MONTE's Avatar
I think it’s a Cummins. Sucker gave me hell to install.
Old 05-08-2019, 10:58 AM   #50
projectking
projectking's Avatar
Attachment 1875795
Where did you find this at, been looking for one for my truck?
Thanks!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
