05-05-2018, 01:12 AM | #26 |
60-66 Nut
Re: gm create motor ?
A question I would ask is, is there a warranty if the engine is not installed in a '96-'02 truck or van and if it is not installed by an authorized shop?
05-05-2018, 06:56 AM | #27 |
yes goes to 12 month warranty .
and i decided to just run it as is no cam swap at this time. K.I.S.S method for now.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-05-2018, 08:38 AM | #28 |
When you decide let me know, I am debating the same thing.
Thought about putting on a 2 piece cam cover. Running it for a year and when the warranty was out doing the cam swap. |
05-07-2018, 06:53 PM | #29 |
placed my order today . should be here by end of the week at most . only few states away .
05-07-2018, 08:12 PM | #30 |
Look at the timing cover when you get it. Seems to me it needed a plug in the bottom and I machined one.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-07-2018, 09:50 PM | #31 |
if so its for the crank sensor position.
05-08-2018, 01:59 PM | #32 |
I removed the reluctor on mine (I'm using HEI) and replaced the timing set with a Cloyes double roller. I finished it off with a stamped metal timing cover, just like any other SBC.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-08-2018, 02:06 PM | #33 |
I'm running the factory cam in mine with a Holley carb and headers. I don't see any need for a cam swap, it has plenty of get up and go.
05-08-2018, 06:13 PM | #34 |
driving is in my blood
So you think that a roller cam that doesn't break the 200*@.050 mark will make the same power as a flat tappet with 15* or more duration? The HT383 cam is lame and tiny. Great for a factory fuel injected engine, way too small to be really worth it otherwise.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-08-2018, 07:49 PM | #35 | |
http://www.hotrod.com/articles/how-t...l-block-chevy/
05-08-2018, 09:35 PM | #36 |
man .................. reading that now makes me want to do the cam swap again .
since its NOT going in a stock 96-00 truck and i am installing it my self . . . i might just say screw it and swap it and to heck with the warranty . . . . oh the choices .
05-08-2018, 11:18 PM | #37 |
60-66 Nut
Did you also change the balancer to an earlier one since you removed the reluctor wheel?
05-09-2018, 12:38 AM | #38 |
I did. I'll look up the Summit part number and post it tomorrow.
05-09-2018, 02:30 PM | #39 | |
http://www.hotrod.com/articles/350-h...ckage-install/ That's a 50hp boost with the non-roller cam.
05-09-2018, 04:10 PM | #40 | |
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
05-09-2018, 04:15 PM | #41 |
Congrats! Looking forward to hearing how it goes.
05-09-2018, 05:09 PM | #42 | |
Another thing you can do is to swap out the intake rockers for 1.6 rockers and that will boost the hp. Last edited by garyd1961; 05-09-2018 at 05:16 PM. |
05-09-2018, 06:07 PM | #43 |
I just finished an L31 5.7 vortec swap. Crate from jegs. Have about 75 miles on it so far. It will roast the tires(which I'm trying not to do until its mnore broken in). Put a 600 cfm summit carb and some cheap long tubes also from jegs. Kept the factory cam. It has plenty of power. Before you do a cam swap try it out. The power is great and has plenty of low end grunt. Only gripe is a slight weeping from where the timing cover meets the oil pan. Hopefully the seals are going to swell a bit and that will stop. Not a leak or anything to worry about at this point. Also for the crank sensor hole on the bottom of the timing cover I used a .075 inch freeze plug. Tapped it in and threw some jb weld over it for good measure. Youre going to love this engine. A huge upgrade from any tired junkyard or original plus roller stuff to boot so no need for special zinc additive or oils. Good luck!
PS are they changing the format of this website? Keep having issues with it and it looks different. Posted via Mobile Device |
05-09-2018, 08:36 PM | #44 |
hay chefk85
what did you do for timming pointer and balancer mark or is there one on it ?
05-09-2018, 11:15 PM | #45 |
There is a timimg pointer molded into timing cover. There's a mark on balancer. I painted the mark white and when at Tdc it lines up with the pointer. That's 0 Tdc. I installed a msd timing tape with 0 on the tape on the balancer mark. Works great. I got a serpentine system from 98 junkyard vortec motor. You can see the mark and pointer just fine. Paid 100 for the serpentine system with the alternator. Bought a new water pump. If you need any help at all just ask. This forum has been a wealth of knowledge and help to me and if like to pay it forward. Good luck! Only thing I'll add is the alternator moved to the other side of the engine bay but it's not a big deal to run wires and there's some great electrical guys on here.
Chefk85
http://67-72chevytrucks.com/vboard/s...25#post7532025 71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress. 79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos. 93 Burb K1500. 350/4l60e Parting out. 2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles! |
05-10-2018, 06:38 AM | #46 |
I have been looking at this and I plan on pulling the oil pan and installing a one piece gasket. I know a couple of people that swear by them. I am seriously thinking about replacing the replacing the timing cover with a 2 piece cover. I am looking at the Edelbrock and it comes with a timing marker.
05-10-2018, 02:26 PM | #47 | |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-10-2018, 08:35 PM | #48 |
There's an engine masters on youtube where they take the lowest GM crate 350 put vortec heads, a cam and intake on it and make power. Sounds similar other than you already have vortecs. Here's a link.
https://www.youtube.com/watch?v=f7mvgf6_p1g https://www.youtube.com/results?sear...engine+masters |
05-13-2018, 12:16 PM | #49 |
I'd put the cam in it and run it. It's a NEW SBC, what could go wrong??
Not to throw a wet blanket on this, but I recently acquired a truck with an LS2 with a ... CARB on it. I love SBCs but I'm not going back. The LS motor makes so much more power, it's just glorious. And you can do it for the same money... Just a thought! |
05-13-2018, 03:19 PM | #50 |
Wow how did I not see this thread?
Ordered mine from Ebay on 5/4/18. Delivery is scheduled for Monday. The only things I've ordered so far: Motor 12530283 Flywheel SCA FP-350L-SFI Intake Edelbrock 2116 (I'm running a Quadrajet) My plan is: cam/spring swap and replace the timing cover Stock exhausts - If I have to replace I'll upgrade to Corvette manifolds Perimeter bolt valve covers Of course a fuel pump. FYI: I've read that you don't have to change the balancer, just use the existing reluctor to make a spacer. I will let you guys know what I find out. Also note: You need to change the gear on your HEI's. Hardened/machined steel Gears are available. You need to measure your shaft diameter to select the correct gear. Last edited by supercheyenne; 05-13-2018 at 03:37 PM. |
