Old 12-31-2018, 11:48 AM   #26
rowdy11
Re: 1971 C20 "LS Swap"
Sounds amazing!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 12-31-2018, 11:48 AM   #27
rjs53
Definitely like to see the dyno run and numbers. It would be great to see what kind of torque your getting with the new motor.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 01-02-2019, 10:07 AM   #28
JustToxic
JustToxic's Avatar
As of right now it is at 397 hp @ 4300 rpm, and torque was in the 380's at the rear tires, after the second dyno run. The motor ran out of injectors, and the trans lost a shift solenoid. Put a set of 42 lbs injectors and replaced all the shift solenoids, and now I'm waiting on the tuner to get it back on the dyno.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 01-03-2019, 12:07 AM   #29
rjs53
That's going to be a dam good running truck. Almost 400hp at the wheels and 15-18 mpg ain't bad. What kind of mode did you do?
2003 Dodge 2500
1969 C10
Old 01-03-2019, 12:19 PM   #30
JustToxic
JustToxic's Avatar
What I know for sure is that it has a Brain Tooley Stage 3 Truck cam, 42 lbs injectors, 3" stainless exhaust. One of my buddy's builds engines, so I had him build the motor and having his business partner tune it. I'm not 100% what all they have done to the motor and tune. Hopefully I'll have the final dyno run and results in the next day or two.
Old 01-29-2019, 03:34 PM   #31
JustToxic
JustToxic's Avatar
Well, after having some injector issues, we finally have the truck tuned and ready to rock and roll. Final numbers are 401 hp and 408 tq at the rear wheels. Now all this cold and snow need to disappear so we can have some fun with the truck.
Old 01-29-2019, 07:06 PM   #32
bmxbang
Solid numbers! Thing sounds fantastic at idle man! I Desperately need to get a cam in my 5.3!
bmxbang is offline   Reply With Quote
Old 02-02-2019, 11:27 AM   #33
JustToxic
JustToxic's Avatar
Thanks, I hope my step dad drive the heck out of it once the weather clears up around here. I'd recommend a BTR (Brian Tooley Racing) Truck cams, this motor has a stage 3 truck cam in it.
Old 03-31-2019, 04:17 PM   #34
JustToxic
JustToxic's Avatar
We put the truck to work this weekend, made it earn its keep. The highway department cut a bunch of trees and branches along the road down and left everything in the front yard. I took my work truck to help my step dad out and he insisted we us the '71. Very happy with all the upgrades we made.
Old 10-03-2019, 01:04 PM   #35
JustToxic
JustToxic's Avatar
A little update on the old girl. We ran into a fuel issue with the duel tanks starving the inline fuel pump. So I'm in process of re doing the fuel system on it, the passenger side tank will have a intake pump and will be the primary tank. The driver side tank will have a booster pump that will pump into the passenger side tank.
Before we had a issue with it, drove it about 55 miles down to a cars and coffee event. It only used about 2 gallons of gas which averaged about 27ish mpg. That was a cruise speed on average of 55 mph. To figure we filled the tank before we left and when we left the event stopped and topped that tank off just to find out how much gas we used. Can't express how happy we are with the power the truck makes and the fuel mileage it has. Can't wait to get the fuel system re configured and drive it again!
Old 01-23-2020, 07:08 PM   #36
999Tinman
Did you use the truck oil pan? I'm wanting to do the swap to my 72 c20. Clean install man!!
999Tinman is offline   Reply With Quote
Old 01-23-2020, 07:09 PM   #37
999Tinman
Did you use the truck oil pan? Sweet install
Old 06-26-2020, 02:19 PM   #38
JustToxic
JustToxic's Avatar
Just realized that this was here. Probably too late now, but I used the oil pan that comes on a 6.0 out of a Yukon.
