Old 06-14-2018, 03:41 PM   #26
Drummerboy
Drummerboy's Avatar
Re: Stock 6" 3 nub wheels on 12" CPP disc brakes?
Originally Posted by demian5 View Post
Start by looking for "witness" marks where the wheel rubs.
Its probably in the Red. But the Green may rub as well.
Look close for where its hitting then grind there. there is NO fluid running through this part of the caliper so you are good to grind a bit away.
I seen the witness marks. I have a pretty good idea where I'd need to grind. I'm just not sure I really want to do that just yet.
Drummerboy is offline   Reply With Quote
Old 06-14-2018, 11:14 PM   #27
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I run 6" 6 lug up front and 8" 6 lug on the rear. I like that look. I found 4-4 nub 6" just in case I decide to up grade to disc brakes. Those 71&up 6" 6-bolt rims are out there and fairly cheap.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 06-15-2018, 01:02 AM   #28
jocko
jocko's Avatar
you might give these guys a call - no guarantee they have em in stock (lots of things they list aren't in stock), but they do still list 6" wide 6 lug on 5.5 bc 71+ wheels. They do exist, I've been to their warehouse when I lived in CA - for hubcaps. But they do wheels too. Worth a call.
https://www.originalwheels.com/chevr...0rims-1972.php
Old 06-15-2018, 10:34 PM   #29
Drummerboy
Drummerboy's Avatar
Thanks guys, very good info. If I can't find them locally I've found them online for around
$50 rash with free shipping, believe it or not.
Old 08-08-2018, 03:00 PM   #30
CRMW
Im thinking of doing this to my 69. Whats size tires are you running?
Tks
Chris
1969 Chev C/10
1972 GMC K2500 Custom
CRMW is offline   Reply With Quote
Old 08-08-2018, 06:17 PM   #31
Canuckvetter
Tks
Chris
I have 235/75/15 on 6” up front and 275/60/15 on 8” out back.
Old 01-14-2020, 12:24 PM   #32
demian5
demian5's Avatar
Well? What did you end up doing?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-15-2020, 01:39 PM   #33
HO455
Post Whore
HO455's Avatar
I know everything is different but I had a similar problem running some Pontiac rally's on my GTO years ago and made some 3/8" spacer plates to move the wheel out so it cleared. That set of wheels got moved to my S10 and the same plates used. By now the wheels and plates have about 250k on them with no problems. The plates cost me $60 to have them made by a local machine shop to be an exact fit on the hub.
I stacked washers on the lug nuts until I got clearance to determine how thick of a spacer I needed.
RIP Bob Parks.
Old 01-16-2020, 12:51 AM   #34
fb111ewo
fb111ewo's Avatar
I would check your local auto salvage place for a mid 70's 4WD K10 truck. I got a set of 4 for $50.
fb111ewo is offline   Reply With Quote
Old 01-17-2020, 07:24 PM   #35
Canuckvetter
Over the Christmas holidays I did install 6 lug disc brakes. The 71-up 6”rims fit flawless. A quick blast and paint and nobody would know there has been an upgrade done.
http://67-72chevytrucks.com/vboard/a...1&d=1579303249
