04-10-2023, 03:22 PM | #26 | |
Re: Battery Placement Question
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
04-11-2023, 03:35 AM | #27 |
Old thread but a good one.
This time around I plan to use an under the backseat battery for 2000 or so Cadillac Deville DTS like the one in the 2000 I used to have. They are a Group 79 that is Height (in): 7-3/8 Inch Length (in): 12-1/16 Inch Width (in): 7-1/16 Inch and put it behind the cross brace behind the seat in a cabinet/ box back there that will hold the battery, speakers and a tucked away storage box. They are designed to vent out through the floor with a vent setup that I will probably snag at a wrecking yard. if I can't just hook a hose to the vent on the battery. I should note that mid 70's Audi 5000 had the battery under the back seat and vented through the floor.. I had one of those back 20 years ago.
04-11-2023, 07:03 AM | #28 |
I’m trying to decide where to put mine now. Thought about putting it behind the seat or frenching the inner fender. I’ve got a drop down box too that I was going to put it on the frame but not sure if I’m going to use it.
04-11-2023, 09:25 AM | #29 |
here is mine in the fender
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
04-11-2023, 09:28 AM | #30 |
lots of different ideas and locations have been used, kinda depends on you truck's design and what is left for space available after custom work has been done to the frame, body, engine bay, exhaust etc. some have used the front of the box with an old cooler or tool box for a battery cover, some use the drop down box along the frame somewhere or in the original spot so the floor can be a solid piece, some french it into an inner fender, some put in the cab with them, I've seen it built into a shallow box under the seat but that truck had a flip up seat like an old full sized blazer. once it is mounted it doesn't really require much maintenance these days but access is required to check connections etc and for replacement some day. if it is hidden you might consider some remote battery terminals placed somewhere handy so you can do boosting and/or charging if needed. part of a good servixe plan for any vehicle includes a battery check for terminals and connections, a load test on the battery and a charging system output test. these would require access to the battery.
04-11-2023, 04:24 PM | #31 |
I think this would look good frenched in the fender BUT it's kinda nice but pricey!
04-11-2023, 04:34 PM | #32 |
I had mine in the fender early on as well before moving it to the firewall. Thinking about moving it back the the fender again but turning it the other way.
04-11-2023, 05:05 PM | #33 |
Yes , they do not look good under the hood, but, IMO, this is where function is more important than form. I have a friend who dreads having to access the battery in his Vette.
Here is what it looks like when done.
04-12-2023, 09:01 AM | #34 |
I chose to mount mine under the passenger side floor using a drop down battery box. I also mounted remote battery terminals inside the engine compartment down by the bottom edge of the front inner wheel tubs (passenger side). This way I can charge/jump the battery from the top side if need be. I did this mainly because my Suburban is bagged and if the battery dies when it is laid out on the running boards I would have issues getting to the battery.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-12-2023, 10:59 AM | #35 | |
I'm liking the idea of accessibility by having it under the hood but wonder how much heat from the headers would affect it.
04-12-2023, 01:07 PM | #36 | |
Marc
04-12-2023, 09:00 PM | #37 | |
it did though! the battery couldnt go forward any, back any or even down any. you cant see the PCM under the air box either.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
04-13-2023, 09:01 AM | #38 |
You did a good job. Is that a 4.3 or 5.0?
04-13-2023, 03:30 PM | #39 |
Joedoe, the guy who proves you can stuff 10 lbs in a 5 lb box and get the lid closed.
I'm the guy who doesn't like open hoods at car gatherings unless under the hood is something really special so that fits my "It's a custom and customs don't look good with the hood open" concept to a T.
04-16-2023, 05:12 PM | #40 |
I installed the drop-down box close to the original position this weekend with remote terminals under the hood. The cables from to the remote seem a bit light to me so I’ll swap those for a heavier gauge. Will have 0ne gauge to the starter/ground. I almost quit mid way through though. I’m getting old & had a time pushing the battery up into position!
04-16-2023, 07:18 PM | #41 |
Well done on the remote connections.
04-16-2023, 09:26 PM | #42 |
Ive got my battery in the stock location with a coupling (?) nut as an extension on the starter positive cable. Has worked good for many years but the idea of remote terminals under the hood intrests me.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
04-16-2023, 10:23 PM | #43 |
if you stop half way through be sure to send yourself an email with where you stopped and whats left. haha
getting old sucks, good thing we have email. lol. |
04-17-2023, 10:01 AM | #44 |
The remote terminals gives you easier access to the battery in case you or some else needs a jump and make trickle charging a snap.
