Old 12-19-2019, 08:13 AM   #26
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: my '59 short bed build
Originally Posted by dsraven View Post
I know it is only mock up and also just a pic, which can be distorted, but it looks like the body line on the cab is not in line with the box. have you checked the frame for straight and sag? just a bad pic?
The bed isn’t bolted on yet; it must have been bumped. The frame is straight.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 01-02-2020, 12:36 PM   #27
1-ton of fun
polishing a turd
So I pulled the bed this morning, cut off the rivets holding factory spring hangers on, and I started drilling holes and bolting up the spring hangers from the 87 Chevy. I’m flipping the rear shackle to put the Shackle in compression instead of tension using a drop hanger kit and drop shackle combined to make a flip shackle lift shackle situation. Hoping to get it all mocked up with the factory 87 rear leafs so I can estimate how much lift I need to level it out and get the rear springs ordered.
Old 01-02-2020, 12:38 PM   #28
1-ton of fun
polishing a turd
Also I picked up a rebuilt np205 transfer case. Just need to get the 4l80e picked up and I can get the trans and transfer case in the truck and measure for driveshafts...
Old 01-02-2020, 12:55 PM   #29
1-ton of fun
polishing a turd
Here it is with the spring hanger bolted on and the shackle and shackle hanger clamped on for mock up
Old 01-02-2020, 11:19 PM   #30
1-ton of fun
polishing a turd
Mocked up the sheet metal to see how it’s all laying out...thinking about the 4” lift springs for the rear. And maybe a 1” block with adjustable pin locations to be able to set the rear axle back 1”. Might put in a stock shackle to make up for the 1” block for axle setback.
Old 01-02-2020, 11:56 PM   #31
mikebte
Looking good. I have been wanting to do that same gas tank and your picture has me convinced. Tank ordered. Keep up the good work.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 01-03-2020, 01:19 PM   #32
1-ton of fun
polishing a turd
I had some 4 x 4 square tubing left over from my carport build, so I cut 2 mock up 4 inch lift blocks to put under the rear springs to see where that with the truck stance. I do not plan on driving with these in it, it is just for mock up purposes to figure out how much is a lift needs to be built into the new springs.
Old 01-03-2020, 01:20 PM   #33
1-ton of fun
polishing a turd
4” is clearly too much. Lol.
Old 01-03-2020, 01:24 PM   #34
mikebte
Looks good, has a nice rack to it. lol
My YouTube:
Old 01-03-2020, 03:34 PM   #35
1-ton of fun
polishing a turd
i ordered some 2.5" lift rear springs today, hopefully that sets it just right. should have them by the end of next week. i'm sure i'll install them the day they arrive and post pics.
Old 01-06-2020, 01:10 PM   #36
1-ton of fun
polishing a turd
i managed to get all front suspension bushings switched out for poly bushings. these little guys actually pressed into the stock front shackle hanger holes in the frame:
https://www.suspension.com/9.9176
then i was able to use the cj5 front shackles, and 1/2" bolts with grease fittings on them, so now all the pivot points on the suspension are poly-bushed, and greaseable!
Old 01-06-2020, 02:44 PM   #37
mikebte
Very Nice!
I would like to see the set up when you have time for pictures.
Old 01-07-2020, 09:22 PM   #38
1-ton of fun
polishing a turd
Some pics of the front shackle setup, now with all poly bushings!
Old 01-07-2020, 09:23 PM   #39
1-ton of fun
polishing a turd
fixed the sideways pics...
Old 01-08-2020, 12:57 PM   #40
1-ton of fun
polishing a turd
just got a delivery notification for my rear springs! hopefully i can get those on tonight and finalize the stance, and move on to mounting the steering box, and getting a single wheel/tire ordered for test fit. thinking about going with a 17"x9" wheel and 35x12.50r17 mud tires.
Old 01-10-2020, 05:45 PM   #41
1-ton of fun
polishing a turd
Got the rear springs in. Thinking the stance is looking pretty good. Ordered one wheel and tire in the size I was thinking of running to test fit. Going with a 35x12.50r17 and 17x9 wheels with a 4.75” backspace.
Old 01-10-2020, 05:48 PM   #42
1-ton of fun
polishing a turd
For reference the wheels/tires in the pic are 31x10.50r15’s with a whole lot more offset than I plan to run.
Old 01-10-2020, 08:19 PM   #43
rgunlock
rgunlock's Avatar
Front to back looks good to me in the pic. Yep, you're going to need more tire to fill those wheel wells though! 2" more on either side of the existing tires looks like it will work out.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-11-2020, 11:41 AM   #44
mikebte
Looks nice. 35" gonna just clear the car port.
My YouTube:
Old 01-11-2020, 06:54 PM   #45
1-ton of fun
polishing a turd
today i got the steering box mounted using the mounting parts from the c10 2wd box kit, with a box for a mid-seventies 4x4 chevy truck, which turns out to be the same box as the 2wd, except for the output shaft.
i mounted the box ~3" forward of where the instructions said to put it, to make it line up with the steering shaft that came attached to the axle. now i just need a 3/4" dd to 1" dd u-joint to have the steering shaft hooked up. I already have a dropped pitman arm on order, and i need to order all new tie rod ends to wrap up the steering. oh and ps hoses i guess too. then steering will be done.
Old 01-12-2020, 08:33 PM   #46
1-ton of fun
polishing a turd
Steering box mounted!
Old 01-15-2020, 12:35 PM   #47
1-ton of fun
polishing a turd
got the u-joint i needed...steering is sorted out from the column to the box!
Old 01-28-2020, 08:58 PM   #48
1-ton of fun
polishing a turd
so i got my test wheel and tire setup, and the tire hits the pitman arm on right turns before lock...so i ordered a different wheel with 1.25" less backspace...
the new wheel came today, hoping i have time tomorrow to get the tire swapped over, then i can see if this one clears the steering...this one is a procomp gloss black steel 17x9 with 3.5" backspace to replace the procomp matte black alloy 17x9 with 4.75" backspace
Old 01-29-2020, 12:31 PM   #49
dsraven
just a quick question, and maybe it's just the angle of the pic, back in post 38 it shows the front spring shackles with a spacer/stabilizer bolt in the middle of the shackle. it kinda looks like the bolt is really going to limit the amount of travel the shackle has and may be bottoming on the frame before the spring even comes close to any bump stops. is there enough travel for the suspension setup? if not those nice new bushings are gonna be split out pretty quickly.
Old 01-29-2020, 03:44 PM   #50
1-ton of fun
polishing a turd
i keep eyeballing that exact issue and wondering if i should get a longer shackle, or one with the brace offset downwards...i likely will do that to avoid issues down the road as you suggest might happen. there are some really neat 'boomerang' shackles that have a bend in them to allow for more travel before the shackle bottoms out - i've been really considering some of those for the front.
thanks for the input!
