Old 06-18-2019, 10:52 PM   #26
TxCajun
TxCajun's Avatar
Re: Dads 1966 C-10
Wow! That's a lot of progress. Looks great!
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 06-19-2019, 12:18 AM   #27
Lokin4AReason
Lokin4AReason's Avatar
Re: Dads 1966 C-10
Looking good. Keep the progress coming . . . .
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 06-22-2019, 04:26 PM   #28
CustomCab66
CustomCab66's Avatar
Re: Dads 1966 C-10
Tailgate was just painted factory dark yellow with ivory letters. Those letters are not decals they were painted first then they were taped off. Once the body color was sprayed the whole tailgate was cleared
CustomCab66 is offline   Reply With Quote
Old 06-22-2019, 08:27 PM   #29
CustomCab66
Re: Dads 1966 C-10
Header panel is done and in clear, fender emblem detailed and installed so the fenders are ready to mount.
Old 06-22-2019, 11:27 PM   #30
Captainfab
60-66 Nut
Re: Dads 1966 C-10
Good job on the masking and painting.....Looking really nice
Old 06-26-2019, 09:08 PM   #31
CustomCab66
Re: Dads 1966 C-10
Header panel and grille together. My dad picked up this set of Cragar S/S wheels and nearly brand new set of Michelin tires for 500. What a score
Old 06-27-2019, 05:50 AM   #32
Android04
Android04's Avatar
Re: Dads 1966 C-10
Looks extremely clean.
Android04 is offline   Reply With Quote
Old 07-01-2019, 12:01 AM   #33
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: Dads 1966 C-10
Really Great Looking Truck
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 07-04-2019, 12:55 AM   #34
CustomCab66
Re: Dads 1966 C-10
Went to dads on Sunday and continued where I left off. LS harness is now completed and it’s now standalone. I converted the main cab harness to accept the gauge cluster since the truck originally had warning lights and the harness is now installed. My dad picked up a fuel pump because the late 80’s pump I. The donor fuel tanks was for throttle body injection. I turned the key and the 5.3 busted right off. Wheels installed
Old 07-22-2019, 03:08 PM   #35
CustomCab66
Re: Dads 1966 C-10
Inner fenders and core support on, and the radiator is in place so the shroud can sorted out
Old 07-22-2019, 03:12 PM   #36
CustomCab66
Re: Dads 1966 C-10
Hole cut in the shroud for the electric fan. I wired the two speed fan to the pcm so the fan will switch on and off as needed. Transmission cooler has been mounted
Old 07-28-2019, 11:18 PM   #37
CustomCab66
Re: Dads 1966 C-10
Fenders in place. Starting to look like a truck
Old 10-04-2019, 02:09 PM   #38
CustomCab66
Re: Dads 1966 C-10
Grille painted and lettered , Hood painted and the clear cut and buffed, bumpers being painted
Old 10-04-2019, 02:12 PM   #39
CustomCab66
Re: Dads 1966 C-10
Interior shots: first picture is a 66 cluster I put together for dad. His truck had warning lights originally. I also modified the original main harness and dash harness to work with the cluster. New steering wheel installed. New black visors.
Old 10-04-2019, 02:16 PM   #40
CustomCab66
Re: Dads 1966 C-10
Dad is back at it again. He painted the bed panels, and decided to use bed liner for the inside of the bed. Oak wood floor and stainless hardware. Bed is taking shape. Wiring installed and lights were tested
Old 10-04-2019, 02:17 PM   #41
CustomCab66
Re: Dads 1966 C-10
More bed photos
Old 10-04-2019, 02:20 PM   #42
CustomCab66
Re: Dads 1966 C-10
Some detail photos. Boy this truck is shaping up nicely
Old 10-04-2019, 02:29 PM   #43
CustomCab66
Re: Dads 1966 C-10
Went to dads last Saturday to work out some kinks in the temp gauge. Helped him install the hood. We fired it up and let it warm up to operating temperature and the temp gauge is straight up dead center at 198 degees. I check the 2 speed electric fan for operation. The fan turns on at low speed at 198 and high speed At 201. As the engine cools down high speed turns off at 198 and low speed turns off at 194. It was 95! degrees in the shop and at idle the engine stayed between 194-198 without fail even with the hood closed.
Old 10-04-2019, 02:40 PM   #44
CustomCab66
Re: Dads 1966 C-10
Cab forward is done. But we found an issue with the rear axle assembly. First it has 2.56 gear set in it and in 4th gear (overdrive) it will run 1,400 rpm at 70MPH. This is a 10 bolt 8.5 out of a 1984 Chevy Silverado so that should explain the gear set. Take off and acceleration will be sluggish. Second the spider gears are toast so either a rebuild is in order or find a donor. We decided on either 3.73 gears which is 70 MPH @ 2200RPM or 3.55 gears that will be 1,900 there abouts @70MPH. My dad said he wants to finish up the rear axle and replace the shocks before installing the bed
Old 10-04-2019, 11:58 PM   #45
Captainfab
60-66 Nut
Re: Dads 1966 C-10
Coming along very nicely. Personally I would go with 3.73's
Old 10-06-2019, 09:12 AM   #46
joesscamaro
Re: Dads 1966 C-10
Nice job guys...truck is looking good!
joesscamaro is offline   Reply With Quote
Old 10-09-2019, 09:50 AM   #47
88Stanger
88Stanger's Avatar
Re: Dads 1966 C-10
Damn fine job!! I like the build, great color combo too.
88Stanger is offline   Reply With Quote
Old 10-09-2019, 01:06 PM   #48
66c10Steve
66c10Steve's Avatar
Re: Dads 1966 C-10
Wow, awesome job....it's looking great
Check out my 66 C10 build here: http://67-72chevytrucks.com/vboard/s...d.php?t=546694
Look here, I also built a canoe: http://stevescedarstripcanoe.blogspot.com/
66c10Steve is offline   Reply With Quote
Old 10-11-2019, 03:49 PM   #49
66ChevyMax
66ChevyMax's Avatar
Re: Dads 1966 C-10
Looking Great!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 06-16-2020, 10:35 PM   #50
CustomCab66
Re: Dads 1966 C-10
Went up and helped my dad fix the gas gauge so we could put the bed on. He had already relocated the gas tank under the bed of the truck so the gauge needed to be fixed first. So other than a radio the truck is ready. My dad decided he wants to go with steel wheels painted yellow with factory white hubcaps. It will look bone stock And will be such a sleeper
