#26 |
landarts
![]() Join Date: May 2005
Re: is Tip and Flip cab dolly available?
Getting closer, was able to get the bottom and diagonal braces welded in. Also added the four bottom diagonal supports for the legs. Drilled the holes for the supports and started getting it ready for some paint. Second pictures shows the dimensions I used for the cart so that the cab will properly. I drilled the holes larger than needed to adjust for some wiggle room.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
#27 |
landarts
Finally got it done and testing today with the K10 cab. Next I will need to test the tilt function. Really like the working heighth of the cab now and works well for my lower back issues.
#28 |
![]() Join Date: Jul 2002
I know this thread is a bit old, but how did it all turn out? Tip function work okay? I'm in the planning stages on building mine and like a few different ideas from each one I've seen.
Patch |
#29 |
landarts
It has been working great. the tip function of the cart has really worked out good. I am now getting geared up for phase two of the build on the cart. I am building additional implements to mount doors, fenders etc for body work and painting.
#30 |
So I am going to go with the original tip & flip design and ordered my metal today. His plans show the wheels getting welded directly to the main frame. There's no reason why I can't weld a mounting plate to that frame so I can bolt and unbolt a wheel in case of failure is there?
Patch |
#31 |
![]() Join Date: Jun 2000
I ended up using the casters he spec’ed, and I can’t remember if the bolt holes were wide enough to clear the width of the tubing they were welded to. Sorry, I can’t check mine because I sold it, but it would be something to verify before you bought/cut the flat metal for this. At worst you could tack the casters and grind them off in case of failure.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
#32 |
You could weld plates to the tube so you can bolt the caster wheels to yhe cart if tubing narrower then caster plate
#33 |
One of the First
![]() Join Date: Jan 2000
I have the metal cut for mine, need to start the welding process. why did you use rubber wheel casters? I would be hesitant because of the welding sparks blowing the tires. No problems?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#34 |
landarts
I used pneumatic tires because I can wheel it to my side yard where there is gravel. If it was only staying in the garage on concrete I would gave used hard rubber. Welding sparks are not an issue, did all rust repair and grinding and it was not an issue.
#35 |
Landarts, so do those mounting plates that the cab mounts to, are those removable, as it looks like they insert into the top of the dolly. If so, then making this into a dolly cart easy for the bed.
I’d like to roll the bed sideways to work on it.
1968 Chevrolet Fleetside C-10 1971 Chevrolet Fleetside C-10 |
#36 |
landarts
Yes they a removable. I have made a few other arms to go on it to hold doors, bedsides, fenders etc., next time I have it in that configuration I will post some pictures.
#37 |
Did they happen to make these for the 73-87??
#38 |
![]() Join Date: Dec 2009
It would not be hard to make one if you have the tools and equipment.
Here is a thread with some dimensions. Link: https://67-72chevytrucks.com/vboard/...ight=cab+dolly
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
