09-28-2019, 07:28 PM | #26 |
Re: front sheet metal assembly
looks like the dimension from the firewall to the middle of the hole for the rubber grommet mount is 1 3/8". bracket over all is 2 1/2" wide, from firewall and looks like 2 3/8 wide across the bracket.sorry, didn't get the dimension from the bend to the centerline of the 2 small holes. let me know if you really need that and I can dig that box out again.
09-29-2019, 02:42 AM | #27 |
That does look more like 1-3/8" to me too (obviously). I'd go with that. Thanks, DS...
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
09-29-2019, 07:40 AM | #28 |
Dransport/dsraven - above and beyond - thx guys.
I used some of this for the trim - worked out real well. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 thanks for the pics/info and measurements.
FAKKY 57 PANEL BUILD |
10-01-2019, 06:07 PM | #29 |
you could buy a small hose (clear or otherwise) maybe 1/8" ID and split it, then slide it over the inner fender that would rub up against the firewall
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
10-01-2019, 08:53 PM | #30 |
upholstery supply shops sell some nice edging as well.
