#26 |
![]() Join Date: Sep 2017
Re: 51 Chev on a S10 frame, named Dale
Nice work!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#27 | |
![]() Join Date: Apr 2009
Desert |
#28 |
I prefer a mechanical fan, and I hope to use one, but that will be a decision during 'final assembly'.
All the front sheet metal is off the truck now, and this weekend I hope to clean up the firewall (I think someone said there are 57 holes?) and get final welds done, then re-paint the frame, tear down engine to inspect and re-seal, then brake and fuel lines, and wiring, and interior and..... a lot to do, but just enjoying the process............snow tomorrow, so I will be in the garage 'grinding'. |
#29 |
![]() Join Date: May 2007
yep, know that process well, my wife sees a truck all put together and the next day all blown apart again and says "I thought it was done!"
looks like a solid front mounting!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#30 |
Thank you , Tempest67, for your time, postings, idea's, and great pictures.
I'm looking & learning as you guys build these trucks. Plus, a lot of the same issues , with different ways & fixes . . . . too make things work. I'm "in & following along" - - - - - jim |
#31 |
After looking at the motor mounts that are used for a SBC, it bothered me that the engine rested over the unsupported portion of the mount.
So I thought I would make a few brackets and weld them in for support. I cut some angled metal to fit in the pocket behind the engine cross member, drilled a hole in it, then drilled a slot in the mount (to match the other 3 slots) , welded it, and ground down the weld. It still needs to be painted, but here is what I did. |
#32 |
Good solution.
#33 |
Looks like you know what your doing...will be following along. What part of Ontario are you from? Been snowing here for last 3 days.
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
#34 |
good thinking, and nice execution!
#35 |
Thanks Guys, just trying to keep the project moving forward, as Johnny Cash would say, " 1 piece at a time"
Olcarguy, I am in Oakville, just west of Toronto. I have seen your metal working skills and am very impressed, keep the updates coming |
#36 |
Thanks Tempest…I know where Oakville is use to live in Mississauga and worked at Molson brewery on fleet
street......unfortunately there won't be an update till sometime after spring. I moved from a 24x30 shop near Peterborough to a 20 x22 space all 90% of my equipment is in a sea can in the drive. panel is sitting in the snow. big shadow is the sea can ![]()
http://67-72chevytrucks.com/vboard/s...82#post8619382 Last edited by olcarguy; 01-28-2020 at 07:28 PM. |
#37 |
Maynooth, had to Google that, and now I see where you are. I used to snowmobile up around there.
The panel is sitting in a lot of snow, No snow down here now, and none in the forecast. Hopefully you will get back at it in the Spring, as I enjoyed the pics of your metal work. |
#38 |
Well, the project just became more expensive, and it's my own fault.
I purchased a SBC with vortec heads from a guy last year, he said the motor ran well, but he is getting a Big Block for his El Camino. I went to his place, saw his car, and his Dad's El Camino parked beside his, and I agreed to buy the motor. So, now, a year later, my friend tells me to open up the motor, and we will have a look inside and reseal it.........guess what???? bad news. I know, I know, I should have taken a head off before I bought it, but I wanted to believe this guy and I really wanted this motor, So, now I am in the process of disassembling the lower end, to see if it is any good, and I will be looking for some heads......or maybe a complete motor if the block is cracked too........ Please don't beat me up too bad, I have been kicking myself since Saturday and I am not over it yet........... Ahhhhh.......... "Serenity Now" |
#39 |
I read up on the Vortec heads before doing mine. They do have a problem with cracks. However, they are plentiful so you should be able to find some that aren't cracked. While you look inside, try to find some better heads.
#40 |
at least you pulled it apart beforehand, saved you some troubleshooting
#41 |
Ya, I guess that is the silver lining to this one
#42 |
My wife says that about once a week or once a month on our projects (depending on how fast we are working). It would be nice to only put each part together once, but that is not how it works.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
#43 | |
Lots of surprises on these projects (and most of them don't result in cash savings LOL)
#44 |
Thanks for the kind words on my metal work. Have to build a garage extention in spring, then hope to be back to work on it....
#45 |
Hi Guys,
I have not updated in a while, but progress is still being made. The sbc is at the machine shop, and I have a found a set of rebuilt Vortec heads, ........ this is causing a serious hit to the budget..... but can't stop now. Anyways, I was planning on using the S10 gas tank, and cutting and adapting the fuel filler neck with some gas line rubber hose. I noticed that the original S10 filler tube has a plastic ball in the fuel filler neck, I think to avoid the tank from overflowing, and fuel sloshing out. Is this piece necessary?? ...what did you guys do, as I am not sure if I can remove this plastic ball assembly and put it in the rubber fuel line?? maybe I can? not sure if I need to?? Thanks for your help |
#46 |
no worries, the ball is an anti-siphon feature, so that fuel will flow past but a garden hose wont.
nice to hear you are still at it!
#47 |
Thanks Russ,
I am still at it, working on the firewall, messing around with wipers, installing Altman latches, bending brake lines, preparing the sheet metal for final assembly...... lots of little things that I am trying to get done, as once that motor is done, it will be full speed ahead. thanks again for the good news about the anti-siphon assembly. |
#48 |
I'm just a little north of you in Sudbury. Nice to see another Ontario build. Mine is a 52, 3 window Saskatchewan truck on a 2000 S10 extended cab, short box. I had to shorten the frame a bit. I have a 5.7 Vortec installed but not running yet.
Just wondering where you sourced the cab corners. One of mine is rusted through but the other side is fine. It will be interesting going through the safety and insurance steps so I will be watching closely. You are a bit ahead of me but if I get in gear, I could have it on the road this coming summer. Brendan |
#49 |
Brendan,
Glad to hear that you are working on a S10 swap, I am enjoying the process. Your winters are longer up there so you will have more time to finish ...ha ha My 51 came from Manitoba, still required alot of rust repair to the cab, but it is amazing how solid the doors, fenders, hood and box are. I am hoping to have it on the road this summer...... but when you put deadlines on a project, it becomes work, not fun....so I am trying to be patient. I picked the cab corners up last year in Carlisle PA at the swap meet, but I found a good place in Courtice ON (near Pickering/Oshawa) named Bill's Truck Shop. They seem to have everything you need for an old truck resto. , and seem to be reasonable to deal with. (not any S10 stuff, but all the original stuff is available)...they also have a lot of used parts. Good Luck with your project, and I will look for your Build thread, if you don't have one, let us see what you are working on. |
#50 |
I really like the look of the original hub caps on these AD trucks. The baby moon with the red 'CHEVROLET' letters.
BUT, our truck is on a S10 frame, and I am using GM wheels with 5 lugs, so the original hub caps will not fit, unless you add the clips., but I did not want to mess around with that. So, I purchased 4 new baby moon hub caps from Summit, https://www.summitracing.com/parts/mrg-4580 and went to my local Vinyl Graphics guy, and he made me up some stickers. I now have baby moons with the CHEVROLET letters. I am going to add 1 inch trim rings, and I think I will have the look I am after. |
