12-31-2019, 11:18 PM | #26 | |
Re: WTB original Blazer Speaker
Do you have a set to sell or one that can be used for dimensions and reference?! |
12-31-2019, 11:23 PM | #27 | |
Thank you Randy! This is perfect. I’ll use this for reference to have a set fabricated. |
01-01-2020, 02:20 AM | #28 |
I dont have a speaker, i wonder if yiu could borrow one for a template, the brackets would be pretty easy to make, one problem is the metal ii think is sheared to width, not standard flat stock.
Found a great pic of how the center speaker looks when mounted properly on brackets that haven't been bent. Mounted as shown the screws are easy to install, not so much with the commonly bent brackets. |
01-01-2020, 08:43 AM | #29 |
Thanks for all the good info on these speakers Randy. When you say early years for the welded nuts is that 69-70? There is so much to learn on these trucks.
01-01-2020, 09:17 AM | #30 |
Carpe manana
Here’s a related thread: http://67-72chevytrucks.com/vboard/s...d.php?t=522444
Wouldn’t the early style work if nuts ground off and brackets slipped between the dash and the AC/heater control?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-01-2020, 09:44 AM | #31 |
2 responses in the thread posted by deadhead have members saying their 71 had the offset speaker.
I think the left mounted speakers are 69-70 and i believe the location moved for gas pedal clearance, 71-2 have the gas pedal cable linkage under the dash and if it has ac the pedal has an extra support for the LH ac vent hose, space became tight in that area with the change in gas pedal so the speaker was moved to the center. Here are 2 more pics of 72 center mounted on brackets that are not bent, note on both the screw heads are hex instead of Phillips. |
01-01-2020, 12:44 PM | #32 |
Good morning and Happy New Year !
OK guys, thank you for your guidance. I just posted a request for dimensions of the bracket or for someone to loan me theirs to be used as a pattern. Hopefully someone will loan me theirs. That will probably be more fool proof (just not sure if someone will want to send me their bracket ). |
01-01-2020, 01:28 PM | #33 |
Here’s a pic of my 72
01-02-2020, 12:40 PM | #34 |
sent you a PM PDXk5
01-11-2020, 05:15 PM | #35 |
Payment received. Speaker shipped today. PMed USPS tracking info
01-12-2020, 03:17 AM | #36 |
One must be a paying member to post a Wanted To Buy... Thanks
01-12-2020, 11:08 AM | #37 | |
i have to dig them out, i`ll post up pics when i do.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
01-12-2020, 12:35 PM | #38 |
Jamie72 interested in 1 of those speakers, sent you a pm.
