Old 04-17-2020, 08:12 PM   #26
gigamanx
Re: Ford Model A Tudor Modern Twist on a Classic
This is the first hurdle I've really scratched my head on. Done a bunch of research and came up with not a picture of example of how to overcome. Hoping I can get some feedback from you fine folks.
I planned and bought a 4 link rear suspension kit with panhard. After setting up the brackets, I realized the forward bracket is basically right where the seat is supposed to go. I need about 3" of clearance which puts my head basically out the top of the roof if I raise the floor that far. Problem two, the lower connecting point is below the scrub line and dangerously low for ride height.
I looked at converting the kit I bought to a ladder bar setup, so I only have to fit one bar under my butt. along the frame rail. What other options would there be to give me some clearance above and below the 4 link? I read that shortening the bars and moving the bracket back to maybe 12" is a really bad idea?
Current bars are 24" in length.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 04-17-2020, 08:18 PM   #27
gigamanx
Something like this maybe gives me the clearance I need? Triangulated 4 link. I would just need to cut the upper bars and build new brackets for them.
Old 04-17-2020, 08:48 PM   #28
mongocanfly
Post Whore
mongocanfly's Avatar
exactly what I was gonna say "triangulated 4link''...or trailing arm style
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-17-2020, 09:11 PM   #29
gigamanx
Thanks man. Triangulated does seem to be the right approach as the picture I posted is almost exactly the setup I'd be aiming for. I have a set of coil overs to go behind the axle with enough room to fit the gas tank also. I am trying to find some articles on where that upper mount needs to be placed on the frame as it seems there would be some geometry issues if I put it in the wrong place.
Love this guy... he talks about it a bit on how to setup the upper section...
https://www.youtube.com/watch?v=FnD40fmlKOA
Old 04-17-2020, 10:30 PM   #30
mongocanfly
Post Whore
there are tons of write ups on t-4links...but the top link should be about 70% of the length of the bottom link ..so if your bottom link was 24" ,your top link should be about 16.8",,and for a street car the bars should be level and parallel
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-12-2020, 08:36 AM   #31
gigamanx
Hey all, would love to give you an update via pictures, but I've upgraded! Hope this doesn't break any rules, but I've started posting YouTube videos as I go along. Partly for updates, partly so other people can learn from things I've tried and failed at.
I'll keep posting on here for everyone but may link to videos also. Update is the install of a cross member with exhaust pass through.
https://www.youtube.com/watch?v=JjBF7trVBRo
You may notice in the intro a silhouette of a 3100. Tip-o-the-hat to my original build "Where there's a Will, there's a way!"
Old 05-17-2020, 05:20 AM   #32
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
A little late to the party but I'm in to watch.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-17-2020, 06:04 PM   #33
gigamanx
Welcome to the party man!
Current state of things after finalizing and installing a triangulated 4 link suspension in the ole hot rod...
4 link suspension install: https://www.youtube.com/watch?v=pQpCUedI8_g
Old 05-17-2020, 08:05 PM   #34
mongocanfly
Post Whore
All the way thru your video I was hollering.. NO NO NO..then you added that last brace to the pinion..
I know your limited by space..With your top bars at the flat of a angle I'd take the coilovers off and check your articulation
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-17-2020, 08:57 PM   #35
gigamanx
Certainly has taken a lot of thought and once I started building I could tell there was no strength in the horizontal bar. Most of the rigidity is now coming from that bolted section on the front.
I do have another issue though, maybe you have some input. I measured my angles and I have 35, 110, 35 degrees on the upper arms. I'm told that is too wide to be successful, but can't find any details on what it should be.
Old 05-17-2020, 09:14 PM   #36
mongocanfly
Post Whore
My internet is acting up and I cant load what I'm looking for...I've got a bunch of stuff saved o suspension setup...I think this is one of the better ones...http://www.trucktrend.com/how-to/cha...ension-design/
But with those bars spread out like that its certainly not ideal...
Where are you getting your angle measurements?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-17-2020, 09:39 PM   #37
gigamanx
Not sure if you can see it, but measuring down the roll center and each upper arm, I get 32 degrees, 58, 58, 32.
I can find articles that suggest 30 is fine, some that say 45 is fine. Now is the time to get it right though cause once I've build a floor, seats, exhaust, it will really suck to have to change it.
Old 06-24-2020, 02:33 PM   #38
doowoppwer
I'm in. Lots to learn.
Roger
doowoppwer is offline   Reply With Quote
Old 06-25-2020, 09:20 PM   #39
gigamanx
Haven't updated my videos, but Roger reminded me I need to update you guys.
4 link was totally removed and redone. After some input including Mongocanfly, I went back to the drawing board literally. Found a 4 link calculator to do all my measurements and calculations. I'll have some videos getting posted soon, but since this is my crew, you guys get some sneak peek photos
New 4 link design. Now has a 90 degree angle between the upper links
Working on framing the car body where the wood used to go with 1 1/2x 3/4 rectangular tubing. Fits quite nicely in the gaps. Its slow going as I'm still trying to figure out where each piece mounts to both the body and itself. I also try to design it so I can remove the frame for paint and reinsert it.
Car was completely missing steering when I bought it. Purchased a full speedway kit with Wilwood brakes. Just mocking up the vega steering box under the engine so I can check clearances and alignment. Starting to look like a real car up front there
Ebay plasma cutter going strong. Really glad I dropped the $200 on that. So much easier to cut steel than a zip disk.
Old 07-15-2020, 06:53 AM   #40
gigamanx
Falling behind on the updates, but not on the work. Each time I was almost finished making a video, I found I needed to work on some other part of the car that was in the way.
Hot summer day, got the new spindles on after painting the axle
https://youtu.be/B0ak6Q1hnSw
Working on the floor braces, aligning the body and doors, along with bead rolling practice on a new firewall.
oh, and goes to show my garage is not always a complete disaster
Old 07-24-2020, 01:21 PM   #41
gigamanx
Bead rolling is turning out awesome on the firewall..
Also got some Wilwood brakes install.
https://youtu.be/zIbHKScvx58
Old 07-24-2020, 01:48 PM   #42
Ol Blue K20
Wow! That looks good.
Dale
Old 07-24-2020, 04:17 PM   #43
mongocanfly
Post Whore
woowzers...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-03-2020, 08:55 PM   #44
gigamanx
Firewall is in....
any suggestions on how to polish up sheet metal so its nice and slick for some primer and paint? Firewall is pretty darn smooth, but I want to be able to scuff the quilt pattern a little to clean it up and not sure what I can use. I've tried wet sanding with a scotch brite pad and that worked pretty well.
Video of the fabrication work and some bead rolling.
https://www.youtube.com/watch?v=ZY83_m6JpIE
Old 08-03-2020, 10:11 PM   #45
Ol Blue K20
Firewall is in....
I think wet sanding and a little wax and grease remover should work.
Dale
Old 08-04-2020, 12:13 AM   #46
mongocanfly
Post Whore
if your gonna epoxy prime it , then I'd hit it with something coarse....like 80-100g...then hit the epoxy with red scotchbrite, highbuild, then paint..
That bare metal really needs epoxy primer on it for a base..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-04-2020, 04:50 PM   #47
gigamanx
Awesome, that's the route I'm taking and the metal looks real clean. Got some epoxy primer I can spray.
Last question and thought....should I close up all the spot welds, or can I leave some gaps to fill with bondo. I think I know the answer is to do it the "right" way would be filling all the welds and grinding flat then use the bondo just to fill low/high spots only.
Old 08-04-2020, 05:53 PM   #48
mongocanfly
Post Whore
Any pics of the spot welds?...if they were really visible I think I'd weld them up and grind smooth...if you used filler to fill them up then theres always the risk of your "bondo button" popping out..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-09-2020, 02:06 PM   #49
gigamanx
Sorry man, took me a while to get back to this. I've been working on buttoning up a bunch of projects for the car...
Pictures are: Welds for firewall, Welds for rear quarter panel corner. Hoping they are enough to smooth over with bondo and give the paint a nice flat surface to bind to. Rear quarter was a pain when I ran into lead filler from an old repair. You can see the two black tack welds higher up from hitting that stuff. Gas masks on everyone!
Still pretty happy with my fabrication skills on the rear quarter so it would fit the new suspension and disk brake arrangement
Old 09-14-2020, 01:30 PM   #50
gigamanx
Would love to share a photo of success and progress today...
Alas, this is not one of those times. After getting this far and finally being able to test fit a seat and pedals, I have concluded I need to be about 4ft 8in to fit in my hot rod. Simply not enough space and my knees are where a steering wheel would go. A combination of things need to occur. I need to move the fuel tank forward about 6" to clear the rear of the cab when lifting the cab off the frame. I'll need to cut all the floor braces I've installed to move them back 6" and snug up against the suspension. I'll need to move the lower links on the suspension back so they don't hit the floor at full compression of the suspension.
ugh!
Let the cutting begin
ford tudor sedan ls
