04-12-2020, 09:34 AM | #26 |
Re: 60-66 extra small stuff lots of it
I was looking at the pictures but can’t see a temperature sender on it. The sensors that I see are oil pressure and are for our trucks that have dummy lights instead of gauges. If I’m not mistaken there is two types of senders for our truck temperature. The one for gauges and the one for lights. The one for lights has two prongs to connect to, usually light green and dark green wires hooked to it. If you had gauges the connection is like a small button that your connection with green wire would connect to. Depending on what cluster a vehicle came with lights or gauges both sensors are common to all Chevy vehicles. Very long answer to (any junkyard V8 or straight six).
04-12-2020, 05:02 PM | #27 |
But Found Her 25yrs Later!
It's in the red circle.
My truck had gauges.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
04-12-2020, 09:45 PM | #28 |
04-13-2020, 12:55 PM | #29 |
I found this, but I wouldn't know how to test it. Maybe put it in different temperature's of hot water and see if the ohms are at those temps.
I don't expect you to go through all that. I figured if you knew that it was correct I'd be interested.
04-13-2020, 06:40 PM | #30 |
That temp sensor is no good according to that chart. Cold or hot
04-13-2020, 07:13 PM | #31 |
Ok, thanks for checking.
04-16-2020, 10:13 AM | #32 |
Active Member
Received the parts yesterday, good stuff, good packing, fast shipment! Thank you!
04-18-2020, 04:51 PM | #33 |
Active Member
Tony, any chance you have un-rusted cab mounts that look like the attached photos? My frame is a 1966 K20
04-18-2020, 06:13 PM | #34 |
These are 68 front look very similar clean yours up a bit see if you agree. Than we can measure the dimensions
07-27-2020, 09:05 AM | #35 |
Ttt
07-30-2020, 01:20 PM | #36 |
Do you have a waterpump bypass valve? Also do you have any front suspension bolts to bolt cradle to the frame
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
07-30-2020, 11:51 PM | #37 |
Hello marine
I don’t have either of the parts you are looking for. |
07-31-2020, 12:24 AM | #38 |
Any fotos of the jack hardware ?
dont want to hear excuses, i want to hear solution(s) |
07-31-2020, 01:15 AM | #39 |
07-31-2020, 03:28 PM | #40 |
Thanks Brother for checking
