04-19-2020, 03:01 PM | #26 | |
Re: Installing door weather strip on '51 Chevrolet
I don't think it's Ebay, Amazon, etc., I think now that with the Covid-19 pandemic is going on a whole lot more people are ordering online now and it's just backing everything up. This may become the normal.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
04-19-2020, 05:06 PM | #27 |
Searching net for more info about D-shaped molding came across Trim-Lok sold on Amazon.
https://www.amazon.com/Trim-Lok-Rubb...00NL4AWTQ?th=1 American made so maybe delivery might be quicker. Slightly more expensive, minimum length 25' but 12 different sizes. Read on Trim-Lok's site that best function when molding achieves 40% compression when in use.
Al '51 3600, LS5.3, 4L60e, Danforth cross., Blazer front susp., Borg Warner 9 bolt 3.27 GR, Wrangler leafs |
05-07-2020, 07:36 AM | #28 |
Post Whore
what a great write up, outstanding tips, and proper result! thank you for doing this
one question I have is, did you remove the metal strip on the cab that held the original rubber molding, and then just glued on the new smaller D shaped strip to the cab? and if so how did you remove it? please and thank you |
05-08-2020, 10:08 AM | #29 |
Only took about a month but my door seals came in later yesterday. This morning I cleaned the DS door and applied the larger "D" shaped seal on the door. I was hoping to shut the door and find no resistance as the smaller seal for the cab has not been applied yet. What I found was the door is very tight and will close if I slam it hard. I had to remove the little rubber door stop off the striker plate. Well.....at least the door did shut this time vs the SoftSeal door seals. I'm not sure why my doors are so tight. It has me baffled.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 05-08-2020 at 10:35 AM. |
05-08-2020, 10:36 AM | #30 |
Should the bottom seal on the door be applied to the very bottom ledge or to the wall facing the cab? I have mine on the wall facing the cab.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 05-08-2020 at 10:44 AM. |
05-08-2020, 03:22 PM | #31 |
I tried the bottom seal in both areas and ended up leaving it on the bottom ledge. I adjusted the striker plate and got the door closing pretty good now. The door is sticking out a little but it was a good trade off for having the seals in place.
05-09-2020, 11:04 AM | #32 | |
My build- 51 Chevrolet |
05-09-2020, 11:09 AM | #33 | |
05-09-2020, 11:11 AM | #34 |
I put mine on the wall facing the cab, that seemed to work best for me
05-09-2020, 11:21 AM | #35 |
Yeah....my gaps are pretty tight. I put the bigger seal on the door on the passengers side and it was about the same closing the door without the seal. No adjustment to the striker plate was needed. On the drivers side I had to remove the small rubber door stop on the striker plate and adjust the striker plate out (away from the cab) to get the door to close better. No way will the smaller seals work. I don't think either door would shut.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 05-09-2020 at 11:50 AM. |
05-09-2020, 02:35 PM | #36 |
Well....at 60+ mph the drivers side door is pretty quite with no wind noise. On the passengers side my wife said there was just a little wind noise and a little air coming in near the bottom rear corner of the door but she said it is so much better than before the seals were put on. I'll have to check into that but I really like how these door seals helped with the wind noise. We are all good in the hood ☺
05-09-2020, 08:25 PM | #37 |
Glad it made the wind noise better! Have fun driving your truck. Im still a month or more away from my first ride!
05-09-2020, 08:56 PM | #38 |
Thanks man. Can't wait to see your finished product.
05-10-2020, 07:37 PM | #39 |
This morning I put a strip of the smaller "D" shapes seal on the passengers side along the bottom of the cab. It is now seal against seal. That stopped all the wind noise. I am very pleased with how this turned out. If for some reason it comes loose I'll just replace it as it was super cheap. Only time will tell.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 05-11-2020 at 08:57 AM. |
05-13-2020, 07:43 AM | #40 | |
Good idea on the seal to seal. Where did you get you “D” shaped seals? |
05-13-2020, 07:45 AM | #41 | |
https://www.amazon.com/Etopars-8Mete.../dp/B06XHJGM33 https://www.amazon.com/Etopars-Weath.../dp/B06XHFKYT1
05-15-2020, 11:59 AM | #42 |
The seals look really clean how you have them. Time for some new floor mats!
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
05-15-2020, 01:39 PM | #43 |
Haha....you don't like my red flames??? They Give me 5 more hp
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 05-15-2020 at 05:13 PM. |
