Old 08-31-2020, 09:25 AM   #26
Nick_R_23
Nick_R_23's Avatar
Re: A freebie! 1986 C10 Longbed
Something interesting! It’s a KEM engine rated at 304HP/396TQ.
Old 08-31-2020, 03:26 PM   #27
LT7A
I would like to know about this. Those are very good truck numbers.
Old 08-31-2020, 04:10 PM   #28
Nick_R_23
Nick_R_23's Avatar
http://www.kemequipment.com/manuals/...r-curve-57.pdf
Old 09-04-2020, 02:14 PM   #29
Nick_R_23
Nick_R_23's Avatar
Prepping the spindles for installation later today!
Old 09-05-2020, 02:02 AM   #30
Nick_R_23
Nick_R_23's Avatar
Front end disassembled and being prepped for the new spindles!
Cut 1 complete coil out of the spring, about 2” additional drop over the 2.5” spindles.
Spring and spindle reinstalled.
My dumb ass forgot to check the brake package before ordering the spindles...turns out this truck actually had the 1” rotors! So, perfect time to convert to JB5 rotors and calipers!
Caliper and new pads installed! I’ll have to wait until tomorrow on the hoses, they ended up being a day out.
Since the front end isn’t complete yet, enjoy another glorious rear end shot!
Old 09-05-2020, 09:14 AM   #31
jjzepplin
jjzepplin's Avatar
Fancy indeed! Nothing wrong with a good rear shot.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-06-2020, 02:38 AM   #32
Nick_R_23
Nick_R_23's Avatar
Thanks!
I finished up the driver side today with a new brake line!
Completed the passenger side too!
Installed the sway bar lowering brackets!
Sway bar reinstalled!
The front end is all back together!
Back on all fours!
This is perfection! Exactly what I was going for!
Old 09-06-2020, 09:24 AM   #33
jjzepplin
jjzepplin's Avatar
That is very nice! Do you have any information on the kit you used?
Old 09-06-2020, 10:58 AM   #34
Nick_R_23
Nick_R_23's Avatar
Thank you! And yes, I do! Overall, this is about a 4.5” front/6” rear drop. Current tire size is 235/70R15, I will likely keep that front size and go 275/60R15 in the rear.
The drop spindles are Classic Performance CLP-CP4s4 2.5” drop spindles. https://www.summitracing.com/parts/clp-cp4s4
The coil springs are stock 1/2 ton V8 springs with 1 complete coil cut as seen in the pictures, equal to about 2” additional drop. The rear leaf springs are the stock 3+1 spring pack, the overload spring is intact and no leafs were removed.
The axle flip kit is UMI Performance UPI-6410, with a 6” drop. https://www.summitracing.com/parts/upi-6410
The shock extensions are UMI Performance UPI-6411. https://www.summitracing.com/parts/upi-6411
The sway bar relocation kit is Classic Performance CLP- 6372LSB. https://www.summitracing.com/parts/clp-6372lsb
Old 09-06-2020, 11:52 AM   #35
Corts60
Just here to tinker
Corts60's Avatar
Great work so far! Very nice stance.
