Old 09-05-2020, 11:27 AM   #26
daveshilling
daveshilling's Avatar
Re: Frame mounted Dual chamber Master cylinder for Drum/Drum..who's done it? Who like
Originally Posted by G&R's57GMC View Post
Dave on a chassis mount power booster/master cylinder do yourself a favor and run the vacuum line from the engine to a high point on the firewall and install a vapor separator from a 70s 80s Chevy caprice or Malibu then run the line down to the booster .
Phil my friend with a Cameo didn’t and had to replace the booster later because the fuel vapor wreaked the rubber in the booster.
Definitely something to look into!
daveshilling is offline   Reply With Quote
Old 09-05-2020, 11:05 PM   #27
G&R's57GMC
G&R's57GMC's Avatar
The part is called power brake filter
Dorman 80195
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 09-05-2020, 11:18 PM   #28
nvrdone
could this filter be mounted at the intake manifold instead of on the fire wall and work properly?
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 09-06-2020, 10:20 AM   #29
G&R's57GMC
G&R's57GMC's Avatar
The p.b. Filter should be mounted vertically with the straight inlet at the bottom and be higher then the top of the carb . The higher the better.
Good location would be just below the firewall seam or if you’re going for a shaved firewall mount it inside the firewall. Just be sure that the vacuum line has a down hill slope to the manifold. The line going to the p.b. Booster can be a hard line with short vacuum hose to the booster.
Be sure to use power brake vacuum hose , it’s thicker and fuel vapor safe and won’t collapse.
Glen & Jane's Rides
Old 09-06-2020, 12:35 PM   #30
nvrdone
ok, thanks for the info. i will add it to my project list
Old 09-14-2020, 01:33 PM   #31
daveshilling
Dorman 80195
I found the GM version on ebay for about the same price:
GM 17056236
