09-23-2020, 02:40 PM | #26 |
Re: Tech Tips and Tricks-Post your favorites!
Not an actual on the vehicle tech tip but a solve the does it exist in the aftermarket tip.
I'm in belief that there is no possible way that they can or do actually stock all of the parts that they show and delayed shipment on a park light lens for my 77 dualie shows that but if you are hunting for an odd ball AD part and want to know if it exists checking the Filling Station catalog will usually show if it exists in the aftermarket. https://www.fillingstation.com/index.htm I've found that the more vague the description is the better chance you have of finding the part even though you may have to do a lot more scrolling. It's not a suggestion to buy from them necessarily but a resource to use in your searches.
09-23-2020, 02:44 PM | #27 | |
09-23-2020, 07:57 PM | #28 | |
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
09-23-2020, 10:31 PM | #29 |
I know some will say that you can use a tape measure but I've found that it is a lot quicker and far more accurate to use a bolt circle gauge when wheel hunting or brake drum checking.
The top two images were snagged off Ebay but I have all three styles. The slide gauge is about 12 bucks or less and you set it to the size you want and use it like a go/no go gauge. It covers about all the bases for car and light truck too. The larger plastic one can often be found at the cheap tool vendors at swapmeets or car shows. Prices are all over the place on EBay. Works great for checking the stud pattern on hubs or axles along with checking wheels. The bottom one is one I picked up a few years ago and is aluminum and fits in a hip pocket in a pair of jeans but does take a tad more thinking to use.
09-25-2020, 04:24 PM | #30 |
Some good tips in here so far! I started grouping some of them together up top so they're easy to find categorically.
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
09-25-2020, 04:32 PM | #31 |
