12-04-2020, 10:45 AM | #26 |
Re: 66swb
What do you estimate your front and rear drop is? And....did you go with 16” wheels to help clear front lower control arm from hitting a drop spindle?
12-05-2020, 02:46 PM | #27 | |
Re: 66 SWB Fleet
I'm not familiar with redline resto, and some preliminary googling turned up a few small shops. |
12-05-2020, 09:42 PM | #28 |
Junior Member
Re: 66swb
3/5 static drop. I used 2 1/2” drop spindles from CCP along with a 1” drop coil. Yes, 16” cleared LCA. Needed to grind a bit off LCA see the outside edge of the rotor.
12-05-2020, 09:44 PM | #29 | |
Junior Member
Re: 66 SWB Fleet
www.redlineg.com Last edited by Ghetto Fireman; 12-05-2020 at 10:17 PM. |
12-05-2020, 10:38 PM | #30 | |
Junior Member
Re: 66swb
67-70, bought it in 2016. Last edited by Ghetto Fireman; 12-06-2020 at 06:40 PM. |
12-06-2020, 10:16 AM | #31 |
Re: 66swb
Thanks for the wheel and suspension info.
How about steering?.....I see you have the period idler arm and also have power steering. Are all of your steering components from 65 Such as centerline, inner and out tie rods, or is it a mix of late model as well? Sorry for all the questions but I’m hoping to do many of the same Upgrades . |
12-06-2020, 10:47 AM | #32 | |
Junior Member
Re: 66swb
12-06-2020, 05:30 PM | #33 |
Re: 66swb
Your avatar image looks like the truck has some caps now. Is that from previous or have you made changes?
12-06-2020, 06:36 PM | #34 |
Junior Member
Re: 66swb
Yup, old photo. Current as she sits now
12-06-2020, 11:10 PM | #35 |
Junior Member
Re: 66swb
Here’s a photo, exhaust is now ceramic coated.
12-07-2020, 12:45 AM | #36 |
64-66 CHEVY JUNKIE
Re: 66swb
Good Looking Truck Ghetto Fireman..
Stance is Killa..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
