Old 11-19-2020, 12:21 AM   #26
cornerstone
cornerstone's Avatar
Re: Thanks Joe, I didn't have anything better to do.
Originally Posted by Dr Jekyll View Post
It's supposed to be fun for me and when I get stressed out it defeats the purpose. Most the time I have to research how do things. My wife asks "How do you know how to do this?" and I reply "What makes you think I know what I'm doing." Admitting that I don't know keeps me open to learning and thats partially what this project is about.
I hear ya loud and clear. I'd bet for every hour of actual hands on work time on my truck, there was 3 hours of "research". I've learned many times that there are better ways to do the job than the way I was planning to do it. I've had occasions when I got a job done, then came here to see how others handled the same task. A time or two I went back and "re-fixed" it because I found a better solution after the fact.
I've come to believe the saying more and more... "its about the journey, not the destination"
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-19-2020, 10:45 AM   #27
MDPotter
MDPotter's Avatar
That's a great attitude to have. I tend to get so tunnel visioned trying to get the project done that I overlook other things I should be doing with my time or taking the enjoyment out of it. With every project, we get better. There are lots of things I wish we would have done on my dad's 64 that we did on my 68, but there are a few things I wish I would have done on my 68 that we are doing on our current 69. They get better and better!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-19-2020, 10:45 AM   #28
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Truth!! I almost want to build another truck now because it seems like a waste to have all this knowledge of what I should have done
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-21-2020, 01:45 PM   #29
Dr Jekyll
Dr Jekyll's Avatar
Interior and engine bay.
“Hammer to fit, paint to match.”
My 70 C10 frame off
3d wheel and paint mock up?
Dr Jekyll is offline   Reply With Quote
Old 11-21-2020, 02:07 PM   #30
Dr Jekyll
Dr Jekyll's Avatar
Installing a new bumper today $150 from classic industries, looks good. The original has a slight tweak on the drivers side, it’s barely noticeable but sticks out to me. Then I have a new hardware set for the bed. Stainless steel unpolished was $120, which is going to take a while with all the pieces.
Size:  49.7 KB Name:  7FC7F6D7-3F38-4C04-8F05-699A62820E09.jpg
It’s a beautiful day to turn some wrenches, it’s 75 with a slight southern breeze. (Back yard pic)
My 70 C10 frame off
Old 11-22-2020, 02:02 PM   #31
Dr Jekyll
Dr Jekyll's Avatar
FYI the repop bumper is 1/16 thinner than the original, and the “OER” bumper hardware has longer square retaining area so the bumper required some body shims on the outside bracket bolts to get the fasteners to engage. Here is the before and after. The originals’ driver side is slightly pushed up and has a creased/pinched area on the top and bottom of the inside bumper fasteners.
Size:  51.6 KB Name:  52D23C56-5BA3-47ED-BE79-35984890EC15.jpg
Here is the new bumper hardware compared to the original and the shim I used to fix it, took two shims on each side.
Also, the bed hardware kit didn’t include flat washers so I had to use some I already had. I think the kit was for wood and steel beds because it had an undersized set of rounded head bolts that weren’t applicable. This kit did not include wheel well to bedside bolts, or front bed panel to bed side hardware. I keep all the original parts and fasteners, learn that lesson early with the Camaro, so I will chase the threads on the old fasteners and paint them black.
My 70 C10 frame off
Old 12-11-2020, 12:40 PM   #32
lupo
Thanks for the encouragement guys.
I felt pretty good about spraying the color because I have sprayed a lot of epoxy primer, but the clear was a whole new animal for me. Bright light when spraying clear is a must and I really needed a couple more coats. After I touch up the blemishes on the color I want to wet sand the exterior and respray the clear.
My 4 year old son is on me almost everyday about working on the Camaro he’s a miniature gear head already.
Really great workmanship and I really like the way you weld. As far as the paint thing goes, I'm sure you'll be able to straighten that out. Great job
lupo is offline   Reply With Quote
Old 12-12-2020, 03:56 PM   #33
Dr Jekyll
Dr Jekyll's Avatar
Thanks, lupo I taught myself how to weld, so that compliment is appreciated.
My 70 C10 frame off
Old 12-16-2020, 06:11 PM   #34
MikeinNH
Great deal on that truck. Love these kinds of threads, good motivator.
Mike
https://www.youtube.com/channel/UCUa...rZijm2tORBoexQ YT channel of my son and mine.
71 resto-mod (probably take years to do)
Projects: 71 C10 going on 04 Tahoe chassis * 67 IH 1200B Pickup mostly original w/ ext rust repair * 41 Buick Super 8 4 Door all original * 52 IH L-110 Panel Van getting S10 motor * 73 Datsun 620 Pickup all original
MikeinNH is offline   Reply With Quote
Old 12-16-2020, 08:42 PM   #35
Dr Jekyll
Dr Jekyll's Avatar
It was priced to move, I really couldn't pass that deal up. Joes a good guy and knew I would fix it up. He's got a 66 SWB, but Im not sure if he posts on this site. Hey, if you get in good with him he mite sell you his 66 for $500.
My 70 C10 frame off
Old 12-17-2020, 09:49 AM   #36
May70
May70's Avatar
Very Nice!
Im still debating how I want to take care of the inside of my doors....
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
1970 c10, frame off rebuild, lwb
