04-08-2021, 05:19 PM | #27 |
Re: Making a bed floor lift up
They seem like they collapse down smaller. Do they elongate more as well? Great job.
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
04-08-2021, 07:22 PM | #29 |
Jan, nice design on the hinges. Do they lift the bed as much as you might want?
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-08-2021, 07:33 PM | #30 |
04-08-2021, 09:35 PM | #32 |
Do you think if we notch it, then it would lock in the up position so you wouldnt need struts or a prop rod?
04-08-2021, 11:32 PM | #33 | |
I made some wood tracers today, tomorrow I will go to my nephews shop and use his plasma to cut out a steel stencil for the plasma.
Jan's 53 |
04-10-2021, 01:49 AM | #35 |
Looks great. He cuts better than I do lol!
04-10-2021, 12:39 PM | #37 |
I pmd you
04-10-2021, 05:31 PM | #39 |
I didnt get your message I tried you again. Maybe you have to many messages I know Im almost at my limit and need to delete some. If not my email is jocww@aol.com
04-12-2021, 01:48 AM | #40 |
Thanks again for all the help today!!! Lesson learned I need a bigger hypertherm!!!! and maybe a 12 in disc grinder lol
04-12-2021, 09:36 AM | #41 |
I would love to have those plans as well.
Were you guys able to connect, or do you want my email? |
04-12-2021, 11:42 AM | #42 |
Jocww drove the two hrs to my house yesterday and we cut some out with the plasma. I’m going to check with a friend who has a lot of parts cut for him on a water jet a see if that is a viable option. It takes some work to finish them when cut with the plasma which is fine when making one set but a little more labor intensive than I’d like.
I will pm you
Jan's 53 |
04-19-2021, 03:19 AM | #43 |
Ok so here’s where I’m at on the hinges. Friday I went and dropped off the prototype hinge with the engineer and he is doing a CAD drawing for me, then I will send it to send-cut-send in Nevada to be water jetted for me.
Jan's 53 |
04-20-2021, 11:28 PM | #45 |
That could be a benefit for you and everyone that really likes your Hard work and planning.
The Set-Up takes the most time. Then once it is set up and the (supplier of the part) knows you want multiple parts. They can run the same program and make a-lot of these. For example : They could buy a 4x8 sheet of material. Then use there Software to cut the parts out. 1 Sheet of material/ 1 setup Then they can name the program( NorCalGal O1277) That way when you call them they could reproduce some more. Just food for thought Hope this helps . .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-22-2021, 12:54 PM | #46 |
norcalgal i like your use of cardboard templates
people don't understand the usefulness of a template
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-24-2021, 08:29 PM | #47 |
Wow awesome work and i'd be interested a set or in the cad drawings that i could get made up in the great Canadian north..
04-24-2021, 11:22 PM | #48 |
Going to call and get a quote sometime this week. I will probably do like Getter-Done said and get multiples cut at once if the $ isn’t too much.
Jan's 53 |
05-07-2021, 10:08 PM | #49 |
So I got my quote back on getting my hinges cut today more than I thought it would be,but apparently steel prices are way up right now $120 for a set ouch. Oh well I’ve come this far! I will post some pictures when I receive them.
Jan's 53 |
05-07-2021, 10:42 PM | #50 |
Actually that's not too bad for your Great design,
If you factor How many pieces are in a kit? There looks to be 14 in just the pivot section. That not factoring the pieces that mount them to the bed, Maybe 8 more pieces? Even at 14 pieces =$8.57 each. If it is 22 pieces that's just $5.45 each. Just food for Thought. Great Idea. Maybe if you get enough orders it can push the price down. The Question I would ask them is: How many sets can you cut out of a 4x8 sheet of metal? Hope this helps .
