04-02-2021, 02:58 PM | #26 |
Re: Rear Sway Bar
Haha, don't be mad dude. I felt it was important to correct the misinformation since it directly pertains to the question the OP asked. If he removes the rear sway bar his rear suspension will have more independent articulation which translates to a better ride, at least in a straight line. Not worth the benefit of more stable cornering though, IMO. Generally speaking, the stabilizer bar doesn't affect the ride as much as springs or shocks, but it still has an effect. Otherwise the OEMs would put big bars front and back so that every vehicle handled well. Unfortunately those big bars take away from the suspension's ability to react differently to road surfaces from side to side.
04-02-2021, 04:15 PM | #27 |
Who Changed This?
Re: Rear Sway Bar
FWIW, I have a Longhorn, so it has a 1T frame and it has the G50 HD rear spring. It only has 6 leaves. You could probably dial down the number of leaves as was mentioned, but that's your call.
04-02-2021, 07:13 PM | #28 | |
Re: Rear Sway Bar
https://www.hellwigproducts.com/prod...del=C20+Pickup I put the kit for rear coils on my '69 back in the day to help reduce sway induced by the cabover camper. I took it off when I restored the truck. I really didn't notice much, if any, improvement. Based on the picture that kit is almost unchanged since. Too bad you aren't close to Wisconsin. You could have it.
Jim Last edited by FirstOwner69; 04-02-2021 at 07:21 PM. |
04-02-2021, 07:35 PM | #29 | |
Re: Rear Sway Bar
04-02-2021, 08:07 PM | #30 | |
Re: Rear Sway Bar
