#26 |
![]() Join Date: Dec 2009
Re: Low mileage 1987 Chevy 1/2 ton to 3/4 ton - Undoing the hacks!
Great deal on the tailgate.
Your'e making good progress ![]() ,....
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#27 |
Thank you! More progress this weekend. Painted all of the engine’s sheet metal.
![]() I picked up a new single roller timing set, the factory one had more chain play than I really wanted to see. I also got new upper and lower oil pressure sensors, knock sensor, coolant temp sensor, thermostat and gasket, EGR gasket, and an oil filter. ![]() New timing set installed! ![]() New front main seal, timing cover, and new water pump installed. ![]() Rear main seal, oil pan, and oil filter installed! ![]() I poured some oil in the pan and spun up the oil pump, and we have oil at the rockers! Installed the valve covers, harmonic balancer, and some of the new sensors. ![]() ![]() |
#28 |
#29 |
I like seeing the TBI getting all cleaned up. Looks good. It is the stock TBI water pump aluminum? It looks like it in the picture.
#30 |
Thanks! And no, they’re just regular cast iron. However, this is a “-P” water pump from Napa, which is supposedly higher flow and better internals than the typical stock replacement.
#31 |
I managed to nearly finish up the engine today! Finally got both of the correct oil sensors in from the parts store.
![]() I finished painting the rest of the accessory drive, as well as a few bolt on pieces. I also replaced all the belts. ![]() Finally, cleaned and rebuilt the throttle body as the last project for the night. ![]() |
#32 |
#33 |
Looking good. Nice work!
#34 |
Thank you!
Since the biggest portion of this project is looming near (swapping the cab over), I decided to use this weekend to repair the hole cut in the bed, since I won’t be able to access it once the cab is on. Started out by bending some metal as filler pieces. ![]() The hole I’m dealing with. ![]() Cleaned up the area. ![]() Cutout traced. ![]() Old material cut out. ![]() Started on the inside piece due to easier access from the front. ![]() ![]() Front piece welded in! ![]() Cleaning up the welds. ![]() Applied some primer. ![]() Not completely perfect, but far better than what was there! ![]() Also bolted the last of the accessories to the engine, the fan, dipstick, and motor mounts. ![]() Finally got around to painting the transmission as well! Primer applied ![]() Paint applied! ![]() ![]() And tape off! ![]() ![]() |
#35 |
![]() Join Date: Jan 2006
Nice work!! I see you invest in Brake Kleen like I do.
#36 |
It’s been on back order for months! I didn’t want to take another chance
#37 |
Sb 400 club
Old truck looks yo have some cool home bree 4x4 parts like front shackle mounts and crossover steering. Nice progress!
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#38 |
#39 |
#40 |
Nice progress, that's crazy about the filters,maybe I need to go buy 2 more just for my break in time .
#41 |
Thanks!
I started on the transfer case rebuild yesterday, and it turned into a disaster. ![]() First, I noticed large metal chunks everywhere with no real source. ![]() ![]() Found a shift fork partially worn through. ![]() Front output shaft thrust surface destroyed. Bearings were missing. ![]() Input shaft grooved, bearings weren’t removable. Looks like they had spun in the case as well. ![]() Synchro worn in an almost impossible way. ![]() So, this 208 is officially junk! ![]() I picked up another 208, dirty, but with low mileage for $50. These internals are much nicer! ![]() |
#42 |
Thanks for sharing the Pictures.
That is what I have in my 84. ,.../////
