02-23-2022, 09:17 AM | #26 |
Re: LS1 No start conditon
I would definitely be pulling the heads. Something is not right. It looks like your pushrods were way too long, but it seems unlikely they would be so long that it causes the valve to hit the piston.
Some timing gears have multiple marks. Did you by chance use the wrong mark? |
02-23-2022, 06:18 PM | #27 |
What a bummer. Maybe before expensive counselling sessions a few cold ones?
I hate to say it but I would pull the engine and check everything. I know its a major pain but then you will know for sure what you got engine wise. |
02-26-2022, 03:31 AM | #28 |
The motor started today. Like it should, touch the key and it's running.
Came down to two issues. The cam timing was way off. Sadly I can't contribute it to anything but bad eyesight. I replaced the push rods with new BTR hardened push rods. Rechecked the compression. All the cylinders were above 160psi. Put it all back together and it fired right off. Idled like a champ. My goal is to be able to drive it down the alley next week. Some minor things need to be addressed like a drivers seat. Thanks to everyone that gave encouragement and suggestions. Much appreciated. |
02-26-2022, 09:37 AM | #29 |
Congratulations. After all the trouble it must feel pretty good to hear it One.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
02-26-2022, 09:40 AM | #30 |
Good deal! Looking at those pushrods, my guess would be that if you had a good set of hardened pushrods and the timing was off, you might be replacing a lot of valves.
02-26-2022, 01:34 PM | #31 |
It sucks that you had so much trouble, but at least you got it going! Should be pretty smooth sailing from here on out.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-26-2022, 02:26 PM | #32 |
Excellent news! Thanks for the update.
02-26-2022, 09:56 PM | #33 | |
I wrote "Came down to two issues" but only listed one. Most would have figured it out if reading the complete post. The other was the defective harness. The one between the main motor harness and the coils. Purchased on Ebay and it was assembled backwards. (i.E. looking at the wrong side of the connector) The pins were reversed left to right. The plug at the coil end, only one row of pins there. It is so satisfying to here it run, only reaching in and touching the key. No mad pumping of the throttle required. On the other hand it was an eye opener, pun intended, on how bad my eyes are. And yes, I had my glasses on. Dam getting old is the pits but the "die young and leave a beautify corpse" option is already gone. LOL. Cheers. |
02-27-2022, 05:47 PM | #34 |
I had Laser surgery on both eyes about 2 years ago and it has been fantastic. No cheaters glasses unless the print is really small or the lighting is poor.
02-28-2022, 05:23 PM | #35 |
Wow wee! Dodged a pretty big bullet there! Those are the most bent pushrods I've ever seen with out some serious Head damage. Although those 243's would be nice on there.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-28-2022, 06:57 PM | #36 | |
Sign of the good mechanic "He stops right before he F' up". |
03-07-2022, 08:30 AM | #37 | |
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
03-07-2022, 02:25 PM | #38 |
Ebay is a good place to purchase China at it's worst. The eBay harness was a bargain at $29 for the pair. Purchase went to heck when I paid $250 for help to find the issue. The guy that converted the main harness found it, not me. I was looking at the incorrect side of the plug. Evidently the same issue the manufacture had. Turns out the builder could have made them for me! I never checked. He showed me where the plug was numbered, I didn't see that either. Iit was partially hidden under the weather pak silicon seal. Now I looking at everything with optics.
Good news is I have moved onto other things that need to be finished. Closing in on a running driving truck for this summer after two years of work. ECM still has a code for the electric fans as they are not connected. I am working on resolving that at the moment. I had two fans and two relays, one low temp and one high. I am going to change it to a three relay two fan set up. Might write that up in a separate thread. Cheers. |
03-07-2022, 02:48 PM | #39 |
Is the third relay for ac to kick the high speed fan on when in use?
03-07-2022, 02:55 PM | #40 | |
Works like this: Low temp computer ground, from the computer, runs both fans at 1/2 speed. High Temp from the computer runs both a full speed. Air Cond ground runs both at full speed. |
03-07-2022, 07:12 PM | #41 |
I would like to see the pin out on the relay and use this on my truck as well. Will be interested to see the post on it.
