06-16-2022, 03:39 PM | #26 |
Re: Lighting question
I'm thinking that this should be a far simpler solution and you might find a switch that you can get and make your own bracket if you want. This is as easy as it gets if you have a Hurst shifter or the directions should help you figure it out.
https://www.holley.com/products/driv...CABEgI3qfD_BwE
06-16-2022, 03:46 PM | #27 |
That is a great help. I'm taking my granddaughter out for a driving lesson right now, but will check later tonight to see if this solution works, or at worst gives me a great idea. Thank you.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
06-16-2022, 04:21 PM | #28 |
the brake light switch is usually activated by the brake pedal assembly under the steering column under the dash.
To adapt this switch ( https://www.summitracing.com/parts/aww-01998728 ) replace 2 side cover bolts with threaded rod and fasten a nut to keep cover plate tight. Then with the protruding threaded rod, place the switch plate on and secure with 2 more nuts. Then, make a rod (coat hanger) and attach to the reverse lever of the trans. I drilled a hole in mine and made a 'Z' shape in the rod to fit in the hole. (like a door latch rod in a door) Hope this helps.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
06-16-2022, 04:35 PM | #29 |
look for a saginaw 4 speed reverse light kit. These have been around for ever. fits Novas and so on.
installed it looks like this: since your shift levers are flipped over you may need to give it some thought. Some saginaw 4 speeds did have a reverse switch built into the side cover by the reverse lever. https://67-72chevytrucks.com/vboard/....php?p=8757378 |
