07-19-2022, 09:31 PM | #26 |
56 - autocross
Re: Battery Cable terminations?
Lots of great ideas. Take a look at this pic - how would you run the cable(s) to the starter from a rear-mounted battery? Kind of close to the headers.
07-19-2022, 10:11 PM | #27 | |
One thing I forgot to mention, I grounded every piece of frame piece to the chassis. (Radiator support, cab, engine, and bed.)
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
07-20-2022, 12:04 PM | #28 |
56 - autocross
Yep, I can run wires through the frame but not sure I want to - could weaken things a bit where it pierces. If I wanted to, are there any good grommets to do that?
07-20-2022, 01:00 PM | #29 |
If the passengers side mirrors the drivers side where the header is, I would use cushion clamps along the inside of the frame, then cross over with a twisted standoff bracket with clamp from one of the torque converter dust shield bolts, come along the starter solenoid and connect with a 90 degree terminal for the positive. For negative I would do the same but use a double stud for one of the bellhousing bolts and ground there instead of the standoff and forward. All that assumes that the exhaust is routed below them far enough to be OK.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-20-2022, 02:11 PM | #30 |
56 - autocross
Thanks for that option. I had to look up every piece that you suggested. I appreciate it.
07-20-2022, 04:03 PM | #31 | |
You could run it inside the frame, but I wouldn't. You cant see it and can't fully protect it if it shorts. You can get all manner of grommets from McMaster-Carr but if I had a custom box frame I wouldn't want to cut big holes in it either.
07-20-2022, 05:12 PM | #32 |
56 - autocross
MarkDTN - Thanks for your knowledge.
07-22-2022, 08:08 AM | #33 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
http://madelectrical.com/catalog/tm-1.shtml
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-22-2022, 10:48 AM | #34 | |
1-"Ford" solenoid is fine for a starter, but is not continuous rated. The kit doesn't use it that way, but somebody might try to use one to disconnect all power downstream. There are continuous rated solenoids available if somebody wants to do that. 2-I know there are a lot of people with remote batteries that rely on the frame for ground. I come from the heavy truck industry. They (and heavy equipment too) mostly pull a full size ground from battery to starter. Is it necessary? Maybe not, but starting performance is maximized. I would at least run a same size or 1 size smaller dedicated ground from battery to starter or block in addition to a frame ground. Ground wires are some of the most overlooked wires in automotive.
07-22-2022, 12:41 PM | #35 |
Post Whore
Are you planning on using a mid-plate to mount the engine? That will change your engineering.
How fast are you planning to cover the quarter mile? I won't deny running a separate ground to the starter has its positive points but, in a race car the weight of the 2nd cable would be the overriding factor in that decision. At least it has been on my cars.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 07-22-2022 at 03:02 PM. |
07-22-2022, 01:01 PM | #36 |
Grounding the battery to the frame, then the starter/engine block to the frame is the way to go. Consider how much metal is in your frame. Now consider even a large battery cable running the full distance from front to back. You need to consider voltage drop here. The frame will have less of it than the cable.
Actually making proper grounds is critical here. Clean metal, good quality star washers, and corrosion protection. |
