07-19-2022, 04:21 PM | #26 |
Re: Radiator search
C10 with LS swap. I did not use the stock mounts and rubbers. I made a different mounting system.
I think it might work with the stock 4 core mounts. |
07-19-2022, 04:54 PM | #27 |
Re: Radiator search
On my 68 C10 LS swap I used a Afco cross flow radiator. Biggest that would fit. Cross flow puts the inlet and outlet on the passenger side.
The Afco radiator has a "U" shaped channel top and bottom. On the bottom I fabbed a piece of aluminum that fit into the channel. Held it in place with 10-24 bolts. That piece I put three tapped 1/4" holes in using them to fasten the bottom of the radiator to the core support. On the top I fabbed a "U" shaped cover that fit over the top of the radiator and the used the stock 68 radiator brackets. I did mod the top brackets eliminating the stock shroud mounts. I'm not a fan of brackets welded to the radiator tanks. Single 16" Spal fan with no shroud. Never came close to over heating. Fan controlled by LS1 ECM. Pic of radiator. |
