09-03-2023, 08:41 PM | #26 |
Re: F/S GM NOS & New Repro Steering Column Replacement Parts
Good evening.
I’ll please take one of each of the following. Thx! #5 / Repro horn contact t/s cancel cam for non-tilt. $13. ***Qty. 1 Sold/Shipped*** Have 2 more on hand/available... #6 / Repro horn contact pin, spring & retainer kit. $7. ***Qty. 1 Sold/Shipped*** Have 2 more on hand/available... . |
09-03-2023, 09:00 PM | #27 | |
Always on the hunt...
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
09-04-2023, 10:45 AM | #28 |
Junior Member
Mel,
I am interested in a set of any NOS internal components that you still have for non tilt automatic steering column. Could you provide a list and $ for what you still have available? Thanks! Greg |
09-05-2023, 10:09 PM | #29 |
Hi Ed, your new repro t/s cancel cam & horn contact kit have been shipped off, the package went out via USPS Priority on Tue. 09/05 and your expected delivery day is this Thu. 09/07. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs. Mel
09-05-2023, 10:22 PM | #30 | |
Many thanks!
09-05-2023, 11:24 PM | #31 |
Hi Greg, to save a bit of time on our end let us know which wear parts you are chasing and I will reply back with availability and cost. Going off of memory for your column shift non-tilt steering column, we have the NOS upper & lower bearings, NOS lower bearing spacer mount, NOS lower bearing tension spring, NOS upper plastic and rubber bushings, NOS horn contact t/s cancel cam and the NOS turn signal switch and harness. Also pending confirmation of the actual year of steering column that you are working on, we may have the NOS shift indicator pointer, NOS shift indicator lens housing and both NOS chrome shift and turn levers. Let us know, Mel
09-06-2023, 09:43 AM | #32 |
Junior Member
Mel,
My column is for a 1972 k10 I will take: NOS upper & lower bearings NOS lower bearing tension spring NOS upper plastic and rubber bushings NOS horn contact t/s cancel cam NOS turn signal switch and harness NOS shift indicator lens housing NOS chrome shift levers NOS chrome turn lever Thanks, Greg |
09-07-2023, 02:42 PM | #33 |
Mel, you did it again. The parts arrived quickly and beautifully packaged. Amazon could learn a thing or two from you.
Thank you. |
09-08-2023, 07:22 AM | #34 |
Junior Member
Mel,
In addition to my list above, if you have a 4sp overdrive lens for the 72 column I will take one of those as well. Thank you, Greg |
09-08-2023, 12:00 PM | #35 |
****EDITED**** I'm after part number 3916047/474102
I'll take one of these, please, if available. #4 / NORS horn contact pin, spring & retainer kit. $20. ***Qty. 3 Sold/Shipped*** Have more on hand/available... Also, please let me know if you have a 3900514 upper spring for a tilt column. Thank you. |
09-08-2023, 01:28 PM | #36 | |
09-08-2023, 01:36 PM | #37 | |
Sounds great. I prefer OE on the 3900514 cam spring, if you've got it, but NOS will work, too. Thank you. |
09-11-2023, 04:21 PM | #38 |
In addition to this...
#4 / NORS horn contact pin, spring & retainer kit. $20. ***Qty. 3 Sold/Shipped*** Have more on hand/available... and this... OE (preferred) or NOS tilt column 3900514 cam spring I'm also looking for this: Clutch pedal push rod for a 2WD SBC Any chance you might have one? |
09-11-2023, 11:27 PM | #39 |
Yes, we do have some of the OE V-8 bell crank/z bar to pedal rods pulled/stored on the shelf, will check on availability/condition and grab you some pics when I get your other items pulled out. Mel
09-11-2023, 11:37 PM | #40 |
Thank you
09-12-2023, 03:58 AM | #41 |
I'm sorry I keep coming back with more stuff, but would you happen to have a bellcrank frame bracket for a 2WD SBC like the one below?
09-16-2023, 09:50 AM | #42 |
I’ll take the bulb cover and filter for the tilt column.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
09-16-2023, 11:59 PM | #43 |
Funds received and the OE used tilt column shift indicator dial lamp steel cap & plastic filter setup have been shipped off, your package went out via USPS ground advantage on Sat. 09/16 and the expected delivery day is Tue. 09/19. Thanks again for your order and let me know if we can help with any other 67-72 parts needs and/or column questions. Mel
09-17-2023, 01:07 AM | #44 |
I was able to source the clutch linkage parts locally. I'm still interested in the following two parts:
#4 / NORS horn contact pin, spring & retainer kit. $20. ***Qty. 3 Sold/Shipped*** Have more on hand/available... and this... OE (preferred) or NOS tilt column 3900514 cam spring |
09-17-2023, 12:54 PM | #45 |
Junior Member
Mel,
Any update on the column parts request? Thanks, Greg |
09-25-2023, 06:10 PM | #46 |
If it's alright with you, I'd like to pass on the following parts:
#4 / NORS horn contact pin, spring & retainer kit. $20. ***Qty. 3 Sold/Shipped*** Have more on hand/available... and this... OE (preferred) or NOS tilt column 3900514 cam spring I was able to find these parts elsewhere. |
09-26-2023, 08:43 AM | #47 |
Mel,
Do you have any of the green filters for the tilt shift indicator light? I already have the housing. I’m looking for two good ones.
Board Member #87725 My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=813848 |
02-26-2024, 04:20 AM | #48 |
New Member
Looking for optic holder socket that fits 69 GMC 1500.
02-28-2024, 04:21 PM | #49 |
New Member
Hello, I’m requesting the thread for the optic cable socket holders
