02-25-2024, 11:26 AM | #26 |
Carpe manana
Re: Help clarify harness adaptation existing HEI to OE points
Quick update. Yesterday I dropped in the OEM, rebuilt points distributor from Advanced Distributors. I think it’s clocked appropriately.
The internally regulated coil diameter is slightly larger than an OE example but fits in the OEM bracket although I had to use a #8 bolt and nut to secure it instead of the larger diameter original screw. If I get time today I’ll run the new plug wires.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-29-2024, 12:28 AM | #27 |
OK, so is it the IC12SB coil that one would use with the resistor and bypass wires?
02-29-2024, 04:56 PM | #28 |
Active Member
02-29-2024, 08:42 PM | #29 |
Well I think that is the one we just discussed using without resistor wire and without bypass wire.
03-03-2024, 08:40 PM | #30 |
Carpe manana
Adjusted the timing to 18 btdc and went on a brief drive. Idles smoother than ever and there’s no hesitation. Very pleased at the moment.
Thank you for all the help!
03-04-2024, 08:55 AM | #31 |
I had similar results when I switched the Pro Billet MSD distributor out for a correct distributor for my 1972 Cheyenne 402. The truck has a lot more pep and idled smoother.
The few downsides to points are the occasional rubbing block and contact wear. For as little as mine are driven, it will be years before they need a tune up. Using USA made old issue parts does make a difference, and also using the proper distributor cam lube.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-04-2024, 09:59 AM | #32 |
Carpe manana
I'm with you. For the amount of driving I'll do this is a good way to go in. In fact, I'm tempted to swap out the HEI in the K20 but that hasn't given me any issues. I will send another points distributor off for a rebuild and keep that on the spare parts shelf. Maybe that'll be a project for next winter. The builder made some advance curve and weight adjustments to this one and remarked that it will will perform better than the "truck distributor" GM supplied.
The USA made plug wires from Lectric Limited are a real nice product and are cut to match a 4wd 350 engine HERE. At least right now, it's not difficult to cobble together (nearly) all US made ignition products. There's a guy here in WI selling reproduced copper terminal caps and black D409-style rotors (rotor is in the above photo) both of which are solid. NOS/NORS examples can still be had too. The Echlin NAPA IC14 coil is made in Mexico and I did install it after returning the PRC-made IC14SB. I wasn't able to source a US coil.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 03-04-2024 at 10:14 AM. |
