Old 03-27-2024, 04:36 PM   #26
OKGMC4
OKGMC4's Avatar
Re: IMPOSTER! ( or hey guys I got a little jimmy!)
While I was at the salvage, I was geekin out about some of the stuff they had. A 65 Mustang, a 50s Mercedes, and this ultra cool International with aftermarket tool box fenders on the step side bed. Those would be cool on a Delmo style build.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-28-2024, 01:23 PM   #27
OKGMC4
OKGMC4's Avatar
This is the seat pattern I want to copy, just in a different color scheme. I've had this photo in my pc for years and years, I'm not even sure where it came from anymore.
Old 04-10-2024, 06:07 PM   #28
OKGMC4
OKGMC4's Avatar
Working on building a bed wall / cubby hole behind the seat. Could be a great place for the battery or subwoofers or who knows what. Also got one back inner fender notched around the tire and putting the tub back in. I had bad luck trying to make the 1.5” wide splice to fill the gap when I moved the tub in. I couldn’t get the bead line correct at all with the tools and skills I have. I looked and found Summit had a rear tub by AMD for $60. Sold! I trimmed it to fit all the way to the bed, cut the excess part off the bed wall, and started fitting the tub. The part I cut off I can use to patch the other side, although I almost want to get another cheap tub from Summit. Much much faster.
Old 04-25-2024, 06:51 PM   #29
OKGMC4
OKGMC4's Avatar
Splicing the other tub in.
Old 04-27-2024, 09:11 AM   #30
OKGMC4
OKGMC4's Avatar
Just hammer and dolly work now.
Old 04-27-2024, 09:59 AM   #31
raggedjim
raggedjim's Avatar
Nice! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-28-2024, 07:23 AM   #32
72 tigger
72 tigger's Avatar
You’re good at fabricating!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-28-2024, 11:01 AM   #33
jjzepplin
jjzepplin's Avatar
Awesome work! I am in!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-02-2024, 03:05 PM   #34
OKGMC4
OKGMC4's Avatar
Thanks for the kind words!
The dash will be body color, but not the door panels. In an effort to have the door meet the dash and flow together better, I used some 5/16 rod and some sheet metal to rework the lines.
Old 05-04-2024, 12:11 PM   #35
dec010974
dec010974's Avatar
Awesome.
"If I had your hands I would cut my hands off"
dec010974 is offline   Reply With Quote
