Old 05-22-2024, 11:08 PM   #26
57taskforce
All about them K’s
57taskforce's Avatar
Re: 72 K10 350 skips after warmup
Unfortunately this is a really common thing these days. I feel your pain. Dont fall for the temptation to just swap the cam and lifters again. All that metal is going to really bone you if you don’t tear it down and do a full rebuild, at this point the block, crank, rods, etc are likely still salvageable. If you don’t tear it down and clean it up that isn’t going to be the case.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 05-24-2024, 06:32 AM   #27
clyde72
Junior Member
yep, unfortunately this is it for this motor, I,m not using up any more hobby time on it, as I mentioned above I have a 5.3 Ls donor waiting, I just wanted to buy some time with the 350...ended up wasting time and $$ that could have gone into the LS.....
I will say part of me wanted to keep it original, but that parts gone now.
clyde72 is offline   Reply With Quote
Old 06-02-2024, 07:10 PM   #28
Dashman
Junior Member
Sorry that happened to you. Did you also change the cam bearings? Did you know if the oil passages were in alignment? Did you use a cam lube? The engine is not scrap because it has an oil pick up screen and a filter.
Dashman is offline   Reply With Quote
Old 06-02-2024, 10:25 PM   #29
Accelo
Accelo's Avatar
I suggest never rebuilding any motor without retrofitting it over to rollers. Just not worth the hassles of doing it twice. I have heard all kinds of reasons for the cam failures. The cause doesn't matter. Only think you need to know the cam/lifters will fail.
Helped my friend with the same issue. Difficult to impossible to get all the debris out of the motor without a complete teardown and hot tank with new bearings.
I have changed my thought to; Go roller or go home.
Accelo is offline   Reply With Quote
Old 06-10-2024, 08:26 PM   #30
clyde72
Junior Member
just an update.. dont judge, I know its not the right move ...but, considering I have another motor waiting and doing another cam would be a bad idea due to the metal in the motor and the possibility of something similar happening, and I really, really, did not want to do what i just finished or rebuild it I said wtf, the next bolts to come out of this motor are the motor mounts when I throw it away.. we had/have a couple vintage camper rallies planned for the summer which is why I wanted it running, sooo, I poured some cheap 10/30 down the valley with the drain plug out, i then assembly lubed up an old lifter and dropped it in the hole. filled it with more cheap 10 /30, started it, shut it off after 30 seconds and changed the oil/filter to 20/50 race oil with a quart of Lucas gooey stuff, its running on 8, towed the 4000 lb camper to a rally in Maine and back, 400 miles, did as good as any other tree fiddy Ive had in the past.. 800 miles so far and no skip or ticking or loss of oil pressure, Ill have to say I`m going to get my summer out of it ... at this point if it eats another lifter Ill take the pushrod out and snug up the rocker and run `er on seven..the old 350 is a fighter.
Old 06-10-2024, 09:22 PM   #31
dmjlambert
dmjlambert's Avatar
I judge you made the right move. :-)
This thread has been interesting to watch. Let us know how it goes over the rest of the summer!
dmjlambert is offline   Reply With Quote
Old 06-11-2024, 08:32 AM   #32
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: 72 K10 350 skips after warmup
I'd done the same thing at this point.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 06-11-2024, 07:06 PM   #33
clyde72
Junior Member
Loaded up and headed for Maine with our ‘74 Shasta
