Old 05-17-2024, 03:24 PM   #26
72SB
Re: Recommended carb for std 350ci v8?
Originally Posted by wrangler94 View Post
If that doesn't work, and I buy the 1406 Edelbrock, do I need adapter plates or anything like that? Custom stuff to work with transmission, throttle linkage, etc? Just planning ahead in case going through this carb a second time doesn't reveal anything.
the 1406 is a square bore carb so if you have a Qjet manifold, you will need an adapter (IIRC # 2696). Edelbrock makes a variety of throttle linkage adapters and kick down cable adapters if you need them.
72SB is offline   Reply With Quote
