03-16-2016, 12:48 PM | #476 |
Re: Let's see some 73-87 1 Ton Dually Pictures!
05-03-2016, 05:49 PM | #477 |
Here's mine - 1988 Crew Dually with a 454 and SM465 3 speed plus granny!
05-03-2016, 05:53 PM | #478 |
And after lowering it with 3" spindles and 1 coil cut off in the front, and 4" shackle/hanger drop in the rear:
05-03-2016, 06:13 PM | #479 |
Looks good.
05-03-2016, 10:24 PM | #480 |
05-04-2016, 06:11 PM | #481 |
05-04-2016, 06:22 PM | #482 |
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
05-04-2016, 06:54 PM | #483 | |
So far static drop only. Belltech all around. In the front I also had to go to a smaller tire 'cause it would rub the fenders pretty bad (from 235/85 16 to 225/75 16) still rubs a little, but not too often. I should probably get heavy duty 1" drop springs for the front... The rear didn't really drop that much (no C-notch - at least not yet...), those crazy thick spring packs won't allow. My spring packs are 10+1, and I believe they are usually 8+1? (Rough ride!) I would like to maybe get some air bags in the back... Just didn't want to lose the 1 ton capability. I have also been looking at the possibility of a 4 link suspension kit for the rear - but they seem to come a bit high on the prices... Oh, also. I kept the old shocks all around. Seemed to work fine... |
05-04-2016, 07:20 PM | #484 |
05-04-2016, 07:22 PM | #485 | |
I'd love to find an 87 or 88 single cab dually 4x4. My CC is sweet but I have a soft spot for single cab squares
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 Last edited by Chevy3+3; 05-04-2016 at 07:29 PM. |
05-04-2016, 09:35 PM | #486 |
05-04-2016, 10:10 PM | #487 |
Some of you have probably already seen my truck, but I used to look at this set of pages for inspiration while building mine. Still have a long way to go, but so far so good I think.
05-05-2016, 08:00 AM | #488 |
yea that is super tough,love the semi wheels,been trying to locate some frito lay 19.5s for mine but hard to find
07-21-2016, 01:32 AM | #489 |
1987 M1028A2 found up in the high desert. Added the lift and tires with a fresh coat of paint. Fixed the trans and it gets daily driven.
07-21-2016, 07:23 AM | #490 |
07-21-2016, 07:52 AM | #491 |
07-21-2016, 08:15 AM | #492 |
That M1028A2 is awesome
Here is my Crew dually I picked up a few weekes ago.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
07-22-2016, 01:13 PM | #493 |
My 88 Crew Dually.
07-23-2016, 04:14 PM | #494 |
"DON'T TOUCH THE TRIM!!"-Early Kyler |
07-28-2016, 01:37 PM | #495 |
My 1985 454 Dually
Member # 286 1975 Trans Am 1986 GMC Wrangler 4X4 1985 Silverado K30 Dually 2016 Skidoo Renegade XRS 800 2016 Yamaha Grizzly 700 |
07-28-2016, 03:16 PM | #496 |
My 89. Still sorting through the last small details but I've got about 3k miles on it w/o any issues except for the first few weeks on the road....
07-29-2016, 05:39 AM | #497 |
here are some pics of mine.
Its an 81 K30 Dually 4x4 with the 454 BB |
08-02-2016, 07:22 PM | #498 |
TecRsq _____________ 1986 Chevy K30 3+3, 454, SM465, NP205, D60 , 14 Bolt, CM Industries SS Flatbed, ORD 6" suspension, 9.00 x 16 Michelin XML'S |
08-02-2016, 08:10 PM | #499 |
Nice rig TecRsq!!!
08-02-2016, 09:05 PM | #500 |
Much thanks, just got the suspension and tires on. Toyed with going SRW and had a set of wheels/ tires on it, but I just couldn't bear to cut the original fenders for clearance and decided to leave it as my old K30 was, as a dually.
Next on list are a full exhaust replacement and a big winch.
