02-01-2015, 12:28 AM | #476 |
Re: Restoring Rusty
Wow...what a day!
02-01-2015, 12:38 AM | #477 |
Re: Restoring Rusty
I may have missed if you posted already, but what brand were the leaky gaskets?
I have found that ALL the gaskets I used from a certain gasket-named company was less than spectacular. Never had a problem with Felpro.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-01-2015, 03:27 AM | #478 | |
Post Whore
Re: Restoring Rusty
That's the good news, the bad news is that now I know I am almost out of gas, LOL, so tomorrow I will put about 5 gallons in and see if the needle moves accordingly. |
02-01-2015, 03:29 AM | #479 | |
Post Whore
Re: Restoring Rusty
02-01-2015, 03:31 AM | #480 |
Post Whore
Re: Restoring Rusty
02-01-2015, 03:33 AM | #481 |
Post Whore
Re: Restoring Rusty
02-01-2015, 03:39 AM | #482 | |
Post Whore
Re: Restoring Rusty
The first was from Mr Gasket valve cover gaskets that just did not fit properly inside my stock valve covers. I don't think there was anything defective in them they just did not mate well with my valve covers. I replaced them with cheapie cork Felpro gaskets that fit like a glove and so far no leaks. The second leak was with a Felpro intake manifold gasket that was either the wrong one to marry an aluminum intake manifold with a cast iron cyliner head / block, or simply not installed properly by me. I replaced it with a different Felpro gasket and problem solved. I don't think its that black and white where one manufacturer simply makes junk whilst another always shines. I believe there are just too many factors. One being guys not knowing how to use the products properly or deliberately cutting corners, etc. Another factor being using the wrong gasket/part for the application either intentionally to save money or by mistake. I like Felpro too, as they always provide you with instructions. |
02-01-2015, 04:44 AM | #483 | |
Re: Restoring Rusty
02-01-2015, 11:28 AM | #484 | |
Post Whore
Re: Restoring Rusty
There is really no trick, the pink wire has nothing to do with the fuel gauge, it is for the ignition/distributor. It was simply happenstance that when I was messing with the wire harness box on the firewall that I moved or wiggled something that made the brown fuel gauge wire happy. |
02-01-2015, 12:15 PM | #485 |
Re: Restoring Rusty
Greg, that's great that the fuel gauge started working again. If you're looking for something to do (ya right), you might want to pop that firewall connector block apart again, and clean all the contacts as best as you can on both sides. Unreliable wiring is no fun at all. I think a nail file will fit in there and clean crud off the female side. Emery cloth with small pliers should work on the male side. I think that's how I cleaned mine.
By the way, good on you to realize that ignition wire was resistance wire. It would have hurt the performance of the HEI if that were still there. when the engine is running, check that you have alternator voltage at the ignition coil. Should be 14.4V with your new wire. I was never sure on the early trucks if that resistance wire ended at the firewall, or if it went under the dash back to the ignition switch.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
02-01-2015, 01:19 PM | #486 |
Re: Restoring Rusty
Oh oh oh. I forgot you had a points system. Either way I got some courage from the discussion. While I've got my engine out and cleaning up the firewall I should probably checkout the wiring harness block.
Thanks Greg and Greg. |
02-01-2015, 05:50 PM | #487 |
Re: Restoring Rusty
Nice job, glad to see you got it running!
1983 GMC SWB - 350, TH-400 2002 Camaro SS - 408 9sec street car 2000 Trans Am - H/C/I 2014 Chevy Z71 |
02-02-2015, 10:02 PM | #488 |
Second Chance Program
Re: Restoring Rusty
I hate setbacks like that! But good that you got it going!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
02-02-2015, 10:08 PM | #489 |
Post Whore
Re: Restoring Rusty
02-02-2015, 10:09 PM | #490 |
Post Whore
Re: Restoring Rusty
kinda strange coming home and not having a Summit package waiting on you, what nothing honey, not even a measly throttle bracket, LOL, jk
02-02-2015, 10:15 PM | #491 |
Post Whore
Re: Restoring Rusty
I just got paid today,
got me a pocket full of change. Said, I just got paid today, got me a pocket full of change. If you believe like workin' on yer truck all day, just step in my shoes and take my pay. so with tens of dollars in the bank account I am on the fence on what to do next, I got two options: 1. Wrap up Phase II of Engine Upgrade with the long tube headers by buying an X pipe exhaust kit 2. Buy a gauge cluster with a tachometer and take a break from engine work. Drive the truck the way it is for a month or so cause and reap the rewards of your hard labor. |
02-02-2015, 10:23 PM | #492 |
Post Whore
Re: Restoring Rusty - The Door Panels
I know - I'll screw around with the door panels
Justification = I only got one key. One key period, and that's the ignition key, I aint got any door keys so I am not locking the truck at night (but don't get any ideas my pitbull sleeps in it at night for realz) The Plan: Get a door cylinder lock out and take it to a lock smith fer some keys to be made Last edited by Gregski; 02-02-2015 at 10:37 PM. |
02-02-2015, 10:35 PM | #493 |
Post Whore
Re: Restoring Rusty
absolutely love working on this truck, now I've had some love / hate relationships with my vehicles [I'm looking at you my '85 2.8 Liter piece of ______ Blazer] but me and Rusty are still in the Honeymoon (don't fart around each other phase)
seriously a door panel held on with four philips screws, I mean who does that any more (they all use those forsaken clips that brake and make you cut your hands up, and scratch the panels or the paint and I wanna see you BMW owners wash your electronic everything door panels on the front lawn with a garden hose |
02-02-2015, 10:45 PM | #494 |
Re: Restoring Rusty
Greg, I bought an ignition and door lock set, all keyed alike for cheap.
http://www.classicparts.com/1973-78-.../#.VNA2IpU5CM8 |
02-02-2015, 10:45 PM | #495 |
Post Whore
Re: Restoring Rusty - Door Lock Cylinder
ah there it is, the Money Shot, our crown jewel, we don't need no Mobile Lock Smith, we'll take this baby in tomorrow at lunch time and get us some keys
super easy to remove too Door Lock Cylinder 1 - - - Cuts On Hands 0 |
02-02-2015, 10:57 PM | #496 |
Post Whore
Re: Restoring Rusty
what's that?
Am I going to take the door panel off the other side or risk having the world be off balance? Shoot you guys know me too well. I am a Gemini after all so here we go, how hard could it be? Last edited by Gregski; 02-02-2015 at 11:08 PM. |
02-02-2015, 11:01 PM | #497 | |
Post Whore
Re: Restoring Rusty
02-02-2015, 11:06 PM | #498 |
Post Whore
Re: Restoring Rusty
sometimes when Rusty fights me like that I feel he's like a stray dog that lived a hard life before you found him and now he just don't know how good he has it, and he don't know to trust you yet
but how in the heck did that door handle rust so bad, it's on the inside of the cab for crying out loud, and it's made out of foam, LOL |
02-02-2015, 11:30 PM | #499 |
Re: Restoring Rusty
Gregski:
Sorry I'm so slow with this. You're moving fast and I've been busy. Two notes on what I saw in my catching up: 1) Hook up a PCV valve on one side and a breather on the other. Two reasons. First reason: with nothing to pull all of the blow-by out of the crankcase, a lot of it sits in there, just a smoky, sooty environment, and when you turn off the engine, it condenses/settles in your crankcase and under your valve covers. This is where a lot of engine sludge comes from. Second reason: when the engine warms up, it pushes air out the breathers, and when it cools down, it pulls air back. Sometimes that air being pulled back in is humid air. Which condenses in your oil. Which puts water where oil wants to be. With PVC, the carb pulls the blow-by out, therefore no sludge, and it also pulls out the condensation the next time the oil warms up and the water evaporates. If you ever rebuilt an engine with 100,000 miles, the difference between whether it had PCV or not is not subtle. One is pretty clean internally, and the other is absolutely filthy. Looks like somebody dumped a couple pounds of crap in there. And with internal rust as well. 2) Looks like you have the vacuum advance hooked to timed vacuum, up on the side of the carb. That's pollution nonsense. I remember when it was introduced in 1968 together with AIR pumps and cats and all. The previous 30 years vac advance was always connected to full manifold vacuum. So hook the vac advance to full manifold vacuum. It's down underneath in the front by the PCV port (see Fig 7 on Page 7 of your carb instructions here: http://documents.holley.com/199r10331rev2.pdf). This will give you advance at idle (which you should have), and will allow a leaner mix at idle and keep the carb in the idle circuit at idle. You THINK it idles nice now. Move the advance line and you will see how good it can be. Nice progress. Jeez, I turn around, do a consulting assignment or two, and you are way down the road.
Rich Weyand 1978 K10 RCSB DD. |
02-02-2015, 11:32 PM | #500 |
Re: Restoring Rusty
Love your thread update style!
