Old 12-02-2019, 10:06 AM   #476
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I'm interested to see what wires you're running through your AAW bulkhead. I know I have several empty slots in my bulkhead but never gave it any thought to use those empty spots.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 12-02-2019, 10:50 AM   #477
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Honestly I'm probably total around 6-8 hours. I enjoy this kind of thing. But I take breaks and go do something else or else it gets monotonous. Hopefully by next weekend I will be installing the harness and routing wires...
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-03-2019, 01:20 AM   #478
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Updates - Remote battery box and Firewall bulkhead
I got my battery box mounted. I ended up drilling and taping the frame so I didn't have to use nuts on backside. Probably do the same for the main electrical circuit breaker and starter solenoid.
Also got my new American Autowire bulkhead cut out. Didn't get a picture yet but mounting holes are drilled and I bought bolts with locknuts for the bulkhead fasteners. Didn't like the idea of the 2 large screws sticking out of the firewall....
Measurement with box in the up position:
Measurement with the box in the lowered position:
I used the template on the outside of firewall rather than the inside. The template would not have stuck to my inner firewall with the lizard skin. It worked just fine using a body saw to cut it out. Then I took a die grinder and smoothed out the edges. sprayed a little paint on the bare metal edges.
"It's only money".
Old 12-03-2019, 01:35 AM   #479
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Also mocking up my radiator. So far looking good.
Had to bend the core support lip at bottom to get the heavy duty rad pads to fit. I hear that's normal. Just used a crescent wrench.
Also had to modify the rubber pads, they were a little too thick and radiator wasn't fitting. Just a little razor blade work and she fits just fine now.
2 bottom pads:
Top pads:
"It's only money".
Old 12-03-2019, 10:58 AM   #480
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
What radiator did you end up going with? It's definitely thicker than mine and has bigger fans.
Old 12-03-2019, 08:23 PM   #481
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I like it having both inlet and outlet in the same side as water pump. The fans are gonna kick azz too
My radiator info:
Brand = Superior Radiator
Fans = 3800 CFM
Steam Port = Yes
Auto Trans Cooler = Yes
https://www.ebay.com/itm/67-68-69-70...EAAOSwlndZJXTJ
"It's only money".
Old 12-04-2019, 10:07 AM   #482
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
There are so many more radiator options out there that I don't even know about. Those fans will move some air for sure! Mine probably move half that. We'll see how it cools things; I may upgrade the fans before long.
Old 12-04-2019, 11:29 AM   #483
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
There really are so many to choose from these days. This one was made in USA, checked all my boxes on what I wanted for features, and it cost half of what the big names cost....
"It's only money".
Old 12-04-2019, 12:09 PM   #484
cornerstone
cornerstone's Avatar
Re: TA_C10: Stage 1
The link for the radiator isn't working for me. What did it cost you?
Edit: Their website shows $550 with the fans.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 12-04-2019, 12:47 PM   #485
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Ebay listing is gone, I was hoping it would redirect you to the new item each time he relists it. Here is their official website. https://www.wwwsuperiorradiator.com
I got mine for $495. If you search ebay with the search term "superior radiator c10" you will see the correct item with lowered price.
"It's only money".
Old 12-06-2019, 05:13 PM   #486
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - PDU Panel
I needed a power distribution panel after relocating my battery to frame and all the new LS wiring/ECM. I first saw this design on the Hulk build if I remember right. Now I see many others using the same design with good results so I'm not re-inventing the wheel here.
I planned to install the TAC module on the backside as you can see here, dotted lines. Everything else on the front. Wires will go through grommets that will route through the backside of the panel. However this isn't set in stone, If my plans are correct, I should have enough vacancy after re-working the new AAW harness to put the 9 TAC wires through the firewall bulkhead. If not, then I have to drill a hole and grommet them through the firewall elsewhere so I may as well mount the TAC under the dash if that is the case.
I have the Dakota Digital BIM module and i'm having trouble figuring out if my 2003 ECM will supply Oil, Water Temp, TACH, and SPEEDO properly. If they don't, I will have to run those wires... We shall see.
I cut my panel out of 16awg steel. I made 2 tabs left side, and drilled holes in the pillar of core support on the right. Then an afterthought came that I wanted to weld nuts on the backside of all 4 holes for easy maintenance. So the tabs on left were open and easy. But pillar on right I had to come up with a solution while keeping my existing holes I drilled.
So I made these little plates, drilled a hole in them, tack welded nuts to the backside.
Then I drilled 2 holes on either side of my preexisting mounting holes, used a long 1/4 inch threaded rod to hold the new nut plates in place while I spot welded them in place. Worked pretty good.
Here they are done and painted.
Here is my final mock-up, SS 1/4 x 20 button head allen bolts, the 2 on the bottom are extra long, 2 on top are short, remove the top bolts, and back out the bottom bolts most of the way and the panel becomes very easy to access backside.
"It's only money".
Old 12-06-2019, 07:57 PM   #487
cornerstone
Re: TA_C10: Stage 1
Now that is slick! Excellent idea allowing it to tilt and give you access to the back of the plate. Carry on, I'm taking notes...
Brian
Old 12-07-2019, 08:11 PM   #488
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks man, I thing it will work out, we shall see.
"It's only money".
Old 12-07-2019, 08:12 PM   #489
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - PDU coming together
I pretty well got my PDU setup. Just have a few more things to do, paint, and final mounting and its complete.
I changed my original plan and relocated everything. I started by mounting the ECM, I bought threaded spacers and rubber washers for this. I ended up re-taping the ecm holes this way the threaded spacers will hold tight the lid of the ECM together. May be overkill, but if I ever take it off for maintenance I wont have to worry about the lid popping off.
I made provisions for a second fuse box at the top. There should be plenty of room to get into both of them for maint. I also staggered the POS and NEG terminals at the bottom so the big 2awg connections don't interfere with each other.
On the back I mounted my TAC. I should be able to lengthen the cables and terminate the wires through the firewall bulkhead, including the 4 cruise control wires and a couple others. I also mounted a positive distribution block for all my KEY + connections. I will also be mounting another distribution block that I plan to use for all the other connections, like all the fuse block wiring, I plan to cut those wires and run them to the distribution block on back side, then I will terminate the other ends as well that run either back to the engine harness or to the firewall bulkhead. This will make it super easy for me to disconnect the whole PDU if needed and feeding wires will be easier too.
Last thing I will need to drill larger diameter holes and install grommets to feed all the wires through the back so they will be hidden behind the panel and organinzed on the distribution blocks.
Pics of where I stand today.
Here you can see I ended up cutting 1/2" holes to accomodate the welded nuts on back of panel so they PDU plate sits flush against the core support.
"It's only money".
Old 12-08-2019, 08:13 PM   #490
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - A/C condenser and core support done
I spent the time today getting everything mocked up for the core support. I ripped it all back off. Removed the core support and my PDU panel. I hung them, scuffed them, painted them. Done. Put it all back together.
"It's only money".
Old 12-09-2019, 01:30 AM   #491
cornerstone
Re: TA_C10: Stage 1
Clean and speedy work, as usual!
Pardon my ignorance, tell me about the terminals that you fit into the PDU panel please. Is that where you will attach anything else needing power? Are they there in case you need a jump start?
Brian
Brian
Old 12-09-2019, 11:46 AM   #492
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Looks great man! What kind of fuse/relay blocks are those? And where are you mounting the American Autowire mega fuse assembly? I mounted mine on the driver side core support.
Old 12-09-2019, 05:31 PM   #493
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Brian
Thanks! Those 2 red and black distribution blocks facing the engine side(under the fuse blocks), are going to be my main power distribution blocks. I have plans to terminate battery hot and negative to those distribution blocks. Then all battery + connections will feed out from there. Essentially, that's my battery terminals.
The red distribution block on the back side of the PDU panel however will be all my Key + coming from the ignition switch. So from the firewall bulkhead the pin Key+ will connect to the main terminal and all subsequent terminals will they feed any other Key+ connections from there like my engine harness, fuel pump, etc.
I have more updates coming soon that will explain my wiring in better detail. Here is a pic of my plans for power distribution from remote battery. On the passenger side core support I am connecting 2 poles that will be remote battery jump terminals.
"It's only money".
Old 12-09-2019, 05:36 PM   #494
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
The fuse/relay blocks came from amazon. If I knew I was going to be adding the 3 relay fans, 2 relay headlights, fuel pump, engine harness relay, and etc then I would have bought a much larger single fuse/relay distribution block....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And I am not planning on using the supplied mega fuse. If that thing ever gets burnt(used) then it's a 1 time only deal and I won't be able to limp home. So instead I am using a 200amp circuit breaker located close to the battery on the frame. (See my diagram in last post of power distribution. It's a little outdated, it says 150amp CB but I got a 200amp instead) This will kick and allow me to fix the issue on side of road(if I ever need to) and limp home. Most likely this would be a larger issue but it's possible I could disconnect a shorting wire completely, hit the reset on CB and limp home.
"It's only money".
Old 12-11-2019, 10:26 AM   #495
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I just stuck this up here for mockup but here are the jump terminals I'm gonna mount. Somewhere in this area. I just need to figure out how to mount them and where exactly. I'm thinking of mounting them tucked under the top of the core support so they barely show. 1/0 awg battery cables will be connected straight from the battery and then my PDU will be powered from these.
"It's only money".
Old 12-12-2019, 01:46 PM   #496
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
CRAP!! Another setback on my Power Distribution.... I'm so thankful for this forum and its members. Another member brought to my attention that if I used those jump terminals the way I have it setup in my wiring diagram above(see post 493) that it's going through my circuit breaker and it would most likely pop when i cranked the engine because all the power would be coming from the jump battery not mine....
So now I either need to put my jump terminals on the frame next to battery or run ANOTHER power wire up the frame rail. Or I could move the CB in front of the jump terminals but I don't want to do this because it leaves a whole lot of big wire vulnerable to melting without protection.
So here is what i'm thinking below. I also removed the fuseable link between ALT and PDU panel.
"It's only money".
Old 12-16-2019, 02:05 PM   #497
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Updates -
Didn't like how bent up my old PS pump return line was so I got a new one. Probably for the best. I went through several pumps at the local parts store before I found the one I liked. Ended up going with a 2005 Silverado pump. It had the best angle for return line to end up above the frame rail. It also had the right studs on back for L shaped mounting bracket.
I ordered the Holley extended replacement high pressure fitting. It converts to A/N. Very nice piece. Then I got 2 A/N adapters for the steering gear. I am using Earls PowerFlex hose that is PTFE and 2500lbs pressure rating. I also got the ptfe A/N 90 degree fittings for everything. All of this worked well except the return line to pump. I may need to find a different style braided line to fit that as it's too small to fit over the barb on return line fitting at the pump side.
Moving on to wiring... I just couldn't get past the issues the circuit breaker was giving me. I ended up deciding to go with the American Autowire double max fuse setup instead. It's 2 175amp fuses with a single battery connection. So it will be fed with a single 1/0 awg battery lead, then one fuse goes to the alternator directly, the other fuse feeds the PDU panel. I mounted it on the passenger side frame rail just under the driver seat area. Then I also decided to grab a remote battery cutoff switch. I wanted this for theft "deterrent" mainly. I got rid of the remote solenoid because I measured out the differnt in length and turns out there is only about a foot difference in length battery cable vs the original wiring with battery on driver side core support.(length from battery to starter that is).
This new diagram is my 5th rendering and I think it will be the last one hopefully
I started making battery cables and ended up springing for a battery cable crimp tool(hammer style). It works much better than expected and I highly recommend this tool.
Here is the double max fuse from AA I mounted on the driver frame rail under cab. This setup really helps to minimize my wiring and it's designed by AA so rather than trying to reinvent the wheel.....
Last I also figured out a great place to mount my jump studs. I really didn't want them mounted on the frame rail. The idea is to make it easy to jump under the hood like normal. This should work out nicely. I will have a 2awg power wired direct to battery. The ground will go through the engine mount.
I took the corner piece that mounts the core support to fender and welded nuts to the bottom of that. I didn't want the nuts on top of the piece to interfere with fender and core support mounting. I will have a stud that screws into the plate nuts and will have another set of nuts that secure it to the stud.
Here are some of the battery cables installed.
Alternator power wire.
I got my inner fenders mocked up, heater hoses connected, and upper and lower radiator hoses installed. I got 1996 jeep grand Cherokee hoses and cut to fit. Also got my serpentine belt installed. 114.2 length with qik mount from Vintage Air. hopefully it doesn't squeel like others have had. It fit perfect.
Upper
Lower
Heater hoses with control valve installed.
And here is a little motivation for myself.
"It's only money".
Old 12-16-2019, 03:59 PM   #498
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Looks great dude! Let us know how the Kwik mount setup works. I've been debating as to whether to go the high mount route or go low.
Old 12-16-2019, 04:23 PM   #499
cornerstone
Re: TA_C10: Stage 1
Just when I think you must be taking a break, you come out with a big ol productive post. Your battery cables really look fantastic man, maybe when I’m ready I can cut all of mine to length and swing by your place for a professional looking crimp job!? I love the jump studs location! It looks like it was meant to be. I’ll probably be “borrowing” that idea.
I was a little concerned about your wiring hanging too low and being in the way of the inner fender on the driver side. How did that work out? If it’s too tight do you have any room to slide the computer up enough to gain the clearance needed?
You’re killin it man, keeping me inspired and chompin’ at the bit to get back on my truck. On Thanksgiving Day our oven crapped out for good, so naturally a full remodel is in order. I’ve got it gutted now and starting back with new tile, sheet rock, counters and granite tops, etc... So close but so far!
Brian
Brian
Old 12-16-2019, 06:50 PM   #500
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I have to say the belt was perfect, just the right amount of tension it looked like to me. The tensioner is right in the middle of its travel. But, we shall know soon enough when I fire this thing up again.
Brian
Sure thing man, come on by and you can terminate those cables man.
And yeah, I did run into an issue but it's not killer, the wiring below the PCM fits pretty good, but its hiding my mounting screw that hooks to core support lol. I have the nuts welded on the back side of the tabs I welded to the core support. The bolt then goes through the panel from the front. So what I will do on just that one bolt is cut the welded nut off the tab, and I will use a loose nut that I can simply screw off from backside. It worked out because of the L shape hole I left to gain access to the headlight so no prob, I can just reach down there and unscrew the nut on back instead of unscrewing the bolt from front.
Dude kitchen remodeling is awesome, but it's also time consuming and lots o cash so I get it man Happy wife.....Happy life.
"It's only money".
