07-23-2021, 01:55 AM | #4976 |
Re: What did you do with your truck today, Part 3
Man I'd love to do this. I've done quite a bit of searching locally for a used T5 in my area and have failed. I assume you bought a rebuilt unit?
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
07-24-2021, 08:32 AM | #4977 |
On it's tires, first time
Sitting on it's own tires and wheels for the first time! I like the stance, the wheels look perfect, it is full of fluid and ready for the first test drive but.......................When I tried to shift out of park today, there was no connection to the shift rod. I knew it could happen when I took the el cheapo path to obtaining a short steering column. These steering columns, made by Saginaw and shared by GM and Chrysler, can be shortened easily by just applying enough force to collapse the column to the desired length. The problem is internal, the shift connection between the shift lever and the tab that connects to the trans is two tubes that are locked together by nylon tabs that break when shortened. Tomorrow I'll pull the column, try to locate the hidden connection point, cut a slot and mig weld the two tubes together. Anyway, here it is
07-24-2021, 10:48 AM | #4978 | |
Re: On it's tires, first time
07-25-2021, 06:38 PM | #4979 |
The distance in the cab from my chest to the firewall where the steering goes through is much shorter than the car that the column came out of. I didn't want to pay $$$$ for a short column so I just shortened mine, Bob
07-25-2021, 06:41 PM | #4980 |
Bought the wood for the bed (Ash) and getting ready to mill it and test install. Have not posted for a while, have been in paint primer blocking mode, just when I think I am done I find something I am not happy with.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-25-2021, 10:46 PM | #4981 |
Welocme back OrrieG!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
07-26-2021, 10:50 PM | #4982 |
I got my water pump pulley that I altered back from powder coating today. $20 to strip and coat the pulley and spacer. I dropped it off Friday about noon. This started it's life as a reverse rotation Ford pulley and I redeemed it. This completes my accessory drive. My P/S and A/C is all electric. He did a really nice job. I shaved down the spacer, countersunk the bolts and grooved it for the 8 rib belt. Thank you for your time.
07-27-2021, 05:38 AM | #4983 | |
07-27-2021, 09:17 AM | #4984 |
LOL, I just finished putting up about 50 feet of 4 foot shelving so I should be good. Also a customer of mine bought me all new really nice commercial LED lights for the shop.
07-27-2021, 10:53 PM | #4985 |
I like the way you fitted the lift thru the ceiling of the garage. Unfortunately if I did that my wife wouldnt like the lift sticking up into the family room.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
07-27-2021, 11:14 PM | #4986 |
I don't know... maybe you could make the top of it into a coffee table.
07-28-2021, 08:10 AM | #4987 |
Now that's just funny.
07-28-2021, 09:28 AM | #4988 |
that might work.
07-28-2021, 08:25 PM | #4989 |
Years ago a friend used an ongoing SBC build as a coffee table. He lived in an apartment so had no real workspace. He'd assemble a little of the engine as he had money and time then he'd put a piece of glass on top of the engine when he was finished.
07-28-2021, 11:09 PM | #4990 |
I almost got a lamborghini 12 cyl at an auction. my plan was to use it as a coffee table with a glass top. unfortunatly that didnt work out
07-29-2021, 11:25 AM | #4991 |
That would have been a cool table!
07-29-2021, 11:26 AM | #4992 |
Duplicate post!
07-29-2021, 01:07 PM | #4993 |
Mick raises the bar a few notches when it comes to detailing an engine out.
07-29-2021, 01:14 PM | #4994 |
07-29-2021, 02:38 PM | #4995 |
I thought about putting this under my glass coffee table.
Hey, that would look OK on Mick's block (as long as it was at my house and not his)!
08-01-2021, 01:06 PM | #4996 |
Fired it up and drove it up and down HWY 101 along the beach. With all this fauxvid bovine excrement i had forgotten how much enjoyment can be derived from driving it. Did not realize how fast the thing was and how good the sea air smells!!
08-01-2021, 01:12 PM | #4997 |
Fired it up and drove it up and down HWY 101 along the beach. Bright sunny morning with the waves crashing in on beach . With all this fauxvid bovine excrement i had forgotten how much enjoyment can be derived from driving it. Did not realize how fast the thing was and how good the sea air smells!! Keep plugging on your builds and remember there's memories to be made.
08-01-2021, 01:57 PM | #4998 |
Todays project is to remove the back window from the cab. A few years ago my wife bought me a sliding rear window. I finally found an old school glass guy who will install it for me on 8/11. Just want to make sure there is no metal repair needed before the install.
08-02-2021, 11:04 PM | #4999 |
so i didnt get to the glass yesterday. But tonight its out !! Cut the gasket from the out side & gave it a push - it came out & fell in the bed.
Then I decided to check the vacuum and timing. Vac was 14" at 950 rpm. timing was almost 25 deg. advanced. brought timing back to 15 deg advanced and left rpm's at 950. vaccum jumped to 25 ". truck runs much better!!
08-03-2021, 07:56 AM | #5000 |
havent done much in the last few weeks. been driving it when i have time. still have some light body work to do.
