Old 12-01-2010, 11:27 PM   #501
3r!c84
Badass
3r!c84's Avatar
Re: LS1 into a 73 cheyenne
what size and kind of rims are on the nova? look like 212 eagles
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-02-2010, 11:55 PM   #502
maxxxy
maxxxy's Avatar
This is a very nice truck. Can't wait to see it finished.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 12-12-2010, 03:43 AM   #503
Devillusion
Devillusion's Avatar
Wow.....just, WOW!
Gorgeous build my friend.......absolutely gorgeous! Lovin the big lip out back..those are some nasty shoes!
I hope my crew will look half as good...
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 12-25-2010, 02:03 AM   #504
c10seconds
c10seconds's Avatar
nice job!
c10seconds is offline   Reply With Quote
Old 01-13-2011, 05:20 PM   #505
kvn1011
Kvn1011
kvn1011's Avatar
i know you have at least 5 new pictures for us!!
kvn1011 is offline   Reply With Quote
Old 01-15-2011, 07:57 AM   #506
73gmc454
73gmc454's Avatar
wow theres a lot of mods here , looks great , I like it ,
73gmc454 is offline   Reply With Quote
Old 01-18-2011, 04:14 PM   #507
monte0185
monte0185's Avatar
Originally Posted by smokedat View Post
Today i started on the 4 link i managed to hang to bottom arms and the top piece were the coilovers connect for this I used a 1.50" OD carbon steel pipe. I didnt have enough time to hang the tri angle arms those require more attention due to the fact that the pumkin is off set to the driver side by a few inches, I should be able to knock it out tomorow. here are a few pics of the progress.
How wide is your axle? WMS to WMS? Im thinking about doing something similiar and my axle is 56 3/4" wide.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 01-18-2011, 05:34 PM   #508
Morfias4Twenty
Morfias4Twenty's Avatar
SICK SICK SICK!!!!
......................_____
.........________//__{\_____
,,,,,,,,,/__(O)__/____/_(O)_/
1967 C-10, 383
1975 C-10, 454 SWB Buckets
Low and Slow Baby!
Morfias4Twenty is offline   Reply With Quote
Old 01-21-2011, 06:33 PM   #509
inovermyhead
Wow! The truck is looking great. I really need to get back to work on mine.
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 01-27-2011, 08:36 PM   #510
smokedat
smokedat's Avatar
There 15"s, yes they are Eagles 212
smokedat is offline   Reply With Quote
Old 01-27-2011, 08:38 PM   #511
smokedat
smokedat's Avatar
Sorry Kvn, not much has been done as I have been busy working on other projects. I will start to concentrate more on my truck
Old 01-27-2011, 09:04 PM   #512
smokedat
smokedat's Avatar
It was 49" from outseide of hub to hub. this will vary depending on what brake system you run and of course the back spacing of wheel.
Old 01-28-2011, 03:59 AM   #513
franky69c10
chevy runs deep
franky69c10's Avatar
ttt
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 01-30-2011, 09:55 PM   #514
smokedat
smokedat's Avatar
I took off the mickeys and slapped on sum S10 wheels just until i finish the dirty work. It looks silly with the wheels sunk in so far
Old 01-31-2011, 10:36 AM   #515
Morfias4Twenty
1967 C-10, 383
Low and Slow Baby!
Old 01-31-2011, 10:47 AM   #516
monte0185
monte0185's Avatar
Thanks!! I was thinking it was going to be very close but it looks like ill have some room to spare now!!
Old 02-01-2011, 01:23 AM   #517
smokedat
smokedat's Avatar
Still battling with alignment issues. Passenger and driver side are so whack they need a prayer. I started on the passenger side the top of fender closest to the door needs to be grinded down and on the top it has a huge gap that needs to be built up with weld, and the door has a really big gap all around the top side needs to be built up also. I tried all possible combinations shimming the fender to raise the fender lost the crease line, but in order to keep the crease line this was the only way. I am trying to align the panels to rival those of new cars.
Old 02-01-2011, 11:13 AM   #518
N2TRUX
Happy to be here
N2TRUX's Avatar
Good luck with that. Its a common issue on these trucks, and there is no easy fix. I had a Master Tech look at my Blazer to see what would work. He did the same thing you did by playing with the gaps. The body line is the deal breaker.
His approach was going to be build the window frame rather than the door and fender edge. His thoughts were if the door or fender ever need replaced, they were standard size.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-01-2011, 12:52 PM   #519
68 TT
Still plays with trucks
68 TT's Avatar
I agree. Fit the cab to the doors and the door to the fender.
A fender is more likely to need replaced so keeping it stock and modding the door to match would make the most sense.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-03-2011, 12:36 AM   #520
smokedat
smokedat's Avatar
It was best if i moded the fender the line of the door would look odd if i moded the door instead, and the fender is 1 Off its shaved on the inside
The gap between the fender and door is good now it is eaven from top to bottom. I only got as far as taking the extension piece still need to finish welding and grinding it accordingly. After this I will take on the gap between the cab and door. Last I will deal with the backside of door to cab
Panels are almost perfectly flush expet for some problem areas that will get adressd later, from fender to door and the crease is right on
Old 02-03-2011, 01:58 AM   #521
mcbassin
Still Learning
mcbassin's Avatar
Hey, that's a great idea with the gaps. I like it!
mcbassin is offline   Reply With Quote
Old 02-05-2011, 06:45 PM   #522
smokedat
smokedat's Avatar
Passenger side is almost complete. The door got a beating some areas had to go in and others out but it is good now.
The column or pillar on the cab was slighly out by a 1/16 or 1/8 so i sloted it just the with of the zip disc hammered it in then tack it. If I were to pop the spot welds i would of been there all day.
Panels are perfectly flush all the way around the door to fender to cab I had to beat the lights out of the door edge trim to get it were it needed to be.
Old 02-05-2011, 07:06 PM   #523
smokedat
smokedat's Avatar
2 more
Old 02-05-2011, 07:46 PM   #524
87 chevy silverado
ur putting a lot of time on the body work cant wait see what the finish product looks like.... might still some of these ides in the future..
87 chevy silverado is offline   Reply With Quote
Old 02-06-2011, 12:41 PM   #525
N2TRUX
Happy to be here
N2TRUX's Avatar
Nice work on the gaps. It going to make a HUGE difference when its done.
Articles-
"Refining Sierra"
73c10, c10, cheyenne, ls1, swap
