Old 08-19-2011, 12:23 AM   #501
bjcaldwe
bjcaldwe's Avatar
Re: AD Truck Project
I am here, just haven't had too much motivation. I know the heat sure has not helped things either.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 08-19-2011, 09:34 AM   #502
scotts62
One day...
scotts62's Avatar
The heat has sucked..
Scott
93 crew cab build
Project 62
Old 08-19-2011, 11:07 AM   #503
mcbassin
Still Learning
mcbassin's Avatar
I hear you bro. It has been a hot mother trucker this year. Not even fishing the last month because of it.
I don't know if it's heat or the sweat dripping in my eyes that's worse
mcbassin is offline   Reply With Quote
Old 08-19-2011, 12:42 PM   #504
scotts62
One day...
scotts62's Avatar
Ya no kidding. I put up insulation yesterday and in this heat that was horrible!!!
Scott
93 crew cab build
Project 62
Old 08-19-2011, 02:58 PM   #505
flatbed51
flatbed51's Avatar
ARGHHHHHH THE HEAT !!!!! After working out in this heat all day, the last place you can find me is in the shop.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 09-04-2011, 10:05 PM   #506
bjcaldwe
bjcaldwe's Avatar
I got a little bit done today. I raised the cross member 1 3/4 inches into the frame, as Fred did on his suburban.
It needs to be centered left to right, and just checked over. Then it needs to be tacked in. Some things I am going to need to purchase or make are the upper cups for the air bags, and boxing plates.
Old 09-04-2011, 10:16 PM   #507
scotts62
One day...
scotts62's Avatar
Getting there!!
Scott
93 crew cab build
Project 62
Old 12-28-2011, 01:27 PM   #508
bjcaldwe
bjcaldwe's Avatar
Here is a small update.
I had already tacked in the crossmember. So, after spending a few hours fumbling around looking for parts, and tools, I tacked in the spring hats, and loosely fitted the suspension. Here are a few pics. I need to get a steering rack, and some pieces to make upper spring cups. Then I should be pretty close to making the front complete enough to roll it out of the garage. Then I will pull out the rest of the rat turd infested interior and probably take the bed off and relocate it to the back yard. Even with auto focus, it did not help my shakey hands lol. The pic would be clear and screw up right before I took the pic.
Old 12-28-2011, 02:19 PM   #509
mcbassin
Still Learning
mcbassin's Avatar
Glad to see you back on it again Billy! Looks like some good progress to me.
Old 12-28-2011, 03:28 PM   #510
Groyd
Groyd's Avatar
Looking good. Just nice enough weather to be out in the garage in the evenings this week.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 12-28-2011, 04:36 PM   #511
bjcaldwe
bjcaldwe's Avatar
Thanks. I finally ran out of excuses of why I was not working on it. The weather has definitely helped. I may try to work on it a bit more on Saturday.
Old 12-29-2011, 01:48 AM   #512
scotts62
One day...
scotts62's Avatar
Sweet!! Is that with the cross member raised or not? Hard to see.
Scott
93 crew cab build
Project 62
Old 12-29-2011, 10:39 AM   #513
bjcaldwe
bjcaldwe's Avatar
That is with it raised I think it was about 1 3/4 inches. I am going to do some checking to see which steering rack I need to buy for it. I want to say it is from a thunderbird but I am going to make sure.
Old 12-29-2011, 12:28 PM   #514
scotts62
One day...
scotts62's Avatar
Mustang 2 and Pinto will fit it, power rack was about 120 for mine.
Scott
93 crew cab build
Project 62
Old 12-29-2011, 12:38 PM   #515
bjcaldwe
bjcaldwe's Avatar
That is not bad at all. I know my dad got his at oreillys. I may go see if I can find one Saturday morning.
Old 03-13-2012, 04:58 PM   #516
bjcaldwe
bjcaldwe's Avatar
Here is a small parts update.
A few weeks back I purchased my steering rack. I have ordered f9000 bags for the rear as well as various mounts. When I get closer to actually working on it, I will see about getting a cnotch for the rear. I was going to take advantage of a deal on the forums for an air management kit, but that was putting the cart before the horse. Once the suspension is all put together, I can just run some temporary lines to air it up and roll it around.
Old 03-15-2012, 12:19 AM   #517
1950foru
Do u know where u set your axle centerline
1950foru is offline   Reply With Quote
Old 03-15-2012, 10:11 AM   #518
bjcaldwe
bjcaldwe's Avatar
If you have your stock suspension you can mark it and then adjust from there. Mine has been trial and error and I am not 100% sure I have the front wheels where I want them. There is not enough room in my tiny garage to get a good look from the side. There is a good write up on custom classic truck about going from stock suspension to an IFS. You might look at instructions from other brands of crossmembers. They can give you an idea.
Old 03-15-2012, 12:49 PM   #519
1950foru
Stock suspension is gone I found out Alot of company's are putting there at 18.125 I just want to see if people are about there when there putting there's in if u ever get chance let me me know what u set yours thanks
Old 03-15-2012, 12:53 PM   #520
bjcaldwe
bjcaldwe's Avatar
Mine was laying in a field with no suspension, so I can understand. If I get some concrete measurements I will post them.
Old 03-15-2012, 01:55 PM   #521
scotts62
One day...
scotts62's Avatar
Not to change style of trucks here but i positioned mine in the center and where i liked them when i did my frame because the 60-66 wheels kind of sit weird in the wells IMO.
Scott
93 crew cab build
Project 62
Old 03-15-2012, 02:18 PM   #522
bjcaldwe
bjcaldwe's Avatar
We face the same problem on the AD trucks. I have tried to center mine. The stock position is just for reference.
Old 03-18-2012, 11:29 PM   #523
bjcaldwe
bjcaldwe's Avatar
19504u ..
Check out this link. I know the year model is difference, but further into the article it talks about how to find the center of the wheel well and marking it.
http://www.classictrucks.com/tech/12.../photo_04.html
Old 03-30-2012, 12:25 PM   #524
bjcaldwe
bjcaldwe's Avatar
I also saw this thread talking about front axle center lines.
http://67-72chevytrucks.com/vboard/s...8&postcount=18
I have my cup kit, rear bags, rear mounts, etc now. I installed my steering rack, and have been doing some measuring and day dreaming about the front cups.
Old 04-04-2012, 03:11 PM   #525
bjcaldwe
bjcaldwe's Avatar
The threads are too long on one side of my thunderbird rack, so I was able to use a short outer tierod on one side. I picked up a longer thunderbird tierod for the drivers side. I will probably get 2 moog outers later and cut the threads down on the passenger side.
I have been trying to at the least go out and look over the truck and think about what I want to work on next every evening.
