#501 | |
![]() Join Date: Jul 2010
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Thanks Ryan
![]() I'm really enjoying the build again. I like the mechanic's of the build and glad to be past the body/paint stage. Quote:
Thanks for taking the time to read through my build... You're really going to be glad you choose the LS. The Scott's Hod Rod chassis look really well built and not over priced. Let me know when you begin your build thread I would love to follow along.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#502 |
I was able to get the new water pump and thermostat installed last night. Now I should be able to run it long enough to get the engine up to tempature.
#503 |
I have spent the last few days getting everything back together and tested. I've learned these LS motors are challenging to get the air out of the cooling system. I ended up borrowing a vacuum tool from a friend to bleed the air out. I'm really amazed how well the motor runs so far. I've run the engine long enough to make sure the thermostat and cooling fans are kicking on/off. I order a http://www.plxdevices.com/product_info.php?id=GSST2WIFI so I can read the vitals until I get my gauges hooked up. Next step is to finish up my intake system and get the exhaust done.
#504 |
Pic 2
#505 |
Airlift tool
#506 |
It helps to fill the engine through the upper radiator hose
#507 |
Yes, you're right. I did that and still had an air bound system. After reading on the LS forums it's almost a must to use the airlift tool since the thermostat is on the bottom (suction) hose not on the top (return) hose.
#508 |
Yes I had the same issue. You can either use this tool or spend 2 hours slowly filling to radiator until all the air escapes. Once you can get eater to the thermostat you are good to go because it will open up. My fill wasn't bad because the top of my radiator is above the top of my motor so air escaped pretty easy. I also have a short top hose (both inlet and outlet are on the right side of the radiator). This tool just makes everything much better! I wish I had one when I bled my system the other day.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#509 |
Hmm, that's not what I read, and I filled mine through the upper hose and then the radiator and I never had any problem. Are your steam vents hooked up?
#510 | ||
#511 |
Steam port is located right below the upper hose.
#512 |
Still Learning
Great progress Mark. The last assembly stuff seems to take the longest.
I need to get one of those purge tools, I'm certain I still have a small amount of air in my system. Although mine doesn't overheat, the heater just doesn't get hot. |
#513 | |
Yesterday I finished up my front end (minus the front turn signals I forgot to order lol). I am really happy how well it came out.
#514 |
I found an air filter and plumbing off of Amazon I think may work.
#515 |
I love how the Red looks almost Orange in the sunlight.
#516 |
Truck is looking good. I wish I was at this point in my build! What kit did you use for your air filter? I need to add it to my amazon cart.
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
#517 |
Thanks.. You can find some really good deals on Amazon.. I have about 20 items in my wish list lol. You can find LS6 intakes priced right.
#518 |
Truck looks great!!! I've read through it a couple of time and realized I never subscribed.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#519 |
Awesome, Thank you. One more question, sorry if I'm blind and missing it, but where is your MAS?
#520 |
![]() Join Date: Dec 2006
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#521 | |
Your not blind lol. I ordered two 3.5" to 4" neoprene couplers so I can put it in behind the filter. Sorry I forgot to mention it. The red couplers aren't really red either, they are more orange. It's a nice kit for the price.
#522 |
Still Learning
Looking good Mark!
#523 | |
Thank you for the answers, Mike!
#524 |
Thanks Mike. Again, I appreciate you answering all of my exhaust questions. I found a muffler shop here in town that's going to install my exhaust. The guy has done numerous 67-72 trucks and quoted me a great price.
Yes, the MAS is 3.5". So I plan on going from 4" aluminum pipe to MAS to 4" filter. As soon as I recieve my order I will post a pic. I'm glad to help. I read through your build and looks great. You've made a lot of progress in a short amount of time.
#525 | |
Thanks bud. What else is a 23 year old single dude suppose to do? ![]()
