Old 02-21-2014, 12:37 AM   #501
lenguini
lenguini's Avatar
Re: Project truck dream 65"
Originally Posted by Snowbound View Post
Ed, fill us in on the dyno session.
Good to see you making progress!
Brian
Hey Brian,I do have my own footage but got a little excited and swore so I don't think it would meet the rules here on the site.
I'm still waiting for footage from the shop.
I can tell you 428 ft lbs of torque and just under 400hp.redline approx 5800rpm
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 02-21-2014, 06:46 PM   #502
lenguini
lenguini's Avatar
Ok finally some Dyno footage here ! No swearing in this,excitment got the better of me when capturing the goods on my phone !
In the Dyno room ....
At the screen...
428 ft lbs of torque and 385 hp
Old 02-21-2014, 08:15 PM   #503
pdxhall
pdxhall's Avatar
That's got to be an exciting moment and it sounds awesome. I can't wait till I can get mine fired for the first time.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 02-22-2014, 04:12 PM   #504
lenguini
lenguini's Avatar
Very exciting ! It's one more step in the build.Does sound pretty good ! I'm looking to run 3" stainless exhaust front to back,probably Flowmaster HP2 for mufflers....still debating.
Old 02-22-2014, 04:35 PM   #505
lenguini
lenguini's Avatar
Just got the truck back from the painter this morning.Firewall redo and steering column sprayed in base clear...looking good.
I also had the wood brace/box supports tacked to their underside brackets ,now it should be alot easier to r&r the box next time around.
At one point with wood in and box squared,I drilled reference points with a 1/8 bit and dropped locating pins through the holes.
If you have to go on and off with the box as many times as I did....,you will definately want to take the time to do this.All three brace's that rest on the frame are all done this way,I have circled in red to highlight them.
Old 02-23-2014, 03:43 PM   #506
McMurphy
McMurphy's Avatar
I love the bed support member reference/align idea... going to nab that one for my build.
Thanks !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-23-2014, 04:28 PM   #507
lenguini
lenguini's Avatar
Thanks !!
Your most welcome !Glad to have helped someone with this idea...once and a while I come up with a good one!
Old 02-25-2014, 03:07 AM   #508
lenguini
lenguini's Avatar
Looking fo a set of 1967 1968 1969 1970 1971 1972 SMALL BLOCK CHEVY MOTOR MOUNT PERCH'S.
If any one can help me with an original set.
Old 02-25-2014, 10:40 AM   #509
Ta2Don
Ta2Don's Avatar
Thanks !!
X2!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-25-2014, 05:25 PM   #510
rusty_67
rusty_67's Avatar
Ed, I might have some, will check later this afternoon.
rusty_67 is offline   Reply With Quote
Old 02-25-2014, 11:20 PM   #511
lenguini
lenguini's Avatar
I'll hold my breath till you call ! I'm getting close to the install,but wanted to cover my base's before hand.I have a feeling the engine is coming ahead far enough that my current ones wont work.
Thanks bud.
Old 02-26-2014, 02:32 AM   #512
lenguini
lenguini's Avatar
I finally mounted the column in place for the last time..,and it felt good ! A local Rod builder up here supplied me with some custom 6061 finishing washers that I used at the mount and will probably use on the hood hinge's and other areas I can think of later on.
The booster went on just after.It looks good with Cap's booster bracket and the aluminum top cap I made to finish it all.
I also started on my battery tray tonight,I'm loosing the factory hold down and making a block that secures the battery at the bottom.
Old 03-01-2014, 02:39 PM   #513
lenguini
lenguini's Avatar
Yesterday I had a day off from work,so I took advantage of it and brought the remainder of the engine bay parts being the hood,inner fenders etc. to the paint shop.
It's exciting to be moving ahead at this rate now ! In all fairness,alot of time and energy went into preparing for it.The last thing I wanted to do was drill into fresh paint for something I overlooked.
The latest job completed was drilling a hole at the rear passenger side of the hood for a 3'8 I.D stainless door loom.I tossed the idea of the contacts to eliminate the singnal wires,but anything I found just wasn't small and durable.enough in my opinion.
By the end of the month I will have everything back from the paint shop,I was clear to my painter there was no rush,so if anything might have been missed,I will have bought some time here.
Old 03-01-2014, 10:43 PM   #514
lenguini
lenguini's Avatar
I went to a battery shop today and found a dead donor for my mod.It's a newer Chevy version so it will be easy to get when it comes time to bolt the new one in.
I made the rear mounts out of some scrap laying around the shop.I'm always glad I kept the small stuff,beats going to the local steel yard and wasting time.
The plastic block,Chevy as well.Had to modify it front and back to make it fit, now holds the battery tightly in place.
Old 03-01-2014, 11:09 PM   #515
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
DUDE!!!!! WOWZA! WOWZA! That thing is wicked! I'm gonna have to challenge you to a race with my 496 bigblock in my 77 C-20! AWESOME! truck is looking good to! Burnout time!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-01-2014, 11:37 PM   #516
lenguini
lenguini's Avatar
Originally Posted by T.J. MCCAULEY View Post
DUDE!!!!! WOWZA! WOWZA! That thing is wicked! I'm gonna have to challenge you to a race with my 496 bigblock in my 77 C-20! AWESOME! truck is looking good to! Burnout time!!!! http://www.youtube.com/watch?v=nKWv_...re=c4-overview
Thanks bud ! Race...you bet ! I know a good stretch of road in Seattle,when the time comes....winner buys the beer !
Old 03-08-2014, 02:13 PM   #517
lenguini
lenguini's Avatar
Going to the wrecking yard today to find Chevy 3157 pigtails for the front signal/marker lights.I have a loaner out of a Chrysler for a guide to compare with when the search starts.
I came up with a cool idea that will alllow my marker lights to be lit up white and signals to flash amber.The style bulb I will be using is silver ,so it should be hidden well behind the lens.
I'm running the clear lens and do not want to see the orange bulb in the background of the housing,so hopefully this works out.
Old 03-08-2014, 11:11 PM   #518
lenguini
lenguini's Avatar
Here we go,late model Chevy Blazer signal pigtails.They fit as tight and maybe just a little better than the original socket.
I now have the updated 3157 bulb,not to mention a lower profile socket that will make it easier route and hide the wires.
Old 03-17-2014, 01:18 AM   #519
lenguini
lenguini's Avatar
I just received my sail panels this weekend ! They have been reworked and restored back to better than new.
Now I'm looking for the mounts,guess I had hoped they would come with but did not.
Anyone know where I might find these ? Hope to go with originals.
Old 03-17-2014, 10:22 PM   #520
lenguini
lenguini's Avatar
Spent the weekend in Vancouver,took my friend Chopper with me.Had a great visit with some friends and family and of course "Rocky the Lab"....,Choppers buddy.
While I was there,I picked up a trunk load of parts for the truck.Air cleaner,serp pulleys,door looms,headlights,kick down and throttle cables,the list goes on.
So today I installed my push button starter switch,It fit tight and covered the OEM hole completely.It blends in nicely with the original buttons and lighter.
No more worries of scratches in the dash from keys !
Old 03-19-2014, 01:32 AM   #521
lenguini
lenguini's Avatar
Assembled the new Hella 4 E-Codes tonight.They come with a 60w-55w bulb which combined with the housing and the way it's designed should increase the candle output by almost 50% over original.(So I've been told)
Put the headlights into the buckets and mount.Replaced the screws,nuts and springs as well. Everything seems to fit pretty good for the upgrade.
I did see in a post some time back that the rubber cover at the back has a tendancy to push the plug off ,so just to trim it back around the prongs.Ill do that later on and post a pic.
Old 03-29-2014, 05:59 PM   #522
lenguini
lenguini's Avatar
I decided to go with .035 wall stainless for brake and fuel lines. At this stage of the game.., why cheap out.
I will be using AN fittings with a 37 degree flare as anyone who has tried knows a 45 degree dual flare on stainless is near impossible to achieve.
I picked up the lines yesterday after work, and was able to bring the brake line at 20 foot long home without cutting it down. Almost 8 feet lancing out the passenger window...,good thing no cops were around.
Today I spent the morning polishing it all .
So after work next week, this will all get plumbed in with hopes of installing the engine and trans a week or two after.
Old 03-30-2014, 02:31 PM   #523
McMurphy
McMurphy's Avatar
I also got my brake and fuel lines in those lengths, and it is nice knowing that I didnt have to patch a bunch of shorter lines together to get from the front of the frame to the rear.
I was nervous about flaring my own ends, but am happy to report they have been connected and filled almost 6 months now without any signs of leakage. Next will be to check them after they have been run with pressure...
Looking forward to seeing your work on this, I am sure you have something really nice in store !!
I love your work, you inspire me often
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-30-2014, 07:20 PM   #524
lenguini
lenguini's Avatar
By chance did you do them in stainless ? Yes doing the lines without more joints than needed makes for less headaches in the end.
Thanks for the kind words bud,appreciate it.
Old 03-30-2014, 10:30 PM   #525
pdxhall
pdxhall's Avatar
Great work, man. I always look forward to your updates. I have been working on my brake lines and I'm hoping to do my fuel line real soon so I have a particular interest in what you've got going on. The small details make all the difference.
Sanity'66
