01-17-2016, 08:44 PM | #501 |
Re: My 78 K15 High Sierra build - Fish Tremble
Working on the pedal assemblies now. Cleaned up and painted with Rustoleum hammered black, just because that's what I had. Anyone know where the piece in the last 2 pictures comes from? A couple years ago when I disassembled this I just labeled it "fell out of the pedal assembly". If anyone has a picture of it in place it would help tremendously.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
01-17-2016, 08:50 PM | #502 |
Also trying to figure out what to do with my steering column. While its out, I'd like to replace anything worn or likely to break. I've found a number of threads about fixing this or that in the column, but have not found any about rebuilding the column. I know I want to replace the boot on the shaft coupler, as well as the rag joint. Anyone know if this pin is supposed to come out so I can put a new boot on? Tried hammering and pressing out in vise but it doesn't budge. Any links to column rebuilds would be appreciated.
01-18-2016, 12:16 AM | #503 |
Nice work! I'm really impressed with your build.
I don't recognize that bracket. My guess would be that it has something to do with the clutch. Looks like it has a hole for a spring? Is that a non-tilt column? Most rebuild threads I have seen have to do with tightening up a loose tilt column. Fortunately, mine was tight. I just painted it, replaced the wiper stalk and put it back in. |
01-18-2016, 12:22 PM | #504 |
Thanks Greenlee. Yes, it is a non-tilt column. I was considering using a tilt column that I have from a '93, but it wasn't a close enough match that I wanted to bother with it.
01-26-2016, 01:37 PM | #505 |
Clutch or brake light switch spring bracket? I'd hit Ebay and search this...... "73 87 Chevy Truck Clutch Pedal" ....... and start scanning pic's. Or is there a chance it was bolted elsewhere in the truck and a spring runs from the brake or clutch pedal to the bracket?
Not much help with the steering column..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-01-2016, 10:04 PM | #506 |
Been making some piddly progress. Got my passenger fender cut & buffed (2nd picture), but I really should have taken a warning from swamp rat's hood mishap. Saturday I'd been in the shop like 5 minutes and hear a big crash. Gust of wind had knocked over the driver side fender that I'd already finished (but not mounted). It fell flat onto the concrete. I don't think it dented or dinged, but not sure that this will buff out. This may just be the excuse I need to figure out spot repairs on the paint.
02-01-2016, 10:08 PM | #507 |
Also got some pedals hung, and mounted my new brake booster. I still have a couple brackets that go in there somewhere. I've got a factory assembly manual for 82 c/k trucks coming that will hopefully show where they go. New pedal rubber from LMC - fit just fine.
02-01-2016, 10:12 PM | #508 |
Also got a pair of door bumpers from LMC so I don't have worry about metal on metal when I close the doors. Made a gasket to mount the fuel filler tubes. Cut new filler and vent hoses to size. Another little project DONE! I like this phase of the build where some things are finally done
02-01-2016, 10:57 PM | #509 |
Second Chance Program
Nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
02-02-2016, 08:45 AM | #510 |
Oh hell yeah! Looking great Rick. This is the fun part. Before you know it, it will be done. It did slow down for me though at this stage as all the little stuff needed to be ordered. I tried in vane to do a list and still came across a ton of stuff I didn't even think about. Assembly was fun though because I was totally motivated after each piece went back together.
Have fun! Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
02-02-2016, 12:23 PM | #511 |
When I was doing some research on my 84 3+3 donor I found some of the other forums dedicated to 3rd gen trucks had parts manuals in the archives you could reference and download. We were able to get both parts & service manuals for that truck for free. Point being the parts illustrations may get you the location of our pedal assembly brackets and service manuals may help with servicing the column. The AIM's are great but these other resources can help out also.
I hope your fender buffs out and your truck is looking great!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
02-02-2016, 02:54 PM | #512 | ||
Thanks!
02-11-2016, 11:19 PM | #513 |
Uh-oh, I think I'm committed on this steering column now!
02-12-2016, 12:02 AM | #514 |
Hahaha no going back!
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
02-12-2016, 12:14 AM | #515 |
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
02-12-2016, 12:23 AM | #516 |
A Jig saw puzzle!
02-12-2016, 07:11 AM | #517 |
Rick: Took a year (+) off from all the truck stuff. Finally caught up on your thread. Great testimony for staying after it. I'm partial to this body style since I had three of them while in High School. Paint turned out great! Looking forward to the "59 Chevy SWB Stepside (next in line)". dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
02-12-2016, 08:34 AM | #518 |
Good job it's a nice looking truck so far. As far as steering columns go if they ain't broke don't fix em.
02-12-2016, 09:44 AM | #519 |
Is that a non tilt column? Might be better off to start with tilt.
02-12-2016, 11:36 AM | #520 |
Holy Moly! Just kidding I'm sure it'll be like new in no time.
02-12-2016, 05:38 PM | #521 | |||
Well, I may have to be more sober to get it back together than I was taking it apart
Sure hope so! Took a LOT of pictures while disassembling - I'm finally learning If all else fails, there is a guy name milkcrate82 that has a great series of videos rebuilding his C10 column that I'm sure I'll be referring back to a couple of times. https://www.youtube.com/watch?v=2W4Ly0m01LE Quote:
Thanks Brett, just need to order a few things for it "while its apart anyway".
02-12-2016, 10:17 PM | #522 |
Ordered a factory assembly manual for 1982 C-K Models Pickup Blazer and Suburban that just showed up. Thing has to be 4 inches thick, and it is printed double-sided. Tons of great illustrations, but you can't read the index. I'm hoping it will help me figure out where some of the mysterious small parts go that I took off years ago, but its going to take some time to find what I need
02-13-2016, 12:34 AM | #523 |
Good luck Rick! You'll get this!
02-16-2016, 11:42 AM | #524 |
Wow Rick, that things a phone book! We've had AIM hard copies from earlier projects (1955 & several 1966) and they are all less than half that size. I'm thinking in this case bigger is way better because they didn't always cover everything.
02-21-2016, 04:20 PM | #525 |
Bunch of new parts showed up for the steering column. New ignition cylinder, turn signal switch, ignition switch, lower column bearing kit, and ragjoint.
